[petsc-users] How to efficiently fill in, in parallel, a PETSc matrix from a COO sparse matrix?
Diego Magela Lemos
diegomagela at usp.br
Wed Jun 21 14:08:34 CDT 2023
Finally!
Moving these routines to outside the if statement solved the problem!
Thank you!
Em qua., 21 de jun. de 2023 às 15:23, Barry Smith <bsmith at petsc.dev>
escreveu:
> These routines are marked as collective in their manual pages and must
> be called by all MPI processes that share the matrix A.
> PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY));
> PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY));
> PetscCall(MatView(A, PETSC_VIEWER_STDERR_WORLD));
> On Jun 21, 2023, at 2:16 PM, Diego Magela Lemos via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> So far, I've tried this:
> // fill_in_matrix.cc
> static char help[] = "Fill in a parallel COO format sparse matrix.";
> #include <petsc.h>
> #include <vector>
> int main(int argc, char **args)
> MPI_Comm comm;
> Mat A;
> PetscInt m = 5;
> PetscMPIInt rank, size;
> PetscCall(PetscInitialize(&argc, &args, NULL, help));
> comm = PETSC_COMM_WORLD;
> PetscCallMPI(MPI_Comm_rank(comm, &rank));
> PetscCallMPI(MPI_Comm_size(comm, &size));
> PetscCall(MatCreate(comm, &A));
> PetscCall(MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, m, m));
> PetscCall(MatSetFromOptions(A));
> PetscCall(MatSetUp(A));
> std::vector<PetscInt> coo_i{0, 0, 1, 2, 3, 4};
> std::vector<PetscInt> coo_j{0, 0, 1, 2, 3, 4};
> std::vector<PetscScalar> coo_v{2, -1, 2, 3, 4, 5};
> if (rank == 0)
> for (size_t j = 0; j < coo_i.size(); j++)
> PetscCall(MatSetValues(A,
> 1, &coo_i.at(j),
> 1, &coo_j.at(j),
> &coo_v.at(j),
> ADD_VALUES));
> PetscCall(MatDestroy(&A));
> PetscCall(PetscFinalize());
> return 0;
> When running with 1 process, it runs like a charm, but when running with
> more than one process, the code does not finish. Somehow it gets stuck
> forever.
> Em qua., 21 de jun. de 2023 às 14:12, Matthew Knepley <knepley at gmail.com>
> escreveu:
>> On Wed, Jun 21, 2023 at 12:57 PM Diego Magela Lemos <diegomagela at usp.br>
>> wrote:
>>> Unfortunately, I can modify ex2 to perform the matrix fill in using only
>>> one rank, although I have understood how it works.
>>> Is it so hard to do that?
>> It should not be. Maybe describe what is not clear? ex2 runs in parallel
>> now.
>> Thanks,
>> Matt
>>> Thank you.
>>> Em qua., 21 de jun. de 2023 às 12:20, Mark Adams <mfadams at lbl.gov>
>>> escreveu:
>>>> ex2 looks the same as the code at the beginning of the thread, which
>>>> looks fine to me, yet fails.
>>>> (the only thing I can think of is that &v.at(i) is not doing what one
>>>> wants)
>>>> Diego: I would start with this ex2.c, add your view statement, verify;
>>>> incrementally change ex2 to your syntax and see where it breaks.
>>>> Mark
>>>> On Wed, Jun 21, 2023 at 9:50 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Wed, Jun 21, 2023 at 9:22 AM Diego Magela Lemos <diegomagela at usp.br>
>>>>> wrote:
>>>>>> Please, could you provide a minimal working example (or link) of how
>>>>>> to do this?
>>>>> You can see here
>>>>> https://petsc.org/main/src/ksp/ksp/tutorials/ex2.c.html
>>>>> that each process only sets values for the rows it owns.
>>>>> Thanks,
>>>>> Matt
>>>>>> Thank you.
>>>>>> Em ter., 20 de jun. de 2023 às 15:08, Matthew Knepley <
>>>>>> knepley at gmail.com> escreveu:
>>>>>>> On Tue, Jun 20, 2023 at 2:02 PM Diego Magela Lemos <
>>>>>>> diegomagela at usp.br> wrote:
>>>>>>>> So... what do I need to do, please?
>>>>>>>> Why am I getting wrong results when solving the linear system if
>>>>>>>> the matrix is filled in with MatSetPreallocationCOO and
>>>>>>>> MatSetValuesCOO?
>>>>>>> It appears that you have _all_ processes submit _all_ triples (i, j,
>>>>>>> v). Each triple can only be submitted by a single process. You can fix this
>>>>>>> in many ways. For example, an easy but suboptimal way is just to have
>>>>>>> process 0 submit them all, and all other processes submit nothing.
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Em ter., 20 de jun. de 2023 às 14:56, Jed Brown <jed at jedbrown.org>
>>>>>>>> escreveu:
>>>>>>>>> Matthew Knepley <knepley at gmail.com> writes:
>>>>>>>>> >> The matrix entries are multiplied by 2, that is, the number of
>>>>>>>>> processes
>>>>>>>>> >> used to execute the code.
>>>>>>>>> > No. This was mostly intended for GPUs, where there is 1 process.
>>>>>>>>> If you
>>>>>>>>> > want to use multiple MPI processes, then each process can only
>>>>>>>>> introduce
>>>>>>>>> > some disjoint subset of the values. This is also how
>>>>>>>>> MatSetValues() works,
>>>>>>>>> > but it might not be as obvious.
>>>>>>>>> They need not be disjoint, just sum to the expected values. This
>>>>>>>>> interface is very convenient for FE and FV methods. MatSetValues with
>>>>>>>>> ADD_VALUES has similar semantics without the intermediate storage, but it
>>>>>>>>> forces you to submit one element matrix at a time. Classic parallelism
>>>>>>>>> granularity versus memory use tradeoff with MatSetValuesCOO being a clear
>>>>>>>>> win on GPUs and more nuanced for CPUs.
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230621/bf3ced4a/attachment-0001.html>
