[petsc-users] SOLVE + PC combination for 7 point stencil (unstructured) poisson solution
    Mark Adams
    mfadams at lbl.gov
    Mon Jun 26 11:05:43 CDT 2023
I'm not sure what MG is doing with an "unstructured" problem. I assume you
are not using DMDA.
-pc_type gamg should work
I would configure with hypre and try that also: -pc_type hypre
As Matt said MG should be faster. How many iterations was it taking?
Try a 100^3 and check that the iteration count does not change much, if at
all.
On Mon, Jun 26, 2023 at 11:35 AM Vanella, Marcos (Fed) via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi, I was wondering if anyone has experience on what combinations are more
> efficient to solve a Poisson problem derived from a 7 point stencil on a
> single mesh (serial).
> I've been doing some tests of multigrid and cholesky on a 50^3 mesh. *-pc_type
> mg* takes about 75% more time than *-pc_type cholesky
> -pc_factor_mat_solver_type cholmod* for the case I'm testing.
> I'm new to PETSc so any suggestions are most welcome and appreciated,
> Marcos
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230626/b9d8d8c6/attachment-0001.html>
