[petsc-users] [EXTERNAL] Re: Performance problem using COO interface
Fackler, Philip facklerpw at ornl.gov
Mon Jan 23 09:52:08 CST 2023
Thank you for looking into that.
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
Sent: Monday, January 23, 2023 10:34
To: Fackler, Philip <facklerpw at ornl.gov>
Cc: Zhang, Junchao <jczhang at mcs.anl.gov>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>; Blondel, Sophie <sblondel at utk.edu>; Roth, Philip <rothpc at ornl.gov>
Subject: [EXTERNAL] Re: [petsc-users] Performance problem using COO interface
Hi, Philip,
  It looks the performance of MatPtAP is pretty bad.  There are a lot of issues with PtAP, which I am going to address.
MatPtAPNumeric       181 1.0   nan nan 0.00e+00 0.0 3.3e+03 1.8e+04 0.0e+00 56  0  4 21  0  56  0  4 21  0  -nan     -nan      0 0.00e+00    0 0.00e+00  0
 Thanks.
--Junchao Zhang
On Fri, Jan 20, 2023 at 10:55 AM Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
The following is the log_view output for the ported case using 4 MPI tasks.
***                                WIDEN YOUR WINDOW TO 160 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document                                 ***
------------------------------------------------------------------ PETSc Performance Summary: ------------------------------------------------------------------
Unknown Name on a  named iguazu with 4 processors, by 4pf Fri Jan 20 11:53:04 2023
Using Petsc Release Version 3.18.3, unknown
                         Max       Max/Min     Avg       Total
Time (sec):           1.447e+01     1.000   1.447e+01
Objects:              1.229e+03     1.003   1.226e+03
Flops:                5.053e+09     1.217   4.593e+09  1.837e+10
Flops/sec:            3.492e+08     1.217   3.174e+08  1.269e+09
MPI Msg Count:        1.977e+04     1.067   1.895e+04  7.580e+04
MPI Msg Len (bytes):  7.374e+07     1.088   3.727e+03  2.825e+08
MPI Reductions:       2.065e+03     1.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
 0:      Main Stage: 1.4471e+01 100.0%  1.8371e+10 100.0%  7.580e+04 100.0%  3.727e+03      100.0%  2.046e+03  99.1%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flop: Max - maximum over all processors
                  Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   AvgLen: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flop in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
   GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU time over all processors)
   CpuToGpu Count: total number of CPU to GPU copies per processor
   CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per processor)
   GpuToCpu Count: total number of GPU to CPU copies per processor
   GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per processor)
   GPU %F: percent flops on GPU in this event
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
   GPU    - CpuToGpu -   - GpuToCpu - GPU
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
 Mflop/s Count   Size   Count   Size  %F
--- Event Stage 0: Main Stage
BuildTwoSided        257 1.0   nan nan 0.00e+00 0.0 4.4e+02 8.0e+00 2.6e+02  1  0  1  0 12   1  0  1  0 13  -nan
BuildTwoSidedF       210 1.0   nan nan 0.00e+00 0.0 1.5e+02 4.2e+04 2.1e+02  1  0  0  2 10   1  0  0  2 10  -nan
