[petsc-users] Failed to configure on Windows with latest Intel OneAPI
Barry Smith
bsmith at petsc.dev
Thu Jun 1 20:24:39 CDT 2023
If you try to access it from the Windows side the file is a link that is not easily dealt with. You need to find some way to access and send the file from Cygwin or copy it to another machine with a sane operating system.
Barry
> On Jun 1, 2023, at 9:12 PM, Hawk Shaw <arsennnic at gmail.com> wrote:
> When I try to open configure.log with Notepad, it says "the file cannot be accessed by the system".
> Besides, the file size is 0 bytes.
> Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> 于2023年6月2日周五 01:20写道:
>> Please send configure.log to petsc-maint at mcs.anl.gov <mailto:petsc-maint at mcs.anl.gov>
>>> On Jun 1, 2023, at 10:01 AM, Hawk Shaw <arsennnic at gmail.com <mailto:arsennnic at gmail.com>> wrote:
>>> Hi,
>>> I failed to configue PETSc on Windows with latest Intel OneAPI toolkit:
>>> ./configure --with-cc="win32fe cl" --with-cxx="win32fe cl" --with-fc=0 \
>>> --with-debugging=0 --with-shared-libraries=0 --with-x=0 --with-quad-precision=0 \
>>> --with-threadcomm=1 --with-openmp=1 \
>>> --with-blaslapack-include="$MKLROOT/include" \
>>> --with-blaslapack-lib="-L$MKLROOT/lib/intel64 mkl_core.lib mkl_intel_thread.lib mkl_intel_lp64.lib libiomp5md.lib" \
>>> --with-mpi-include="$I_MPI_ROOT/include" \
>>> --with-mpi-lib="-L$I_MPI_ROOT/lib/release impi.lib" \
>>> --with-mpiexec="$I_MPI_ROOT/bin/mpiexec" \
>>> --ignore-cygwin-link
>>> However, the configuration was successful with Intel OneAPI 2022.1.0.93 or previous version.
>>> Error message:
>>> Configuring PETSc to compile on your system
>>> ***** WARNING *****
>>> Using default optimization C flags "-O". You might consider manually setting optimal
>>> optimization flags for your system with COPTFLAGS="optimization flags" see
>>> config/examples/arch-*-opt.py for examples
>>> ***** WARNING *****
>>> Using default Cxx optimization flags "-O". You might consider manually setting optimal
>>> optimization flags for your system with CXXOPTFLAGS="optimization flags" see
>>> TESTING: checkCxxLibraries from config.compilers(config/BuildSystem/config/compilers.py:450)
>>> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
>>> Cxx libraries cannot directly be used with C as linker.
>>> If you don't need the C++ compiler to build external packages or for you application you
>>> can run
>>> ./configure with --with-cxx=0. Otherwise you need a different combination of C and C++
>>> compilers
>>> makefile:24: /cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscrules: No such file or directory
>>> make[1]: *** No rule to make target '/cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscrules'. Stop.
>>> gmakefile:67: arch-mswin-c-opt/lib/petsc/conf/files: No such file or directory
>>> make: *** [GNUmakefile:17: /cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/include/petscconf.h] Error 2
>>> /cygdrive/e/petsc-v3.19.2/lib/petsc/conf/variables:140: /cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscvariables: No such file or directory
>>> make: *** [GNUmakefile:17: /cygdrive/e/petsc-v3.19.2/arch-mswin-c-opt/lib/petsc/conf/petscvariables] Error 2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230601/794a1ad4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230601/794a1ad4/attachment-0001.png>
