[petsc-users] Inquiry about the c++ destructor and PetscFinalize.
neil liu
liufield at gmail.com
Fri Jun 16 17:13:33 CDT 2023
Dear Petsc developers,
I am trying to use Petsc with C++. And came across one issue.
Class DMManage has been defined, one default constructor and destructor has
been defined there.
The code has a runtime error, "double free or corruption". Finally I found
that, this is due to PetscFinalize. If I called explicitly the destructor
before this PetscFinalze, the error will disappear.
Does that mean PetscFinalize do some work to destroy DM?
#include <petscdmplex.h>
#include <petscdmadaptor.h>
#include <petscds.h>
#include <petscviewerhdf5.h>
class DMManage{
PetscSF distributionSF;
public:
DM dm;
DMManage();
~DMManage();
DMManage::DMManage(){
const char filename[] = "ParallelWaveguide.msh";
DM dmDist;
PetscViewer viewer;
PetscViewerCreate(PETSC_COMM_WORLD, &viewer);
PetscViewerSetType(viewer, PETSCVIEWERASCII);
PetscViewerFileSetMode(viewer, FILE_MODE_READ);
PetscViewerFileSetName(viewer, filename);
DMPlexCreateGmsh(PETSC_COMM_WORLD, viewer, PETSC_TRUE, &dm);
PetscViewerDestroy(&viewer);
PetscInt overlap = 0;
DMPlexDistribute(dm, overlap, &distributionSF, &dmDist);
std::cout<<&dm<<std::endl;
if (dmDist) {
DMDestroy(&dm);
dm = dmDist;
DMDestroy(&dmDist);
DMManage::~DMManage(){
DMDestroy(&dm);
int main(int argc, char** argv) {
PetscFunctionBeginUser;
PetscCall(PetscInitialize(&argc, &argv, NULL, help));
DMManage objDMManage;
PetscFinalize();
return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230616/dd5e2e1a/attachment.html>