DMCreateMat            1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 7.0e+00 10  0  0  0  0  10  0  0  0  0  -nan
SFSetGraph            69 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SFSetUp               47 1.0   nan nan 0.00e+00 0.0 7.3e+02 2.1e+03 4.7e+01  0  0  1  1  2   0  0  1  1  2  -nan
SFBcastBegin         222 1.0   nan nan 0.00e+00 0.0 2.3e+03 1.9e+04 0.0e+00  0  0  3 16  0   0  0  3 16  0  -nan
SFBcastEnd           222 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0  -nan
SFReduceBegin        254 1.0   nan nan 0.00e+00 0.0 1.5e+03 1.2e+04 0.0e+00  0  0  2  6  0   0  0  2  6  0  -nan
SFReduceEnd          254 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0  -nan
SFFetchOpBegin         1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SFFetchOpEnd           1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SFPack              8091 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SFUnpack            8092 1.0   nan nan 4.78e+04 1.5 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecDot                60 1.0   nan nan 4.30e+06 1.2 0.0e+00 0.0e+00 6.0e+01  0  0  0  0  3   0  0  0  0  3  -nan
    -nan      0 0.00e+00    0 0.00e+00  100
VecMDot              398 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+02  0  0  0  0 19   0  0  0  0 19  -nan
VecNorm              641 1.0   nan nan 4.45e+07 1.2 0.0e+00 0.0e+00 6.4e+02  1  1  0  0 31   1  1  0  0 31  -nan
VecScale             601 1.0   nan nan 2.08e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecCopy             3735 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecSet              2818 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecAXPY              123 1.0   nan nan 8.68e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecAYPX             6764 1.0   nan nan 1.90e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   0  4  0  0  0  -nan
VecAXPBYCZ          2388 1.0   nan nan 1.83e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  4  0  0  0   0  4  0  0  0  -nan
VecWAXPY              60 1.0   nan nan 4.30e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecMAXPY             681 1.0   nan nan 1.36e+08 1.2 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0  -nan
VecAssemblyBegin       7 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecAssemblyEnd         7 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecPointwiseMult    4449 1.0   nan nan 6.06e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  -nan
VecScatterBegin     7614 1.0   nan nan 0.00e+00 0.0 7.1e+04 2.9e+03 1.3e+01  0  0 94 73  1   0  0 94 73  1  -nan
VecScatterEnd       7614 1.0   nan nan 4.78e+04 1.5 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0  -nan
VecReduceArith       120 1.0   nan nan 8.60e+06 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
VecReduceComm         60 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+01  0  0  0  0  3   0  0  0  0  3  -nan
VecNormalize         401 1.0   nan nan 4.09e+07 1.2 0.0e+00 0.0e+00 4.0e+02  0  1  0  0 19   0  1  0  0 20  -nan
TSStep                20 1.0 1.2908e+01 1.0 5.05e+09 1.2 7.6e+04 3.7e+03 2.0e+03 89 100 100 98 96  89 100 100 98 97  1423
    -nan      0 0.00e+00    0 0.00e+00  99
