[petsc-users] Performance problem using COO interface
Fackler, Philip
facklerpw at ornl.gov
Fri Jan 20 10:55:28 CST 2023
The following is the log_view output for the ported case using 4 MPI tasks.
*** WIDEN YOUR WINDOW TO 160 CHARACTERS. Use 'enscript -r -fCourier9' to print this document ***
------------------------------------------------------------------ PETSc Performance Summary: ------------------------------------------------------------------
Unknown Name on a named iguazu with 4 processors, by 4pf Fri Jan 20 11:53:04 2023
Using Petsc Release Version 3.18.3, unknown
Max Max/Min Avg Total
Time (sec): 1.447e+01 1.000 1.447e+01
Objects: 1.229e+03 1.003 1.226e+03
Flops: 5.053e+09 1.217 4.593e+09 1.837e+10
Flops/sec: 3.492e+08 1.217 3.174e+08 1.269e+09
MPI Msg Count: 1.977e+04 1.067 1.895e+04 7.580e+04
MPI Msg Len (bytes): 7.374e+07 1.088 3.727e+03 2.825e+08
MPI Reductions: 2.065e+03 1.000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
e.g., VecAXPY() for real vectors of length N --> 2N flops
and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages --- -- Message Lengths -- -- Reductions --
Avg %Total Avg %Total Count %Total Avg %Total Count %Total
0: Main Stage: 1.4471e+01 100.0% 1.8371e+10 100.0% 7.580e+04 100.0% 3.727e+03 100.0% 2.046e+03 99.1%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
Count: number of times phase was executed
Time and Flop: Max - maximum over all processors
Ratio - ratio of maximum to minimum over all processors
Mess: number of messages sent
AvgLen: average message length (bytes)
Reduct: number of global reductions
Global: entire computation
Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
%T - percent time in this phase %F - percent flop in this phase
%M - percent messages in this phase %L - percent message lengths in this phase
%R - percent reductions in this phase
Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU time over all processors)
CpuToGpu Count: total number of CPU to GPU copies per processor
CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per processor)
GpuToCpu Count: total number of GPU to CPU copies per processor
GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per processor)
GPU %F: percent flops on GPU in this event
Event Count Time (sec) Flop --- Global --- --- Stage ---- Total
GPU - CpuToGpu - - GpuToCpu - GPU
Max Ratio Max Ratio Max Ratio Mess AvgLen Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s
Mflop/s Count Size Count Size %F
--- Event Stage 0: Main Stage
BuildTwoSided 257 1.0 nan nan 0.00e+00 0.0 4.4e+02 8.0e+00 2.6e+02 1 0 1 0 12 1 0 1 0 13 -nan
-nan 0 0.00e+00 0 0.00e+00 0
BuildTwoSidedF 210 1.0 nan nan 0.00e+00 0.0 1.5e+02 4.2e+04 2.1e+02 1 0 0 2 10 1 0 0 2 10 -nan
