[petsc-users] compile PETSc on win using clang
Guo, Sam sam.guo at siemens.com
Tue Jan 24 20:14:27 CST 2023
I've added the path to clang to PATH but configuration still failed. configure.log is attached. Thanks a lot for your help.
Sent: Tuesday, January 24, 2023 5:36 PM
To: Guo, Sam (DI SW STS SDDEV MECH PHY FEA FW) <sam.guo at siemens.com>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] compile PETSc on win using clang
Do you have clang in your PATH? Is the binary named clang for something else?
              Defined make macro "CC" to "/home/xian/dev/star/petsc/lib/petsc/bin/win32fe/win32fe cl --use clang"
Executing: /home/xian/dev/star/petsc/lib/petsc/bin/win32fe/win32fe cl --use clang -c -o /tmp/petsc-t4q6osvc/config.setCompilers/conftest.o -I/tmp/petsc-t4q6osvc/config.setCompilers -O2 -MD -wd4996  /tmp/petsc-t4q6osvc/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 15
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
          Error testing C compiler: Cannot compile C with /home/xian/dev/star/petsc/lib/petsc/bin/win32fe/win32fe cl --use clang.
You can try this test below manually - with the --verbose option. [I don't have clang - so using 'cl' here]
balay at ps5 ~/petsc/src/benchmarks
$ ~/petsc/lib/petsc/bin/win32fe/win32fe cl --use cl --verbose sizeof.c
Using tool: cl
Win32 Development Tool Front End, version 1.11.4 Fri, Sep 10, 2021  6:33:40 PM
Attempting to create file: C:\cygwin64\tmp\wfe2972.tmp
cl
Microsoft (R) C/C++ Optimizing Compiler Version 19.30.30709 for x64
del C:\cygwin64\tmp\wfe2972.tmp
Attempting to create file: C:\cygwin64\tmp\wfe2983.tmp
cl sizeof.c -link
Copyright (C) Microsoft Corporation.  All rights reserved.
sizeof.c
Microsoft (R) Incremental Linker Version 14.30.30709.0
/out:sizeof.exe
sizeof.obj
del C:\cygwin64\tmp\wfe2983.tmp
$ ~/petsc/lib/petsc/bin/win32fe/win32fe cl --use dummy-binary --verbose sizeof.c
Using tool: dummy-binary
Attempting to create file: C:\cygwin64\tmp\wfe6AD0.tmp
dummy-binary
win32feutils::CreateProcess failed.
dummy-binary
The system cannot find the file specified.
del C:\cygwin64\tmp\wfe6AD0.tmp
Satish
On Wed, 25 Jan 2023, Guo, Sam wrote:
> configure.log with -with-cc="win32fe cl --use clang"
> ________________________________
> From: Satish Balay <balay at mcs.anl.gov>
> Sent: Tuesday, January 24, 2023 5:15 PM
> Cc: Barry Smith <bsmith at petsc.dev>; petsc-users <petsc-users at mcs.anl.gov>
> Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-cc="win32fe cl" --use win32fe clang --with-fc=0
>  --with-debugging=0 -CFLAGS="-O2 -MD -wd4996" -CXXFLAGS="-O2 -MD -wd4996" --with-mpi=0 --with-clean=1 --force --with-scalar-type=real
>  --ignore-cygwin-link -CFLAGS="-O2 -MD -wd4996" -CXXFLAGS="-O2 -MD -wd4996"
> It should be --with-cc="win32fe cl --use clang"
> But then - this mode is untested with configure - so there could be other issues.
> Also - do you need c++? If not - use --with-cxx=0. This can avoid the error below. [for clang++ - you might need --with-cxx="win32fe cl --use clang++" - again untested - so might not work..]
> Satish
> On Tue, 24 Jan 2023, Guo, Sam wrote:
> > Attached please find configure.log.
> > error messgae:
> > C:\home\xian\dev\star\petsc\src\sys\objects\device\INTERF~1\device.cxx(486): error C2065: 'PETSC_DEVICE_CASE': undeclared identifier
> > Sent: Tuesday, January 24, 2023 2:00 PM
> > To: Barry Smith <bsmith at petsc.dev>
> > Cc: Guo, Sam (DI SW STS SDDEV MECH PHY FEA FW) <sam.guo at siemens.com>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> > https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.wikihow.com%2FInstall-Clang-on-Windows&data=05%7C01%7Csam.guo%40siemens.com%7C1ca3b3b2be7e4886974d08dafe749081%7C38ae3bcd95794fd4addab42e1495d55a%7C1%7C0%7C638102073862928368%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=6Qn3tRbky7pGr1qqSz2IBDsO2q8MJGis%2B57JEyzNSBk%3D&reserved=0
> > Is the clang you have from visual studio - as described above?
> > We don't have experience with using this variant of clang.
> > If its compatible with 'cl' - and supports the same command interface as 'cl' then the following might work [assuming clang.exe is the compiler binary installed - and available in PATH]:
> > '--with-cc=win32fe cl --use clang'
> > Satish
> > On Tue, 24 Jan 2023, Barry Smith wrote:
> > >    Are you using clang as a replacement for the
> > >    *  "Unix-like" Cygwin GNU compilers compilers or
> > >    *  MinGW GNU compilers that are compatible with the Microsoft compilers?
> > >   If the former, follow the instructions for using the Cygwin GNU compilers, if the latter follow the directions for the MinGW compilers.
> > >   Send the configure.log and make.log if things go wrong and we'll help you out.
> > >   Barry
> > > > On Jan 24, 2023, at 4:01 PM, Guo, Sam <sam.guo at siemens.com> wrote:
> > > > Hi PETSc dev team,
> > > >    I try to compile PETSc on win using clang. I am wondering if you could give me some hint. (I’ve already made intel compiler work on win using win32fe icl).
> > > > Thanks,
> > > > Sam Guo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230125/8cb91f8f/attachment-0001.html>
Type: text/x-log
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230125/8cb91f8f/attachment-0001.bin>