TSFunctionEval       140 1.0   nan nan 1.00e+07 1.2 1.1e+03 3.7e+04 0.0e+00  1  0  1 15  0   1  0  1 15  0  -nan
TSJacobianEval        60 1.0   nan nan 1.67e+07 1.2 4.8e+02 3.7e+04 6.0e+01  2  0  1  6  3   2  0  1  6  3  -nan
    -nan      0 0.00e+00    0 0.00e+00  87
MatMult             4934 1.0   nan nan 4.16e+09 1.2 5.1e+04 2.7e+03 4.0e+00 15 82 68 49  0  15 82 68 49  0  -nan
MatMultAdd          1104 1.0   nan nan 9.00e+07 1.2 8.8e+03 1.4e+02 0.0e+00  1  2 12  0  0   1  2 12  0  0  -nan
MatMultTranspose    1104 1.0   nan nan 9.01e+07 1.2 8.8e+03 1.4e+02 1.0e+00  1  2 12  0  0   1  2 12  0  0  -nan
MatSolve             368 0.0   nan nan 3.57e+04 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatSOR                60 1.0   nan nan 3.12e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  -nan
MatLUFactorSym         2 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatLUFactorNum         2 1.0   nan nan 4.24e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatConvert             8 1.0   nan nan 0.00e+00 0.0 8.0e+01 1.2e+03 4.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatScale              66 1.0   nan nan 1.48e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatResidual         1104 1.0   nan nan 1.01e+09 1.2 1.2e+04 2.9e+03 0.0e+00  4 20 16 12  0   4 20 16 12  0  -nan
MatAssemblyBegin     590 1.0   nan nan 0.00e+00 0.0 1.5e+02 4.2e+04 2.0e+02  1  0  0  2 10   1  0  0  2 10  -nan
MatAssemblyEnd       590 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+02  2  0  0  0  7   2  0  0  0  7  -nan
MatGetRowIJ            2 0.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatCreateSubMat      122 1.0   nan nan 0.00e+00 0.0 6.3e+01 1.8e+02 1.7e+02  2  0  0  0  8   2  0  0  0  8  -nan
MatGetOrdering         2 0.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatCoarsen             3 1.0   nan nan 0.00e+00 0.0 5.0e+02 1.3e+03 1.2e+02  0  0  1  0  6   0  0  1  0  6  -nan
MatZeroEntries        61 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatAXPY                6 1.0   nan nan 1.37e+06 1.2 0.0e+00 0.0e+00 1.8e+01  1  0  0  0  1   1  0  0  0  1  -nan
MatTranspose           6 1.0   nan nan 0.00e+00 0.0 2.2e+02 2.9e+04 4.8e+01  1  0  0  2  2   1  0  0  2  2  -nan
MatMatMultSym          4 1.0   nan nan 0.00e+00 0.0 2.2e+02 1.7e+03 2.8e+01  0  0  0  0  1   0  0  0  0  1  -nan
MatMatMultNum          4 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
MatPtAPSymbolic        5 1.0   nan nan 0.00e+00 0.0 6.2e+02 5.2e+03 4.4e+01  3  0  1  1  2   3  0  1  1  2  -nan
MatGetLocalMat       185 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0  -nan
MatSetPreallCOO        1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0  -nan
MatSetValuesCOO       60 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
KSPSetUp             483 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 2.2e+01  0  0  0  0  1   0  0  0  0  1  -nan
KSPSolve              60 1.0 1.1843e+01 1.0 4.91e+09 1.2 7.3e+04 2.9e+03 1.2e+03 82 97 97 75 60  82 97 97 75 60  1506
KSPGMRESOrthog       398 1.0   nan nan 7.97e+07 1.2 0.0e+00 0.0e+00 4.0e+02  1  2  0  0 19   1  2  0  0 19  -nan
SNESSolve             60 1.0 1.2842e+01 1.0 5.01e+09 1.2 7.5e+04 3.6e+03 2.0e+03 89 99 100 96 95  89 99 100 96 96  1419
