[petsc-users] Kronecker Product
Jose E. Roman jroman at dsic.upv.es
Mon Jan 30 16:30:06 CST 2023
The matrix can be a shell matrix, only the matrix-vector product operation is required.
Jose
> El 30 ene 2023, a las 22:23, Guglielmo, Tyler Hardy via petsc-users <petsc-users at mcs.anl.gov> escribió:
> I have an implementation of the slepc MFN matrix exponential which is implicitly using ExpoKit.  You have to supply a matrix into the Slepc MFN operator to set the problem up as far as I know.
> Tyler
> From: Matthew Knepley <knepley at gmail.com>
> Date: Monday, January 30, 2023 at 12:24 PM
> To: Guglielmo, Tyler Hardy <guglielmo2 at llnl.gov>
> Cc: Barry Smith <bsmith at petsc.dev>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Kronecker Product
> On Mon, Jan 30, 2023 at 3:08 PM Guglielmo, Tyler Hardy via petsc-users <petsc-users at mcs.anl.gov> wrote:
> I would need the Kronecker product to be explicitly available to perform matrix exponentials.  A and B are of order 5000, so not too large.  I will give storing them on all ranks a shot.  Thanks for the tips!
> Were you going to do exponentials by explicit factorization? For large matrices, I thought it was common to
> use matrix-free methods (https://slepc.upv.es/documentation/current/docs/manualpages/MFN/index.html)
>   Thanks,
>     Matt
> Best,
> Tyler
> From: Barry Smith <bsmith at petsc.dev>
> Date: Monday, January 30, 2023 at 12:01 PM
> Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>   What is large? If A and B have dimensions of 1000, then the Kronecker product is of size 1,000,000. Do you want the Kronecker product to be explicitly formed or just available as matrix vector products?  If just explicitly available then I think you can just store sparse A (for example) completely on all ranks, 10,000 by 10,000 sparse matrix is small for sequential) while B is distributed.
> Barry
> On Jan 30, 2023, at 2:48 PM, Guglielmo, Tyler Hardy <guglielmo2 at llnl.gov> wrote:
> Both matrices (A and B) would be approximately the same size and large.  The use case (for me at least) is to create several large sparse matrices which will be combined in various ways through Kronecker products.  The combination happens at every time step in an evolution, so it really needs to be fast as well.  I’m thinking mpi/petsc is probably not the most optimal way for dealing with this, and might just have to work with single node multi-threading.
> Best,
> Tyler
> Date: Monday, January 30, 2023 at 11:31 AM
> On Mon, Jan 30, 2023 at 2:24 PM Guglielmo, Tyler Hardy via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Thanks Barry,
> I saw that function, but wasn’t sure how to apply it since the documentation says that S and T are dense matrices, but in my case all matrices involved are sparse.  Is there a way to work around the dense requirement?
> We don't have parallel sparse-sparse. It would not be too hard to write, but it would be some work.
> It is hard to understand the use case. Is one matrix much smaller? If not, and you inherit the distribution from A, it seems
> like it might be very suboptimal, and otherwise you would have to redistribute on the fly and it would get very complicated.
>   Thanks,
>      Matt
> Best,
> Tyler
> Date: Monday, January 30, 2023 at 11:12 AM
>    Do you need the explicit sparse representation of the Kronecker product? Or do you want to apply it as an operator or solve systems with it? If the latter you can use https://petsc.org/release/docs/manualpages/Mat/MatCreateKAIJ/#matcreatekaij
>   Barry
> On Jan 30, 2023, at 12:53 PM, Guglielmo, Tyler Hardy via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi all,
> I am wondering if there is any functionality for taking Kronecker products of large sparse matrices that are parallel?  MatSeqAIJKron is as close as I have found, but it seems like this does not work for parallel matrices.  Any ideas here?
> An option could be to make A and B sequential, compute the Kronecker product, C, then scatter C into a parallel matrix?  This seems like a horribly inefficient procedure.  I’m still fairly new to petsc, so thanks for patience :)!
> Best,
> Tyler
> Tyler Guglielmo
> Postdoctoral Researcher
> Lawrence Livermore National Lab
> Office: 925-423-6186
> Cell: 210-480-8000
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> -- Norbert Wiener
