[petsc-users] snes_type aspin without DA example
Barry Smith bsmith at petsc.dev
Fri Jun 23 11:51:48 CDT 2023
Look at SNESSetUp_NASM() src/snes/nasm/nasm.c  and see the if (dm) case. It calls DMCreateDomainDecomposition() to get subdms and then calls DMCreateDomainDecompositionScatters() to get the scatters that would be passed to SNESNASMSetSubdomains(). Then it builds the subsnes. These are
the ingredients needed to construct the objects passed to SNESNASMSetSubdomains().
One could argue that this code fragment would be better if it did not interact directly with the internals of &nasm->oscatter etc but instead created the objects and then (in the routine) called SNESNASMSetSubdomains() but anyways it is how it ended up.
  Barry
> On Jun 23, 2023, at 3:40 AM, Karin&NiKo <niko.karin at gmail.com> wrote:
> Dear Barry,
> I have started looking at the code but I miss an example using SNESNASMSetSubdomains. In fact I do not even find a single use of the function in PETSc.
> Could someone provide me with an example ?
> Thanks,
> Nicolas
> Le ven. 23 juin 2023 à 02:17, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> a écrit :
>>   A test would be great.
>>> On Jun 22, 2023, at 3:20 PM, Karin&NiKo <niko.karin at gmail.com <mailto:niko.karin at gmail.com>> wrote:
>>> Thank you Barry. I will try this.
>>> Should I provide a test in src/binding/petsc4py/test/test_snes.py ?
>>> Le jeu. 22 juin 2023 à 20:41, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> a écrit :
>>>>   You are not missing anything. The petsc4py stub for SNESNASMSetSubdomains() has not been written. You could add it by adding to
>>>> src/petsc4py/PETSc/SNES.pyx and src/petsc4py/PETSc/petscsnes.pxi and then make a merge request  https://petsc.org/release/developers/contributing/ to get it into PETSc.
>>>>> On Jun 22, 2023, at 1:54 PM, Karin&NiKo <niko.karin at gmail.com <mailto:niko.karin at gmail.com>> wrote:
>>>>> Dear PETSc team,
>>>>> I would like to play with aspin-type nonlinear solvers. I have found several tests like snes/tutorials/ex19.c but they all use DA, which I don't want to use since I need to stick at the algebraic level.
>>>>> Then, I started looking at petsc4py/demo/ode/heat.py and tried to set up things.
>>>>> Unfortunately, I get the error "DM has no default decomposition defined.  Set subsolves manually with SNESNASMSetSubdomains()" which, I think, I do understand.
>>>>> But I do not find any implementation of the SNESNASMSetSubdomains in petsc4py.
>>>>> Am I missing something ?
>>>>> Thanks,
>>>>> Nicolas
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230623/510c328a/attachment.html>
