[petsc-users] Nonconforming object sizes using TAO (TAOBNTR)
Alexis Marboeuf alexis.marboeuf at hotmail.fr
Mon Jan 16 14:14:54 CST 2023
Hi Matt,
After investigation, it fails because, at some point, the boolean needH is set to PETSC_FALSE when initializing the BNK method with TAOBNKInitialize (line 103 of $PETSC_DIR/src/tao/bound/impls/bnk/bntr.c). The Hessian and the precondtitioner are thus not updated throughout the TAO iterations. It has something to do with the option BNK_INIT_INTERPOLATION set by default. It works when I choose BNK_INIT_CONSTANT. In my case, in all the successful calls of TAOSolve, the computed trial objective value is better than the current value which implies needH = PETSC_TRUE within TAOBNKInitialize. At some point, the trial value becomes equal to the current objective value up to machine precision and then, needH = PETSC_FALSE. I have to admit I am struggling understanding how that boolean needH is computed when BNK is initialized with BNK_INIT_INTERPOLATION. Can you help me with that?
Thanks a lot.
Alexis
De : Alexis Marboeuf <alexis.marboeuf at hotmail.fr>
Envoyé : samedi 14 janvier 2023 05:24
À : Matthew Knepley <knepley at gmail.com>
Cc : petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : RE: [petsc-users] Nonconforming object sizes using TAO (TAOBNTR)
Hi Matt,
Indeed, it fails on 1 process with the same error. The source code is available here: https://github.com/bourdin/mef90 (branch marboeuf/vdef-tao-test)
[https://opengraph.githubassets.com/8f51eb183957c4e2f2dd59e2733f43a7bc667a50d4aaad934ebb3ac8f25a17ab/bourdin/mef90]<https://github.com/bourdin/mef90>
GitHub - bourdin/mef90: Official repository for mef90/vDef<https://github.com/bourdin/mef90>
mef90 / vDef: A reference implementation of the variational approach to fracture, as described in: Francfort, G. and Marigo, J.-J. (1998). Revisiting brittle fracture as an energy minimization problem.
github.com
I can share the details (installation + command line) for running it. But the ideal would be to reproduce this error with a Petsc example so it's easier for you to investigate. I looked for a bound constraint minimization problem with TAO and TS but I didn't find it. What example could I use?
Thanks!
Alexis
De : Matthew Knepley <knepley at gmail.com>
Envoyé : samedi 14 janvier 2023 02:38
À : Alexis Marboeuf <alexis.marboeuf at hotmail.fr>
Objet : Re: [petsc-users] Nonconforming object sizes using TAO (TAOBNTR)
On Fri, Jan 13, 2023 at 3:21 PM Alexis Marboeuf <alexis.marboeuf at hotmail.fr<mailto:alexis.marboeuf at hotmail.fr>> wrote:
Hi Matt,
Here is the output from Petsc when I view the TAO solver:
Okay, there is no sophisticated caching going on. So, first I would get it to fail on1 process. It should if it just depends on
the convergence (I hope). Then send the source so we can run it. It should be simple for us to find where system size
changes and the KSP is not reset (if that indeed is what happens).
    Matt
Tao Object: (Damage_) 4 MPI processes
  type: bntr
    Tao Object: (Damage_tao_bnk_cg_) 4 MPI processes
      type: bncg
        CG Type: ssml_bfgs
        Skipped Stepdirection Updates: 0
        Scaled gradient steps: 0
        Pure gradient steps: 0
        Not a descent direction: 0
        Line search fails: 0
        Matrix has not been preallocated yet
      TaoLineSearch Object: (Damage_tao_bnk_cg_) 4 MPI processes
        type: more-thuente
        maximum function evaluations=30
        tolerances: ftol=0.0001, rtol=1e-10, gtol=0.9
        total number of function evaluations=0
        total number of gradient evaluations=0
        total number of function/gradient evaluations=0
        Termination reason: 0
      Active Set subset type: subvec
      convergence tolerances: gatol=1e-08,       steptol=0.,       gttol=0.
      Residual in Function/Gradient:=0.