DMCreateMat 1 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 7.0e+00 10 0 0 0 0 10 0 0 0 0 -nan
SFSetGraph 69 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
SFSetUp 47 1.0 nan nan 0.00e+00 0.0 7.3e+02 2.1e+03 4.7e+01 0 0 1 1 2 0 0 1 1 2 -nan
SFBcastBegin 222 1.0 nan nan 0.00e+00 0.0 2.3e+03 1.9e+04 0.0e+00 0 0 3 16 0 0 0 3 16 0 -nan
SFBcastEnd 222 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 -nan
SFReduceBegin 254 1.0 nan nan 0.00e+00 0.0 1.5e+03 1.2e+04 0.0e+00 0 0 2 6 0 0 0 2 6 0 -nan
SFReduceEnd 254 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 -nan
SFFetchOpBegin 1 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
SFFetchOpEnd 1 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
SFPack 8091 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
SFUnpack 8092 1.0 nan nan 4.78e+04 1.5 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecDot 60 1.0 nan nan 4.30e+06 1.2 0.0e+00 0.0e+00 6.0e+01 0 0 0 0 3 0 0 0 0 3 -nan
-nan 0 0.00e+00 0 0.00e+00 100
VecMDot 398 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+02 0 0 0 0 19 0 0 0 0 19 -nan
VecNorm 641 1.0 nan nan 4.45e+07 1.2 0.0e+00 0.0e+00 6.4e+02 1 1 0 0 31 1 1 0 0 31 -nan
VecScale 601 1.0 nan nan 2.08e+07 1.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecCopy 3735 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecSet 2818 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecAXPY 123 1.0 nan nan 8.68e+06 1.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecAYPX 6764 1.0 nan nan 1.90e+08 1.2 0.0e+00 0.0e+00 0.0e+00 0 4 0 0 0 0 4 0 0 0 -nan
VecAXPBYCZ 2388 1.0 nan nan 1.83e+08 1.2 0.0e+00 0.0e+00 0.0e+00 0 4 0 0 0 0 4 0 0 0 -nan
VecWAXPY 60 1.0 nan nan 4.30e+06 1.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecMAXPY 681 1.0 nan nan 1.36e+08 1.2 0.0e+00 0.0e+00 0.0e+00 0 3 0 0 0 0 3 0 0 0 -nan
VecAssemblyBegin 7 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecAssemblyEnd 7 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecPointwiseMult 4449 1.0 nan nan 6.06e+07 1.2 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 -nan
VecScatterBegin 7614 1.0 nan nan 0.00e+00 0.0 7.1e+04 2.9e+03 1.3e+01 0 0 94 73 1 0 0 94 73 1 -nan
VecScatterEnd 7614 1.0 nan nan 4.78e+04 1.5 0.0e+00 0.0e+00 0.0e+00 3 0 0 0 0 3 0 0 0 0 -nan
VecReduceArith 120 1.0 nan nan 8.60e+06 1.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
VecReduceComm 60 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+01 0 0 0 0 3 0 0 0 0 3 -nan
VecNormalize 401 1.0 nan nan 4.09e+07 1.2 0.0e+00 0.0e+00 4.0e+02 0 1 0 0 19 0 1 0 0 20 -nan
TSStep 20 1.0 1.2908e+01 1.0 5.05e+09 1.2 7.6e+04 3.7e+03 2.0e+03 89 100 100 98 96 89 100 100 98 97 1423
-nan 0 0.00e+00 0 0.00e+00 99
TSFunctionEval 140 1.0 nan nan 1.00e+07 1.2 1.1e+03 3.7e+04 0.0e+00 1 0 1 15 0 1 0 1 15 0 -nan
