[petsc-users] Nonconforming object sizes using TAO (TAOBNTR)
Alexis Marboeuf
alexis.marboeuf at hotmail.fr
Fri Jan 13 19:21:10 CST 2023
Hi Matt,
Here is the output from Petsc when I view the TAO solver:
Tao Object: (Damage_) 4 MPI processes
type: bntr
Tao Object: (Damage_tao_bnk_cg_) 4 MPI processes
type: bncg
CG Type: ssml_bfgs
Skipped Stepdirection Updates: 0
Scaled gradient steps: 0
Pure gradient steps: 0
Not a descent direction: 0
Line search fails: 0
Matrix has not been preallocated yet
TaoLineSearch Object: (Damage_tao_bnk_cg_) 4 MPI processes
type: more-thuente
maximum function evaluations=30
tolerances: ftol=0.0001, rtol=1e-10, gtol=0.9
total number of function evaluations=0
total number of gradient evaluations=0
total number of function/gradient evaluations=0
Termination reason: 0
Active Set subset type: subvec
convergence tolerances: gatol=1e-08, steptol=0., gttol=0.
Residual in Function/Gradient:=0.
Objective value=0.
total number of iterations=0, (max: 2000)
Solver terminated: 0
Rejected BFGS updates: 0
CG steps: 0
Newton steps: 11
BFGS steps: 0
Gradient steps: 0
KSP termination reasons:
atol: 4
rtol: 0
ctol: 7
negc: 0
dtol: 0
iter: 0
othr: 0
TaoLineSearch Object: (Damage_) 4 MPI processes
type: more-thuente
using variable bounds
KSP Object: (Damage_tao_bnk_) 4 MPI processes
type: stcg
maximum iterations=10000, nonzero initial guess
tolerances: relative=1e-08, absolute=1e-08, divergence=1e+10
left preconditioning
using UNPRECONDITIONED norm type for convergence test
PC Object: (Damage_tao_bnk_) 4 MPI processes
type: lmvm
Mat Object: (Damage_tao_bnk_pc_lmvm_) 4 MPI processes
type: lmvmbfgs
rows=30634, cols=30634
Scale type: DIAGONAL
Scale history: 1
Scale params: alpha=1., beta=0.5, rho=1.
Convex factors: phi=0., theta=0.125
Max. storage: 5
Used storage: 5
Number of updates: 11
Number of rejects: 0
Number of resets: 0
Mat Object: (Damage_tao_bnk_pc_lmvm_J0_) 4 MPI processes
type: lmvmdiagbroyden
Scale history: 1
Convex factor: theta=0.125
Max. storage: 1
Used storage: 1
Number of resets: 0
linear system matrix = precond matrix:
Mat Object: 4 MPI processes
type: mpiaij
rows=468, cols=468
total: nonzeros=2932, allocated nonzeros=2932
total number of mallocs used during MatSetValues calls=0
not using I-node (on process 0) routines
total KSP iterations: 103
convergence tolerances: gatol=0.0001, steptol=0., gttol=1e-05
Residual in Function/Gradient:=9.11153e-05
Objective value=0.00665458
total number of iterations=11, (max: 50)
total number of function evaluations=17, max: -1
total number of gradient evaluations=13, max: -1
total number of Hessian evaluations=12
Solution converged: ||g(X)|| <= gatol
Thanks again for your help!
Alexis
De : Matthew Knepley <knepley at gmail.com>
Envoyé : samedi 14 janvier 2023 01:38
À : Alexis Marboeuf <alexis.marboeuf at hotmail.fr>
Cc : petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-users] Nonconforming object sizes using TAO (TAOBNTR)
On Fri, Jan 13, 2023 at 11:22 AM Alexis Marboeuf <alexis.marboeuf at hotmail.fr<mailto:alexis.marboeuf at hotmail.fr>> wrote:
Hi all,
In a variational approach of brittle fracture setting, I try to solve a bound constraint minimization problem using TAO. I checkout on the main branch of Petsc. Minimization with respect to the bounded variable (damage) is achieved through the Bounded Newton Trust Region (TAOBNTR). All other TAO parameters are set by default. On a Linux machine, I get the following error with a 4 processors run:
Can you view the solver?