      Objective value=0.
      total number of iterations=0,                              (max: 2000)
      Solver terminated: 0
    Rejected BFGS updates: 0
    CG steps: 0
    Newton steps: 11
    BFGS steps: 0
    Gradient steps: 0
    KSP termination reasons:
      atol: 4
      rtol: 0
      ctol: 7
      negc: 0
      dtol: 0
      iter: 0
      othr: 0
  TaoLineSearch Object: (Damage_) 4 MPI processes
    type: more-thuente
    using variable bounds
  KSP Object: (Damage_tao_bnk_) 4 MPI processes
    type: stcg
    maximum iterations=10000, nonzero initial guess
    tolerances:  relative=1e-08, absolute=1e-08, divergence=1e+10
    left preconditioning
    using UNPRECONDITIONED norm type for convergence test
  PC Object: (Damage_tao_bnk_) 4 MPI processes
    type: lmvm
    Mat Object: (Damage_tao_bnk_pc_lmvm_) 4 MPI processes
      type: lmvmbfgs
      rows=30634, cols=30634
        Scale type: DIAGONAL
        Scale history: 1
        Scale params: alpha=1., beta=0.5, rho=1.
        Convex factors: phi=0., theta=0.125
        Max. storage: 5
        Used storage: 5
        Number of updates: 11
        Number of rejects: 0
        Number of resets: 0
        Mat Object: (Damage_tao_bnk_pc_lmvm_J0_) 4 MPI processes
          type: lmvmdiagbroyden
            Scale history: 1
            Convex factor: theta=0.125
            Max. storage: 1
            Used storage: 1
            Number of resets: 0
    linear system matrix = precond matrix:
    Mat Object: 4 MPI processes
      type: mpiaij
      rows=468, cols=468
      total: nonzeros=2932, allocated nonzeros=2932
      total number of mallocs used during MatSetValues calls=0
        not using I-node (on process 0) routines
  total KSP iterations: 103
  convergence tolerances: gatol=0.0001,   steptol=0.,   gttol=1e-05
  Residual in Function/Gradient:=9.11153e-05
  Objective value=0.00665458
  total number of iterations=11,                          (max: 50)
  total number of function evaluations=17,                  max: -1
  total number of gradient evaluations=13,                  max: -1
  total number of Hessian evaluations=12
  Solution converged:    ||g(X)|| <= gatol
Thanks again for your help!
Alexis
De : Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Envoyé : samedi 14 janvier 2023 01:38
À : Alexis Marboeuf <alexis.marboeuf at hotmail.fr<mailto:alexis.marboeuf at hotmail.fr>>
Cc : petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Fri, Jan 13, 2023 at 11:22 AM Alexis Marboeuf <alexis.marboeuf at hotmail.fr<mailto:alexis.marboeuf at hotmail.fr>> wrote:
Hi all,
In a variational approach of brittle fracture setting, I try to solve a bound constraint minimization problem using TAO. I checkout on the main branch of Petsc. Minimization with respect to the bounded variable (damage) is achieved through the Bounded Newton Trust Region (TAOBNTR). All other TAO parameters are set by default. On a Linux machine, I get the following error with a 4 processors run:
Can you view the solver?
    Matt
[3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Nonconforming object sizes
[3]PETSC ERROR: Preconditioner number of local rows 1122 does not equal input vector size 1161
[3]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[3]PETSC ERROR: Petsc Development GIT revision: v3.18.3-342-gdab44c92d91  GIT Date: 2023-01-04 13:37:04 +0000
[3]PETSC ERROR: /home/marboeua/Developpement/mef90/arch-darwin-c/bin/vDefTAO on a arch-darwin-c named bb01 by marboeua Thu Jan 12 16:55:18 2023
[2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Configure options --FFLAGS=-ffree-line-length-none --COPTFLAGS="-O3 -march=znver3 -g" --CXXOPTFLAGS="-O3 -march=znver3 -g" --FOPTFLAGS="-O3 -march=znver3 -g" --download-fblaslapack=1 --download-mumps=1 --download-chaco=1 --download-exodusii=1 --download-hypre=1 --download-ml=1 --download-triangle --download-scalapack=1 --download-superlu=1 --download-sowing=1 --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++ --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-yaml=1 --download-bison=1 --download-hdf5=1 --download-metis=1 --download-parmetis=1 --download-netcdf=1 --download-pnetcdf=1 --download-zlib=1 --with-cmake=1 --with-debugging=0 --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-ranlib=ranlib --with-shared-libraries=1 --with-sieve=1 --download-p4est=1 --with-pic --with-mpiexec=srun --with-x11=0 PETSC_ARCH=arch-darwin-c
