[petsc-users] IS natural numbering to global numbering
    Matthew Knepley
    knepley at gmail.com
    Fri Jun  9 13:04:05 CDT 2023
On Fri, Jun 9, 2023 at 1:46 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
> Hi Barry,
> Is there any way to use the mapping generated by DMPlexDistribute along
> with AO?
For Plex, if you turn on
  https://petsc.org/main/manualpages/DM/DMSetUseNatural/
before DMPlexDistribute(), it will compute and store a GlobalToNatural map.
This can be
used to map vectors back and forth, but you can extract the SF
  DMPlexGetGlobalToNaturalSF
<https://petsc.org/main/manualpages/DMPlex/DMPlexGetGlobalToNaturalSF/>
and use that to remap your IS, by extracting the indices.
  THanks,
     Matt
> Thanks,
> Josh
> Barry Smith <bsmith at petsc.dev> 於 2023年6月9日 週五 上午10:42寫道:
>>   You might be looking for
>> https://petsc.org/release/manualpages/AO/AO/#ao
>> On Jun 9, 2023, at 11:02 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> An IS is just an array of integers. We need your context.
>> Is this question for sparse matrices? If so look at the documentation on
>> the AIJ matrix construction and the global vertex numbering system.
>> Mark
>> On Thu, Jun 8, 2023 at 1:15 PM YuSh Lo <ysjosh.lo at gmail.com> wrote:
>>> Hi,
>>> I have an IS that contains some vertex that is in natural numbering. How
>>> do I map them to global numbering without being distributed?
>>> Thanks,
>>> Josh
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230609/8bfafad8/attachment.html>
