[petsc-users] SOLVE + PC combination for 7 point stencil (unstructured) poisson solution
    Matthew Knepley
    knepley at gmail.com
    Mon Jun 26 11:11:25 CDT 2023
On Mon, Jun 26, 2023 at 12:08 PM Vanella, Marcos (Fed) via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Than you Matt and Mark, I'll try your suggestions. To configure with hypre
> can I just use the --download-hypre configure line?
Yes,
    Matt
> That is what I did with suitesparse, very nice.
> *From:* Mark Adams <mfadams at lbl.gov>
> *Sent:* Monday, June 26, 2023 12:05 PM
> *To:* Vanella, Marcos (Fed) <marcos.vanella at nist.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] SOLVE + PC combination for 7 point stencil
> I'm not sure what MG is doing with an "unstructured" problem. I assume you
> are not using DMDA.
> -pc_type gamg should work
> I would configure with hypre and try that also: -pc_type hypre
> As Matt said MG should be faster. How many iterations was it taking?
> Try a 100^3 and check that the iteration count does not change much, if at
> all.
> Mark
> On Mon, Jun 26, 2023 at 11:35 AM Vanella, Marcos (Fed) via petsc-users <
> Hi, I was wondering if anyone has experience on what combinations are more
> efficient to solve a Poisson problem derived from a 7 point stencil on a
> single mesh (serial).
> I've been doing some tests of multigrid and cholesky on a 50^3 mesh. *-pc_type
> mg* takes about 75% more time than *-pc_type cholesky
> -pc_factor_mat_solver_type cholmod* for the case I'm testing.
> I'm new to PETSc so any suggestions are most welcome and appreciated,
> Marcos
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230626/20b8473e/attachment-0001.html>