[3]PETSC ERROR: #1 PCApply() at /1/home/marboeua/Developpement/petsc/src/ksp/pc/interface/precon.c:434
[3]PETSC ERROR: #2 KSP_PCApply() at /home/marboeua/Developpement/petsc/include/petsc/private/kspimpl.h:380
[3]PETSC ERROR: #3 KSPCGSolve_STCG() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c:76
[3]PETSC ERROR: #4 KSPSolve_Private() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:898
[3]PETSC ERROR: #5 KSPSolve() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:1070
[3]PETSC ERROR: #6 TaoBNKComputeStep() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bnk.c:459
[3]PETSC ERROR: #7 TaoSolve_BNTR() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bntr.c:138
[3]PETSC ERROR: #8 TaoSolve() at /1/home/marboeua/Developpement/petsc/src/tao/interface/taosolver.c:177
[2]PETSC ERROR: Nonconforming object sizes
[2]PETSC ERROR: Preconditioner number of local rows 1229 does not equal input vector size 1254
[2]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[2]PETSC ERROR: Petsc Development GIT revision: v3.18.3-342-gdab44c92d91  GIT Date: 2023-01-04 13:37:04 +0000
[2]PETSC ERROR: /home/marboeua/Developpement/mef90/arch-darwin-c/bin/vDefTAO on a arch-darwin-c named bb01 by marboeua Thu Jan 12 16:55:18 2023
[2]PETSC ERROR: Configure options --FFLAGS=-ffree-line-length-none --COPTFLAGS="-O3 -march=znver3 -g" --CXXOPTFLAGS="-O3 -march=znver3 -g" --FOPTFLAGS="-O3 -march=znver3 -g" --download-fblaslapack=1 --download-mumps=1 --download-chaco=1 --download-exodusii=1 --download-hypre=1 --download-ml=1 --download-triangle --download-scalapack=1 --download-superlu=1 --download-sowing=1 --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++ --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-yaml=1 --download-bison=1 --download-hdf5=1 --download-metis=1 --download-parmetis=1 --download-netcdf=1 --download-pnetcdf=1 --download-zlib=1 --with-cmake=1 --with-debugging=0 --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-ranlib=ranlib --with-shared-libraries=1 --with-sieve=1 --download-p4est=1 --with-pic --with-mpiexec=srun --with-x11=0 PETSC_ARCH=arch-darwin-c
[2]PETSC ERROR: #1 PCApply() at /1/home/marboeua/Developpement/petsc/src/ksp/pc/interface/precon.c:434
[2]PETSC ERROR: #2 KSP_PCApply() at /home/marboeua/Developpement/petsc/include/petsc/private/kspimpl.h:380
[2]PETSC ERROR: #3 KSPCGSolve_STCG() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c:76
[2]PETSC ERROR: #4 KSPSolve_Private() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:898
[2]PETSC ERROR: #5 KSPSolve() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:1070
[2]PETSC ERROR: #6 TaoBNKComputeStep() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bnk.c:459
[2]PETSC ERROR: #7 TaoSolve_BNTR() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bntr.c:138
[2]PETSC ERROR: #8 TaoSolve() at /1/home/marboeua/Developpement/petsc/src/tao/interface/taosolver.c:177
[3]PETSC ERROR: #9 /home/marboeua/Developpement/mef90/vDef/vDefTAO.F90:370
application called MPI_Abort(MPI_COMM_SELF, 60) - process 0
[2]PETSC ERROR: #9 /home/marboeua/Developpement/mef90/vDef/vDefTAO.F90:370
slurmstepd: error: *** STEP 5034.0 ON bb01 CANCELLED AT 2023-01-12T17:21:07 ***
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
srun: error: bb01: tasks 0-1: Killed
srun: error: bb01: tasks 2-3: Exited with exit code 1
The error is raised in the middle of the computation after many successful calls of TAOSolve and TAO iterations. My guess is that TAO computes the preconditioner during its first iteration with all variables in the active set. But the preconditioner is never updated when some variables are moved to the inactive set during the next TAO iterations. Am I right? Can you help me with that?
Thanks a lot for your help and your time.
Alexis
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230116/2c8974fa/attachment-0001.html>
