[petsc-users] hypre-ILU vs hypre Euclid
Matthew Knepley
knepley at gmail.com
Thu Jun 22 20:49:07 CDT 2023
On Thu, Jun 22, 2023 at 8:37 PM Alexander Lindsay <alexlindsay239 at gmail.com>
wrote:
> I know that PETSc has hooks for Euclid but I discovered today that it does
> not support 64 bit indices, which many MOOSE applications need. This would
> probably be more appropriate for a hypre support forum (does anyone know if
> such a forum exists other than opening GitHub issues?), but does anyone
> here know what the difference between hypre-ILU and hypre-Euclid are? From
> the docs it seems they are both supposed to be parallel ILU solvers.
> If hypre-ILU worked with 64 bit indices (I can probably check this sifting
> through the sources), then I would probably add hooks for it in PETSc
> (AFAICT those don't exist at present).
My understanding was that two different people were working on them. I do
not know if either is still actively supported. We would of course like a
binding to whatever is supported.
Are you sure you want to run ILU?
THanks,
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230622/fc9c32de/attachment.html>
