[petsc-users] compile PETSc on win using clang
Barry Smith
bsmith at petsc.dev
Tue Jan 24 15:12:05 CST 2023
Are you using clang as a replacement for the
* "Unix-like" Cygwin GNU compilers compilers or
* MinGW GNU compilers that are compatible with the Microsoft compilers?
If the former, follow the instructions for using the Cygwin GNU compilers, if the latter follow the directions for the MinGW compilers.
Send the configure.log and make.log if things go wrong and we'll help you out.
Barry
> On Jan 24, 2023, at 4:01 PM, Guo, Sam <sam.guo at siemens.com> wrote:
> Hi PETSc dev team,
> I try to compile PETSc on win using clang. I am wondering if you could give me some hint. (I’ve already made intel compiler work on win using win32fe icl).
> Thanks,
> Sam Guo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230124/73483695/attachment.html>
