[petsc-users] Cmake problem on an old cluster
Danyang Su
danyang.su at gmail.com
Thu Jan 19 12:46:03 CST 2023
Hi All,
I am trying to install the latest PETSc on an old cluster but always get
some error information at the step of cmake. The system installed cmake
is V3.2.3, which is out-of-date for PETSc. I tried to use
--download-cmake first, it does not work. Then I tried to clean
everything (delete the petsc_arch folder), download the latest cmake
myself and pass the path to the configuration, the error is still there.
The compiler there is a bit old, intel-14.0.2 and openmpi-1.6.5. I have
no problem to install PETSc-3.13.6 there. The latest version cannot pass
configuration, unfortunately. Attached is the last configuration I have
tried.
--with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
--download-cmake=/home/danyangs/soft/petsc/petsc-3.18.3/packages/cmake-3.25.1.tar.gz
--download-mumps --download-scalapack --download-parmetis
--download-metis --download-ptscotch --download-fblaslapack
--download-hypre --download-superlu_dist --download-hdf5=yes
--with-hdf5-fortran-bindings --with-debugging=0 COPTFLAGS="-O2
-march=native -mtune=native" CXXOPTFLAGS="-O2 -march=native
-mtune=native" FOPTFLAGS="-O2 -march=native -mtune=native"
Is there any solution for this.
Danyang
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230119/26ef3cc8/attachment-0001.bin>