TSJacobianEval 60 1.0 nan nan 1.67e+07 1.2 4.8e+02 3.7e+04 6.0e+01 2 0 1 6 3 2 0 1 6 3 -nan
-nan 0 0.00e+00 0 0.00e+00 87
MatMult 4934 1.0 nan nan 4.16e+09 1.2 5.1e+04 2.7e+03 4.0e+00 15 82 68 49 0 15 82 68 49 0 -nan
MatMultAdd 1104 1.0 nan nan 9.00e+07 1.2 8.8e+03 1.4e+02 0.0e+00 1 2 12 0 0 1 2 12 0 0 -nan
MatMultTranspose 1104 1.0 nan nan 9.01e+07 1.2 8.8e+03 1.4e+02 1.0e+00 1 2 12 0 0 1 2 12 0 0 -nan
MatSolve 368 0.0 nan nan 3.57e+04 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatSOR 60 1.0 nan nan 3.12e+07 1.2 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 -nan
MatLUFactorSym 2 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatLUFactorNum 2 1.0 nan nan 4.24e+02 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatConvert 8 1.0 nan nan 0.00e+00 0.0 8.0e+01 1.2e+03 4.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatScale 66 1.0 nan nan 1.48e+07 1.2 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatResidual 1104 1.0 nan nan 1.01e+09 1.2 1.2e+04 2.9e+03 0.0e+00 4 20 16 12 0 4 20 16 12 0 -nan
MatAssemblyBegin 590 1.0 nan nan 0.00e+00 0.0 1.5e+02 4.2e+04 2.0e+02 1 0 0 2 10 1 0 0 2 10 -nan
MatAssemblyEnd 590 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+02 2 0 0 0 7 2 0 0 0 7 -nan
MatGetRowIJ 2 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatCreateSubMat 122 1.0 nan nan 0.00e+00 0.0 6.3e+01 1.8e+02 1.7e+02 2 0 0 0 8 2 0 0 0 8 -nan
MatGetOrdering 2 0.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatCoarsen 3 1.0 nan nan 0.00e+00 0.0 5.0e+02 1.3e+03 1.2e+02 0 0 1 0 6 0 0 1 0 6 -nan
MatZeroEntries 61 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatAXPY 6 1.0 nan nan 1.37e+06 1.2 0.0e+00 0.0e+00 1.8e+01 1 0 0 0 1 1 0 0 0 1 -nan
MatTranspose 6 1.0 nan nan 0.00e+00 0.0 2.2e+02 2.9e+04 4.8e+01 1 0 0 2 2 1 0 0 2 2 -nan
MatMatMultSym 4 1.0 nan nan 0.00e+00 0.0 2.2e+02 1.7e+03 2.8e+01 0 0 0 0 1 0 0 0 0 1 -nan
MatMatMultNum 4 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
MatPtAPSymbolic 5 1.0 nan nan 0.00e+00 0.0 6.2e+02 5.2e+03 4.4e+01 3 0 1 1 2 3 0 1 1 2 -nan
MatPtAPNumeric 181 1.0 nan nan 0.00e+00 0.0 3.3e+03 1.8e+04 0.0e+00 56 0 4 21 0 56 0 4 21 0 -nan
MatGetLocalMat 185 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 -nan
MatSetPreallCOO 1 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01 0 0 0 0 0 0 0 0 0 0 -nan
MatSetValuesCOO 60 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
KSPSetUp 483 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 2.2e+01 0 0 0 0 1 0 0 0 0 1 -nan
KSPSolve 60 1.0 1.1843e+01 1.0 4.91e+09 1.2 7.3e+04 2.9e+03 1.2e+03 82 97 97 75 60 82 97 97 75 60 1506
KSPGMRESOrthog 398 1.0 nan nan 7.97e+07 1.2 0.0e+00 0.0e+00 4.0e+02 1 2 0 0 19 1 2 0 0 19 -nan
SNESSolve 60 1.0 1.2842e+01 1.0 5.01e+09 1.2 7.5e+04 3.6e+03 2.0e+03 89 99 100 96 95 89 99 100 96 96 1419
