[petsc-users] How to efficiently fill in, in parallel, a PETSc matrix from a COO sparse matrix?
Mark Adams mfadams at lbl.gov
Wed Jun 21 10:20:01 CDT 2023
ex2 looks the same as the code at the beginning of the thread, which looks
fine to me, yet fails.
(the only thing I can think of is that &v.at(i) is not doing what one wants)
Diego: I would start with this ex2.c, add your view statement, verify;
incrementally change ex2 to your syntax and see where it breaks.
On Wed, Jun 21, 2023 at 9:50 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jun 21, 2023 at 9:22 AM Diego Magela Lemos <diegomagela at usp.br>
> wrote:
>> Please, could you provide a minimal working example (or link) of how to
>> do this?
> You can see here
>   https://petsc.org/main/src/ksp/ksp/tutorials/ex2.c.html
> that each process only sets values for the rows it owns.
>   Thanks,
>      Matt
>> Thank you.
>> Em ter., 20 de jun. de 2023 às 15:08, Matthew Knepley <knepley at gmail.com>
>> escreveu:
>>> On Tue, Jun 20, 2023 at 2:02 PM Diego Magela Lemos <diegomagela at usp.br>
>>> wrote:
>>>> So... what do I need to do, please?
>>>> Why am I getting wrong results when solving the linear system if the
>>>> matrix is filled in with MatSetPreallocationCOO and MatSetValuesCOO?
>>> It appears that you have _all_ processes submit _all_ triples (i, j, v).
>>> Each triple can only be submitted by a single process. You can fix this in
>>> many ways. For example, an easy but suboptimal way is just to have process
>>> 0 submit them all, and all other processes submit nothing.
>>>   Thanks,
>>>   Matt
>>>> Em ter., 20 de jun. de 2023 às 14:56, Jed Brown <jed at jedbrown.org>
>>>> escreveu:
>>>>> Matthew Knepley <knepley at gmail.com> writes:
>>>>> >> The matrix entries are multiplied by 2, that is, the number of
>>>>> processes
>>>>> >> used to execute the code.
>>>>> > No. This was mostly intended for GPUs, where there is 1 process. If
>>>>> you
>>>>> > want to use multiple MPI processes, then each process can only
>>>>> introduce
>>>>> > some disjoint subset of the values. This is also how MatSetValues()
>>>>> works,
>>>>> > but it might not be as obvious.
>>>>> They need not be disjoint, just sum to the expected values. This
>>>>> interface is very convenient for FE and FV methods. MatSetValues with
>>>>> ADD_VALUES has similar semantics without the intermediate storage, but it
>>>>> forces you to submit one element matrix at a time. Classic parallelism
>>>>> granularity versus memory use tradeoff with MatSetValuesCOO being a clear
>>>>> win on GPUs and more nuanced for CPUs.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230621/1022541f/attachment-0001.html>
