[petsc-users] Question about using MatCreateAIJ
Matthew Knepley
knepley at gmail.com
Thu Jun 15 09:51:19 CDT 2023
On Thu, Jun 15, 2023 at 8:32 AM Karsten Lettmann <
karsten.lettmann at uni-oldenburg.de> wrote:
> Dear all,
> I'm quite new to PETSC. So I hope the following questions are not too
> stupid.
> 1) We have a (Fortran) code, that we want to update from an older PETSC
> version (petsc.2.3.3-p16) to a newer version.
> Inside the old code, for creating matrices A, there are function calls
> of the from:
> MatCreateMPIAIJ
> In the reference page for this old version it says:
> When calling this routine with a single process communicator, a matrix
> of type SEQAIJ is returned.
> So I assume the following behavior of this old routine:
> - for N_proc == 1:
> a matrix of type SEQAIJ is returned.
> - for N_proc > 1:
> a matrix of type MPIAIJ is returned
> 2a) So, in the new code, we want to have a similar behavior.
> I found that this function is not present any more in the newer PETSC
> versions.
> Instead, one might use: MatCreateAIJ(….)
> ( https://petsc.org/release/manualpages/Mat/MatCreateAIJ/ )
> If I understand the reference page of the function correctly, then,
> actually, a similar behavior should be expected:
> - for N_proc == 1:
> - for N_proc > 1:
> 2b) However, on the reference page, there is the note:
> It is recommended that one use the MatCreate(), MatSetType() and/or
> MatSetFromOptions(), MatXXXXSetPreallocation() paradigm instead of this
> routine directly.
> So, if I want the behavior above, it is recommended to code it like
> this, isn't it:
> If (N_Proc == 1)
> MatCreate(.. ,A ,...)
> MatSetType(…,A, MATSEQAIJ,..)
> MatSetSizes(…,A, ..)
> MatSeqAIJSetPreallocation(,...A,...)
> else
> MatSetType(…,A, MATMPIAIJ,..)
> MatMPIAIJSetPreallocation(,...A,...)
You can use
MatCreate(comm, &A);
MatSetType(A, MATAIJ);
MatSetSizes(A, ...);
MatXAIJSetPreallocation(A, ...);
We recommend this because we would like to get rid of the convenience
functions that
wrap up exactly this code.
Matt
> end
> 3) So my questions are:
> - Is my present understanding correct?
> If yes:
> - Why might using MatCreateAIJ(….) for my case not be helpful?
> - So, why is it recommended to use the way 2b) instead of this
> MatCreateAIJ(….) ?
> Best, Karsten
> ICBM
> Section: Physical Oceanography
> Universitaet Oldenburg
> Postfach 5634
> D-26046 Oldenburg
> Germany
> Tel: +49 (0)441 798 4061
> email: karsten.lettmann at uni-oldenburg.de
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230615/6ba654f8/attachment-0001.html>