SNESSetUp 1 1.0 nan nan 0.00e+00 0.0 0.0e+00 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
SNESFunctionEval 120 1.0 nan nan 3.01e+07 1.2 9.6e+02 3.7e+04 0.0e+00 1 1 1 13 0 1 1 1 13 0 -nan
SNESJacobianEval 60 1.0 nan nan 1.67e+07 1.2 4.8e+02 3.7e+04 6.0e+01 2 0 1 6 3 2 0 1 6 3 -nan
SNESLineSearch 60 1.0 nan nan 6.99e+07 1.2 9.6e+02 1.9e+04 2.4e+02 1 1 1 6 12 1 1 1 6 12 -nan
PCSetUp_GAMG+ 60 1.0 nan nan 3.53e+07 1.2 5.2e+03 1.4e+04 4.3e+02 62 1 7 25 21 62 1 7 25 21 -nan
-nan 0 0.00e+00 0 0.00e+00 96
PCGAMGCreateG 3 1.0 nan nan 1.32e+06 1.2 2.2e+02 2.9e+04 4.2e+01 1 0 0 2 2 1 0 0 2 2 -nan
GAMG Coarsen 3 1.0 nan nan 0.00e+00 0.0 5.0e+02 1.3e+03 1.2e+02 1 0 1 0 6 1 0 1 0 6 -nan
GAMG MIS/Agg 3 1.0 nan nan 0.00e+00 0.0 5.0e+02 1.3e+03 1.2e+02 0 0 1 0 6 0 0 1 0 6 -nan
PCGAMGProl 3 1.0 nan nan 0.00e+00 0.0 7.8e+01 7.8e+02 4.8e+01 0 0 0 0 2 0 0 0 0 2 -nan
GAMG Prol-col 3 1.0 nan nan 0.00e+00 0.0 5.2e+01 5.8e+02 2.1e+01 0 0 0 0 1 0 0 0 0 1 -nan
GAMG Prol-lift 3 1.0 nan nan 0.00e+00 0.0 2.6e+01 1.2e+03 1.5e+01 0 0 0 0 1 0 0 0 0 1 -nan
PCGAMGOptProl 3 1.0 nan nan 3.40e+07 1.2 5.8e+02 2.4e+03 1.1e+02 1 1 1 0 6 1 1 1 0 6 -nan
GAMG smooth 3 1.0 nan nan 2.85e+05 1.2 1.9e+02 1.9e+03 3.0e+01 0 0 0 0 1 0 0 0 0 1 -nan
-nan 0 0.00e+00 0 0.00e+00 43
PCGAMGCreateL 3 1.0 nan nan 0.00e+00 0.0 4.8e+02 6.5e+03 8.0e+01 3 0 1 1 4 3 0 1 1 4 -nan
GAMG PtAP 3 1.0 nan nan 0.00e+00 0.0 4.5e+02 7.1e+03 2.7e+01 3 0 1 1 1 3 0 1 1 1 -nan
GAMG Reduce 1 1.0 nan nan 0.00e+00 0.0 3.6e+01 3.7e+01 5.3e+01 0 0 0 0 3 0 0 0 0 3 -nan
PCGAMG Gal l00 60 1.0 nan nan 0.00e+00 0.0 1.1e+03 1.4e+04 9.0e+00 46 0 1 6 0 46 0 1 6 0 -nan
PCGAMG Opt l00 1 1.0 nan nan 0.00e+00 0.0 4.8e+01 1.7e+02 7.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
PCGAMG Gal l01 60 1.0 nan nan 0.00e+00 0.0 1.6e+03 2.9e+04 9.0e+00 13 0 2 16 0 13 0 2 16 0 -nan
PCGAMG Opt l01 1 1.0 nan nan 0.00e+00 0.0 7.2e+01 4.8e+03 7.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
PCGAMG Gal l02 60 1.0 nan nan 0.00e+00 0.0 1.1e+03 1.2e+03 1.7e+01 0 0 1 0 1 0 0 1 0 1 -nan
PCGAMG Opt l02 1 1.0 nan nan 0.00e+00 0.0 7.2e+01 2.2e+02 7.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
PCSetUp 182 1.0 nan nan 3.53e+07 1.2 5.3e+03 1.4e+04 7.7e+02 64 1 7 27 37 64 1 7 27 38 -nan
PCSetUpOnBlocks 368 1.0 nan nan 4.24e+02 0.0 0.0e+00 0.0e+00 0.0e+00 0 0 0 0 0 0 0 0 0 0 -nan
PCApply 60 1.0 nan nan 4.85e+09 1.2 7.3e+04 2.9e+03 1.1e+03 81 96 96 75 54 81 96 96 75 54 -nan
KSPSolve_FS_0 60 1.0 nan nan 3.12e+07 1.2 0.0e+00 0.0e+00 0.0e+00 0 1 0 0 0 0 1 0 0 0 -nan
KSPSolve_FS_1 60 1.0 nan nan 4.79e+09 1.2 7.2e+04 2.9e+03 1.1e+03 81 95 96 75 54 81 95 96 75 54 -nan
--- Event Stage 1: Unknown
Object Type Creations Destructions. Reports information only for process 0.