SNESSetUp              1 1.0   nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
SNESFunctionEval     120 1.0   nan nan 3.01e+07 1.2 9.6e+02 3.7e+04 0.0e+00  1  1  1 13  0   1  1  1 13  0  -nan
SNESJacobianEval      60 1.0   nan nan 1.67e+07 1.2 4.8e+02 3.7e+04 6.0e+01  2  0  1  6  3   2  0  1  6  3  -nan
SNESLineSearch        60 1.0   nan nan 6.99e+07 1.2 9.6e+02 1.9e+04 2.4e+02  1  1  1  6 12   1  1  1  6 12  -nan
PCSetUp_GAMG+         60 1.0   nan nan 3.53e+07 1.2 5.2e+03 1.4e+04 4.3e+02 62  1  7 25 21  62  1  7 25 21  -nan
    -nan      0 0.00e+00    0 0.00e+00  96
 PCGAMGCreateG         3 1.0   nan nan 1.32e+06 1.2 2.2e+02 2.9e+04 4.2e+01  1  0  0  2  2   1  0  0  2  2  -nan
 GAMG Coarsen          3 1.0   nan nan 0.00e+00 0.0 5.0e+02 1.3e+03 1.2e+02  1  0  1  0  6   1  0  1  0  6  -nan
  GAMG MIS/Agg         3 1.0   nan nan 0.00e+00 0.0 5.0e+02 1.3e+03 1.2e+02  0  0  1  0  6   0  0  1  0  6  -nan
 PCGAMGProl            3 1.0   nan nan 0.00e+00 0.0 7.8e+01 7.8e+02 4.8e+01  0  0  0  0  2   0  0  0  0  2  -nan
  GAMG Prol-col        3 1.0   nan nan 0.00e+00 0.0 5.2e+01 5.8e+02 2.1e+01  0  0  0  0  1   0  0  0  0  1  -nan
  GAMG Prol-lift       3 1.0   nan nan 0.00e+00 0.0 2.6e+01 1.2e+03 1.5e+01  0  0  0  0  1   0  0  0  0  1  -nan
 PCGAMGOptProl         3 1.0   nan nan 3.40e+07 1.2 5.8e+02 2.4e+03 1.1e+02  1  1  1  0  6   1  1  1  0  6  -nan
  GAMG smooth          3 1.0   nan nan 2.85e+05 1.2 1.9e+02 1.9e+03 3.0e+01  0  0  0  0  1   0  0  0  0  1  -nan
    -nan      0 0.00e+00    0 0.00e+00  43
 PCGAMGCreateL         3 1.0   nan nan 0.00e+00 0.0 4.8e+02 6.5e+03 8.0e+01  3  0  1  1  4   3  0  1  1  4  -nan
  GAMG PtAP            3 1.0   nan nan 0.00e+00 0.0 4.5e+02 7.1e+03 2.7e+01  3  0  1  1  1   3  0  1  1  1  -nan
  GAMG Reduce          1 1.0   nan nan 0.00e+00 0.0 3.6e+01 3.7e+01 5.3e+01  0  0  0  0  3   0  0  0  0  3  -nan
PCGAMG Gal l00        60 1.0   nan nan 0.00e+00 0.0 1.1e+03 1.4e+04 9.0e+00 46  0  1  6  0  46  0  1  6  0  -nan
PCGAMG Opt l00         1 1.0   nan nan 0.00e+00 0.0 4.8e+01 1.7e+02 7.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
PCGAMG Gal l01        60 1.0   nan nan 0.00e+00 0.0 1.6e+03 2.9e+04 9.0e+00 13  0  2 16  0  13  0  2 16  0  -nan
PCGAMG Opt l01         1 1.0   nan nan 0.00e+00 0.0 7.2e+01 4.8e+03 7.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
PCGAMG Gal l02        60 1.0   nan nan 0.00e+00 0.0 1.1e+03 1.2e+03 1.7e+01  0  0  1  0  1   0  0  1  0  1  -nan
PCGAMG Opt l02         1 1.0   nan nan 0.00e+00 0.0 7.2e+01 2.2e+02 7.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
PCSetUp              182 1.0   nan nan 3.53e+07 1.2 5.3e+03 1.4e+04 7.7e+02 64  1  7 27 37  64  1  7 27 38  -nan
PCSetUpOnBlocks      368 1.0   nan nan 4.24e+02 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  -nan
PCApply               60 1.0   nan nan 4.85e+09 1.2 7.3e+04 2.9e+03 1.1e+03 81 96 96 75 54  81 96 96 75 54  -nan
KSPSolve_FS_0         60 1.0   nan nan 3.12e+07 1.2 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  -nan
KSPSolve_FS_1         60 1.0   nan nan 4.79e+09 1.2 7.2e+04 2.9e+03 1.1e+03 81 95 96 75 54  81 95 96 75 54  -nan
--- Event Stage 1: Unknown
Object Type          Creations   Destructions. Reports information only for process 0.
