[petsc-users] Scalable Solver for Incompressible Flow
Pierre Jolivet pierre.jolivet at lip6.fr
Fri Jun 23 15:09:01 CDT 2023
> On 23 Jun 2023, at 10:06 PM, Pierre Jolivet <pierre.jolivet at lip6.fr> wrote:
>> On 23 Jun 2023, at 9:39 PM, Alexander Lindsay <alexlindsay239 at gmail.com> wrote:
>> Ah, I see that if I use Pierre's new 'full' option for -mat_schur_complement_ainv_type
> That was not initially done by me
Oops, sorry for the noise, looks like it was done by me indeed in 9399e4fd88c6621aad8fe9558ce84df37bd6fada…
Pierre
> (though I recently tweaked MatSchurComplementComputeExplicitOperator() a bit to use KSPMatSolve(), so that if you have a small Schur complement — which is not really the case for NS — this could be a viable option, it was previously painfully slow).
> Thanks,
> Pierre
>> that I get a single iteration for the Schur complement solve with LU. That's a nice testing option
>> On Fri, Jun 23, 2023 at 12:02 PM Alexander Lindsay <alexlindsay239 at gmail.com <mailto:alexlindsay239 at gmail.com>> wrote:
>>> I guess it is because the inverse of the diagonal form of A00 becomes a poor representation of the inverse of A00? I guess naively I would have thought that the blockdiag form of A00 is A00
>>> On Fri, Jun 23, 2023 at 10:18 AM Alexander Lindsay <alexlindsay239 at gmail.com <mailto:alexlindsay239 at gmail.com>> wrote:
>>>> Hi Jed, I will come back with answers to all of your questions at some point. I mostly just deal with MOOSE users who come to me and tell me their solve is converging slowly, asking me how to fix it. So I generally assume they have built an appropriate mesh and problem size for the problem they want to solve and added appropriate turbulence modeling (although my general assumption is often violated).
>>>> > And to confirm, are you doing a nonlinearly implicit velocity-pressure solve?
>>>> Yes, this is our default.
>>>> A general question: it seems that it is well known that the quality of selfp degrades with increasing advection. Why is that?
>>>> On Wed, Jun 7, 2023 at 8:01 PM Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>>>> Alexander Lindsay <alexlindsay239 at gmail.com <mailto:alexlindsay239 at gmail.com>> writes:
>>>>> > This has been a great discussion to follow. Regarding
>>>>> >> when time stepping, you have enough mass matrix that cheaper preconditioners are good enough
>>>>> > I'm curious what some algebraic recommendations might be for high Re in
>>>>> > transients.
>>>>> What mesh aspect ratio and streamline CFL number? Assuming your model is turbulent, can you say anything about momentum thickness Reynolds number Re_θ? What is your wall normal spacing in plus units? (Wall resolved or wall modeled?)
>>>>> > I've found one-level DD to be ineffective when applied monolithically or to the momentum block of a split, as it scales with the mesh size.
>>>>> I wouldn't put too much weight on "scaling with mesh size" per se. You want an efficient solver for the coarsest mesh that delivers sufficient accuracy in your flow regime. Constants matter.
>>>>> Refining the mesh while holding time steps constant changes the advective CFL number as well as cell Peclet/cell Reynolds numbers. A meaningful scaling study is to increase Reynolds number (e.g., by growing the domain) while keeping mesh size matched in terms of plus units in the viscous sublayer and Kolmogorov length in the outer boundary layer. That turns out to not be a very automatic study to do, but it's what matters and you can spend a lot of time chasing ghosts with naive scaling studies.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230623/0b8ed25a/attachment.html>