Container 14 14
Distributed Mesh 9 9
Index Set 120 120
IS L to G Mapping 10 10
Star Forest Graph 87 87
Discrete System 9 9
Weak Form 9 9
Vector 761 761
TSAdapt 1 1
TS 1 1
DMTS 1 1
SNES 1 1
DMSNES 3 3
SNESLineSearch 1 1
Krylov Solver 11 11
DMKSP interface 1 1
Matrix 171 171
Matrix Coarsen 3 3
Preconditioner 11 11
Viewer 2 1
PetscRandom 3 3
Average time to get PetscTime(): 3.82e-08
Average time for MPI_Barrier(): 2.2968e-06
Average time for zero size MPI_Send(): 3.371e-06
#PETSc Option Table entries:
-log_view
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with 64 bit PetscInt
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 8
Configure options: PETSC_DIR=/home2/4pf/petsc PETSC_ARCH=arch-kokkos-serial --prefix=/home2/4pf/.local/serial --with-cc=mpicc --with-cxx=mpicxx --with-fc=0 --with-cudac=0 --with-cuda=0 --with-shared-libraries --with-64-bit-indices --with-debugging=0 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --with-kokkos-dir=/home2/4pf/.local/serial --with-kokkos-kernels-dir=/home2/4pf/.local/serial --download-f2cblaslapack
Libraries compiled on 2023-01-06 18:21:31 on iguazu
Machine characteristics: Linux-4.18.0-383.el8.x86_64-x86_64-with-glibc2.28
Using PETSc directory: /home2/4pf/.local/serial
Using PETSc arch:
Using C compiler: mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wno-lto-type-mismatch -fstack-protector -fvisibility=hidden -O3
Using include paths: -I/home2/4pf/.local/serial/include
Using C linker: mpicc
Using libraries: -Wl,-rpath,/home2/4pf/.local/serial/lib -L/home2/4pf/.local/serial/lib -lpetsc -Wl,-rpath,/home2/4pf/.local/serial/lib64 -L/home2/4pf/.local/serial/lib64 -Wl,-rpath,/home2/4pf/.local/serial/lib -L/home2/4pf/.local/serial/lib -lkokkoskernels -lkokkoscontainers -lkokkoscore -lf2clapack -lf2cblas -lm -lX11 -lquadmath -lstdc++ -ldl
Philip Fackler
Research Software Engineer, Application Engineering Group
Advanced Computing Systems Research Section
Computer Science and Mathematics Division
Oak Ridge National Laboratory
Sent: Tuesday, January 17, 2023 17:25
To: Fackler, Philip <facklerpw at ornl.gov>; xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Cc: Mills, Richard Tran <rtmills at anl.gov>; Blondel, Sophie <sblondel at utk.edu>; Roth, Philip <rothpc at ornl.gov>
Subject: [EXTERNAL] Re: Performance problem using COO interface
Hi, Philip,
Could you add -log_view and see what functions are used in the solve? Since it is CPU-only, perhaps with -log_view of different runs, we can easily see which functions slowed down.
--Junchao Zhang
Sent: Tuesday, January 17, 2023 4:13 PM
To: xolotl-psi-development at lists.sourceforge.net <xolotl-psi-development at lists.sourceforge.net>; petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Cc: Mills, Richard Tran <rtmills at anl.gov>; Zhang, Junchao <jczhang at mcs.anl.gov>; Blondel, Sophie <sblondel at utk.edu>; Roth, Philip <rothpc at ornl.gov>
Subject: Performance problem using COO interface
In Xolotl's feature-petsc-kokkos branch I have ported the code to use petsc's COO interface for creating the Jacobian matrix (and the Kokkos interface for interacting with Vec entries). As the attached plots show for one case, while the code for computing the RHSFunction and RHSJacobian perform similarly (or slightly better) after the port, the performance for the solve as a whole is significantly worse.
Note:
This is all CPU-only (so kokkos and kokkos-kernels are built with only the serial backend).
The dev version is using MatSetValuesStencil with the default implementations for Mat and Vec.
The port version is using MatSetValuesCOO and is run with -dm_mat_type aijkokkos -dm_vec_type kokkos.
The port/def version is using MatSetValuesCOO and is run with -dm_vec_type kokkos (using the default Mat implementation).
So, this seems to be due be a performance difference in the petsc implementations. Please advise. Is this a known issue? Or am I missing something?
Thank you for the help,
Philip Fackler
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230120/532b0b6f/attachment-0001.html>