           Container    14             14
    Distributed Mesh     9              9
           Index Set   120            120
   IS L to G Mapping    10             10
   Star Forest Graph    87             87
     Discrete System     9              9
           Weak Form     9              9
              Vector   761            761
             TSAdapt     1              1
                  TS     1              1
                DMTS     1              1
                SNES     1              1
              DMSNES     3              3
      SNESLineSearch     1              1
       Krylov Solver    11             11
     DMKSP interface     1              1
              Matrix   171            171
      Matrix Coarsen     3              3
      Preconditioner    11             11
              Viewer     2              1
         PetscRandom     3              3
Average time to get PetscTime(): 3.82e-08
Average time for MPI_Barrier(): 2.2968e-06
Average time for zero size MPI_Send(): 3.371e-06
#PETSc Option Table entries:
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with 64 bit PetscInt
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 8
Configure options: PETSC_DIR=/home2/4pf/petsc PETSC_ARCH=arch-kokkos-serial --prefix=/home2/4pf/.local/serial --with-cc=mpicc --with-cxx=mpicxx --with-fc=0 --with-cudac=0 --with-cuda=0 --with-shared-libraries --with-64-bit-indices --with-debugging=0 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --with-kokkos-dir=/home2/4pf/.local/serial --with-kokkos-kernels-dir=/home2/4pf/.local/serial --download-f2cblaslapack
Libraries compiled on 2023-01-06 18:21:31 on iguazu
Machine characteristics: Linux-4.18.0-383.el8.x86_64-x86_64-with-glibc2.28
Using PETSc directory: /home2/4pf/.local/serial
Using PETSc arch:
Using C compiler: mpicc  -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector -fvisibility=hidden -O3
Using include paths: -I/home2/4pf/.local/serial/include
Using C linker: mpicc
Using libraries: -Wl,-rpath,/home2/4pf/.local/serial/lib -L/home2/4pf/.local/serial/lib -lpetsc -Wl,-rpath,/home2/4pf/.local/serial/lib64 -L/home2/4pf/.local/serial/lib64 -Wl,-rpath,/home2/4pf/.local/serial/lib -L/home2/4pf/.local/serial/lib -lkokkoskernels -lkokkoscontainers -lkokkoscore -lf2clapack -lf2cblas -lm -lX11 -lquadmath -lstdc++ -ldl
Philip Fackler
From: Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>>
Sent: Tuesday, January 17, 2023 17:25
To: Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>>; xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net> <xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Cc: Mills, Richard Tran <rtmills at anl.gov<mailto:rtmills at anl.gov>>; Blondel, Sophie <sblondel at utk.edu<mailto:sblondel at utk.edu>>; Roth, Philip <rothpc at ornl.gov<mailto:rothpc at ornl.gov>>
Subject: [EXTERNAL] Re: Performance problem using COO interface
Hi, Philip,
  Could you add -log_view and see what functions are used in the solve? Since it is CPU-only, perhaps with -log_view of different runs, we can easily see which functions slowed down.
--Junchao Zhang
From: Fackler, Philip <facklerpw at ornl.gov<mailto:facklerpw at ornl.gov>>
Sent: Tuesday, January 17, 2023 4:13 PM
To: xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net> <xolotl-psi-development at lists.sourceforge.net<mailto:xolotl-psi-development at lists.sourceforge.net>>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Cc: Mills, Richard Tran <rtmills at anl.gov<mailto:rtmills at anl.gov>>; Zhang, Junchao <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>>; Blondel, Sophie <sblondel at utk.edu<mailto:sblondel at utk.edu>>; Roth, Philip <rothpc at ornl.gov<mailto:rothpc at ornl.gov>>
Subject: Performance problem using COO interface
In Xolotl's feature-petsc-kokkos branch I have ported the code to use petsc's COO interface for creating the Jacobian matrix (and the Kokkos interface for interacting with Vec entries). As the attached plots show for one case, while the code for computing the RHSFunction and RHSJacobian perform similarly (or slightly better) after the port, the performance for the solve as a whole is significantly worse.
Note:
This is all CPU-only (so kokkos and kokkos-kernels are built with only the serial backend).
The dev version is using MatSetValuesStencil with the default implementations for Mat and Vec.
The port version is using MatSetValuesCOO and is run with -dm_mat_type aijkokkos -dm_vec_type kokkos​.
The port/def version is using MatSetValuesCOO and is run with -dm_vec_type kokkos​ (using the default Mat implementation).
So, this seems to be due be a performance difference in the petsc implementations. Please advise. Is this a known issue? Or am I missing something?
Thank you for the help,
Philip Fackler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230123/7970996c/attachment-0001.html>