Matt
[3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Nonconforming object sizes
[3]PETSC ERROR: Preconditioner number of local rows 1122 does not equal input vector size 1161
[3]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[3]PETSC ERROR: Petsc Development GIT revision: v3.18.3-342-gdab44c92d91 GIT Date: 2023-01-04 13:37:04 +0000
[3]PETSC ERROR: /home/marboeua/Developpement/mef90/arch-darwin-c/bin/vDefTAO on a arch-darwin-c named bb01 by marboeua Thu Jan 12 16:55:18 2023
[2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Configure options --FFLAGS=-ffree-line-length-none --COPTFLAGS="-O3 -march=znver3 -g" --CXXOPTFLAGS="-O3 -march=znver3 -g" --FOPTFLAGS="-O3 -march=znver3 -g" --download-fblaslapack=1 --download-mumps=1 --download-chaco=1 --download-exodusii=1 --download-hypre=1 --download-ml=1 --download-triangle --download-scalapack=1 --download-superlu=1 --download-sowing=1 --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++ --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-yaml=1 --download-bison=1 --download-hdf5=1 --download-metis=1 --download-parmetis=1 --download-netcdf=1 --download-pnetcdf=1 --download-zlib=1 --with-cmake=1 --with-debugging=0 --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-ranlib=ranlib --with-shared-libraries=1 --with-sieve=1 --download-p4est=1 --with-pic --with-mpiexec=srun --with-x11=0 PETSC_ARCH=arch-darwin-c
[3]PETSC ERROR: #1 PCApply() at /1/home/marboeua/Developpement/petsc/src/ksp/pc/interface/precon.c:434
[3]PETSC ERROR: #2 KSP_PCApply() at /home/marboeua/Developpement/petsc/include/petsc/private/kspimpl.h:380
[3]PETSC ERROR: #3 KSPCGSolve_STCG() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c:76
[3]PETSC ERROR: #4 KSPSolve_Private() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:898
[3]PETSC ERROR: #5 KSPSolve() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:1070
[3]PETSC ERROR: #6 TaoBNKComputeStep() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bnk.c:459
[3]PETSC ERROR: #7 TaoSolve_BNTR() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bntr.c:138
[3]PETSC ERROR: #8 TaoSolve() at /1/home/marboeua/Developpement/petsc/src/tao/interface/taosolver.c:177
[2]PETSC ERROR: Nonconforming object sizes
[2]PETSC ERROR: Preconditioner number of local rows 1229 does not equal input vector size 1254
[2]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[2]PETSC ERROR: Petsc Development GIT revision: v3.18.3-342-gdab44c92d91 GIT Date: 2023-01-04 13:37:04 +0000
[2]PETSC ERROR: /home/marboeua/Developpement/mef90/arch-darwin-c/bin/vDefTAO on a arch-darwin-c named bb01 by marboeua Thu Jan 12 16:55:18 2023
[2]PETSC ERROR: Configure options --FFLAGS=-ffree-line-length-none --COPTFLAGS="-O3 -march=znver3 -g" --CXXOPTFLAGS="-O3 -march=znver3 -g" --FOPTFLAGS="-O3 -march=znver3 -g" --download-fblaslapack=1 --download-mumps=1 --download-chaco=1 --download-exodusii=1 --download-hypre=1 --download-ml=1 --download-triangle --download-scalapack=1 --download-superlu=1 --download-sowing=1 --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++ --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-yaml=1 --download-bison=1 --download-hdf5=1 --download-metis=1 --download-parmetis=1 --download-netcdf=1 --download-pnetcdf=1 --download-zlib=1 --with-cmake=1 --with-debugging=0 --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-ranlib=ranlib --with-shared-libraries=1 --with-sieve=1 --download-p4est=1 --with-pic --with-mpiexec=srun --with-x11=0 PETSC_ARCH=arch-darwin-c
[2]PETSC ERROR: #1 PCApply() at /1/home/marboeua/Developpement/petsc/src/ksp/pc/interface/precon.c:434
[2]PETSC ERROR: #2 KSP_PCApply() at /home/marboeua/Developpement/petsc/include/petsc/private/kspimpl.h:380
[2]PETSC ERROR: #3 KSPCGSolve_STCG() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c:76
[2]PETSC ERROR: #4 KSPSolve_Private() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:898
[2]PETSC ERROR: #5 KSPSolve() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:1070
[2]PETSC ERROR: #6 TaoBNKComputeStep() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bnk.c:459
[2]PETSC ERROR: #7 TaoSolve_BNTR() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bntr.c:138
[2]PETSC ERROR: #8 TaoSolve() at /1/home/marboeua/Developpement/petsc/src/tao/interface/taosolver.c:177
[3]PETSC ERROR: #9 /home/marboeua/Developpement/mef90/vDef/vDefTAO.F90:370
application called MPI_Abort(MPI_COMM_SELF, 60) - process 0
[2]PETSC ERROR: #9 /home/marboeua/Developpement/mef90/vDef/vDefTAO.F90:370
slurmstepd: error: *** STEP 5034.0 ON bb01 CANCELLED AT 2023-01-12T17:21:07 ***
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
srun: error: bb01: tasks 0-1: Killed
srun: error: bb01: tasks 2-3: Exited with exit code 1
The error is raised in the middle of the computation after many successful calls of TAOSolve and TAO iterations. My guess is that TAO computes the preconditioner during its first iteration with all variables in the active set. But the preconditioner is never updated when some variables are moved to the inactive set during the next TAO iterations. Am I right? Can you help me with that?
Thanks a lot for your help and your time.
Alexis
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230114/5692a32c/attachment-0001.html>
