[petsc-users] compile PETSc on win using clang
Guo, Sam
sam.guo at siemens.com
Wed Jan 25 11:31:47 CST 2023
Hi Barry,
Here is the output of win32fe cl --use clang --verbose sizeof.c
Using tool: clang
Win32 Development Tool Front End, version 1.11.4 Fri, Sep 10, 2021 6:33:40 PM
Attempting to create file: C:\cygwin64\tmp\wfe1EB0.tmp
clang
clang: error: no input files
del C:\cygwin64\tmp\wfe1EB0.tmp
Attempting to create file: C:\cygwin64\tmp\wfe1ED1.tmp
clang sizeof.c -link
LINK : fatal error LNK1181: cannot open input file 'ink.lib'
clang: error: linker command failed with exit code 1181 (use -v to see invocation)
del C:\cygwin64\tmp\wfe1ED1.tmp
clang sizeof.c works which produces a.exe.
This is from clang -help:
OVERVIEW: clang LLVM compiler
Sent: Wednesday, January 25, 2023 7:48 AM
To: Guo, Sam (DI SW STS SDDEV MECH PHY FEA FW) <sam.guo at siemens.com>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] compile PETSc on win using clang
Please do as Satish previously suggested
~/petsc/lib/petsc/bin/win32fe/win32fe cl --use clang --verbose sizeof.c
Also do
clang sizeof.c
and send the output of both. Where sizeof.c is
#include <stdio.h>
int main(int argc,char **args)
printf("%d\n",(int)sizeof(int));
return 0;
I may have typos in my sample code so please fix those.
Barry
On Jan 24, 2023, at 6:22 PM, Guo, Sam <sam.guo at siemens.com<mailto:sam.guo at siemens.com>> wrote:
Attached please find configure.log.
error messgae:
C:\home\xian\dev\star\petsc\src\sys\objects\device\INTERF~1\device.cxx(486): error C2065: 'PETSC_DEVICE_CASE': undeclared identifier
From: Satish Balay <balay at mcs.anl.gov<mailto:balay at mcs.anl.gov>>
Sent: Tuesday, January 24, 2023 2:00 PM
To: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Cc: Guo, Sam (DI SW STS SDDEV MECH PHY FEA FW) <sam.guo at siemens.com<mailto:sam.guo at siemens.com>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.wikihow.com%2FInstall-Clang-on-Windows&data=05%7C01%7Csam.guo%40siemens.com%7Ca6e1607f7e23403f9b4008dafe56627d%7C38ae3bcd95794fd4addab42e1495d55a%7C1%7C0%7C638101944252560682%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=BOy9RDMGw11IlwRthzcB5Il3YUIgVVrukbzOMFdV8MI%3D&reserved=0<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.wikihow.com%2FInstall-Clang-on-Windows&data=05%7C01%7Csam.guo%40siemens.com%7C34507bcd28884c9a119b08dafeeb8500%7C38ae3bcd95794fd4addab42e1495d55a%7C1%7C0%7C638102584757255429%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Y1zEjwZF3VgHmtqHgNMgcLmd7fYi7hzZ98vvNI3XA6s%3D&reserved=0>
Is the clang you have from visual studio - as described above?
We don't have experience with using this variant of clang.
If its compatible with 'cl' - and supports the same command interface as 'cl' then the following might work [assuming clang.exe is the compiler binary installed - and available in PATH]:
'--with-cc=win32fe cl --use clang'
Satish
On Tue, 24 Jan 2023, Barry Smith wrote:
> Are you using clang as a replacement for the
> * "Unix-like" Cygwin GNU compilers compilers or
> * MinGW GNU compilers that are compatible with the Microsoft compilers?
> If the former, follow the instructions for using the Cygwin GNU compilers, if the latter follow the directions for the MinGW compilers.
> Send the configure.log and make.log if things go wrong and we'll help you out.
> Barry
> > On Jan 24, 2023, at 4:01 PM, Guo, Sam <sam.guo at siemens.com<mailto:sam.guo at siemens.com>> wrote:
> > Hi PETSc dev team,
> > I try to compile PETSc on win using clang. I am wondering if you could give me some hint. (I've already made intel compiler work on win using win32fe icl).
> > Thanks,
> > Sam Guo
<configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230125/5d467892/attachment.html>
