[petsc-users] Petsc using VecDuplicate in solution process
Stefano Zampini
stefano.zampini at gmail.com
Tue Jun 6 09:39:38 CDT 2023
Il giorno mar 6 giu 2023 alle ore 09:24 Pichler, Franz <
franz.pichler at v2c2.at> ha scritto:
> Hello,
> I was just investigating my KSP_Solve_BCGS Routine with algrandcallgrind,
> I see there that petsc is using a vecduplicate (onvolvin malloc and copy)
> every time it is called.
Do you mean KSPSolve_BCGS?
There's only one VecDuplicate in there and it is called only once. An
example code showing the problem would help
> I call it several thousand times (time evolution problem with rather small
> matrices)
> I am not quite sure which vector is copied there but I guess is the
> initial guess or the rhs,
> Is there a tool in petsc to avoid any vecduplication by providing a fixed
> memory for this vector?
> Some corner facts of my routine:
> I assemble the matrices(crs,serial) and vectors myself and then use
> MatCreateSeqAIJWithArrays and VecCreateSeqWithArray
> To wrap petsc around it,
> I use a ILU preconditioner and the sparsity patterns between the calls to
> not change, the values do,
> Thank you for any hint how to avoid the vecduplicate,
> Best regards
> Franz
> *Dr. Franz Pichler*
> Lead Researcher Area E
> *Virtual Vehicle Research GmbH*
> Inffeldgasse 21a, 8010 Graz, Austria
> Phone: +43 316 873 9818
> www.v2c2.at
> Firmenname: Virtual Vehicle Research GmbH
> Rechtsform: Gesellschaft mit beschränkter Haftung
> Firmensitz: Austria, 8010 Graz, Inffeldgasse 21/A
> Firmenbuchnummer: 224755y
> Firmenbuchgericht: Landesgericht für ZRS Graz
> UID: ATU54713500
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230606/0f09edc5/attachment.html>
