[petsc-users] dm_view of high-order geometry/solution
Duan Junming
junming.duan at epfl.ch
Mon Jun 12 08:38:35 CDT 2023
Dear Jed,
Thank you for the suggestion.
When I run tests/ex33.c with
./ex33 -dm_plex_simplex 0 -dm_plex_box_faces 1,1 -mesh_transform annulus -dm_coord_space 0 -dm_coord_petscspace_degree 3 -dm_refine 1 -dm_view cgns:test.cgns
and load it using Paraview,
the mesh is still with straight lines.
Should I modify the code to make cgns work? Or any other examples for me to start?
Thanks!
Junming
Sent: Monday, June 12, 2023 2:52:48 PM
To: Matthew Knepley; Duan Junming
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] dm_view of high-order geometry/solution
Matthew Knepley <knepley at gmail.com> writes:
> On Mon, Jun 12, 2023 at 6:01 AM Duan Junming <junming.duan at epfl.ch> wrote:
>> Dear Matt,
>> Thank you for the reply. I have a more specific question about the
>> spectral element example. Do you have any suggestions that how to write
>> all the nodes in each cell to .vtu?
> It is the same procedure. VTU is not a great format for this. It wants
> everything at first order.
I would recommend configuring with --download-cgns and running with -dm_view cgns:output.cgns. This format has efficient parallel IO and curved elements work for moderate order in Paraview.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230612/4b27678a/attachment.html>
