[petsc-users] Nonconforming object sizes using TAO (TAOBNTR)
Alexis Marboeuf alexis.marboeuf at hotmail.fr
Fri Jan 13 15:21:46 CST 2023
Hi all,
In a variational approach of brittle fracture setting, I try to solve a bound constraint minimization problem using TAO. I checkout on the main branch of Petsc. Minimization with respect to the bounded variable (damage) is achieved through the Bounded Newton Trust Region (TAOBNTR). All other TAO parameters are set by default. On a Linux machine, I get the following error with a 4 processors run:
[3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Nonconforming object sizes
[3]PETSC ERROR: Preconditioner number of local rows 1122 does not equal input vector size 1161
[3]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[3]PETSC ERROR: Petsc Development GIT revision: v3.18.3-342-gdab44c92d91  GIT Date: 2023-01-04 13:37:04 +0000
[3]PETSC ERROR: /home/marboeua/Developpement/mef90/arch-darwin-c/bin/vDefTAO on a arch-darwin-c named bb01 by marboeua Thu Jan 12 16:55:18 2023
[2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[3]PETSC ERROR: Configure options --FFLAGS=-ffree-line-length-none --COPTFLAGS="-O3 -march=znver3 -g" --CXXOPTFLAGS="-O3 -march=znver3 -g" --FOPTFLAGS="-O3 -march=znver3 -g" --download-fblaslapack=1 --download-mumps=1 --download-chaco=1 --download-exodusii=1 --download-hypre=1 --download-ml=1 --download-triangle --download-scalapack=1 --download-superlu=1 --download-sowing=1 --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++ --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-yaml=1 --download-bison=1 --download-hdf5=1 --download-metis=1 --download-parmetis=1 --download-netcdf=1 --download-pnetcdf=1 --download-zlib=1 --with-cmake=1 --with-debugging=0 --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-ranlib=ranlib --with-shared-libraries=1 --with-sieve=1 --download-p4est=1 --with-pic --with-mpiexec=srun --with-x11=0 PETSC_ARCH=arch-darwin-c
[3]PETSC ERROR: #1 PCApply() at /1/home/marboeua/Developpement/petsc/src/ksp/pc/interface/precon.c:434
[3]PETSC ERROR: #2 KSP_PCApply() at /home/marboeua/Developpement/petsc/include/petsc/private/kspimpl.h:380
[3]PETSC ERROR: #3 KSPCGSolve_STCG() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c:76
[3]PETSC ERROR: #4 KSPSolve_Private() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:898
[3]PETSC ERROR: #5 KSPSolve() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:1070
[3]PETSC ERROR: #6 TaoBNKComputeStep() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bnk.c:459
[3]PETSC ERROR: #7 TaoSolve_BNTR() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bntr.c:138
[3]PETSC ERROR: #8 TaoSolve() at /1/home/marboeua/Developpement/petsc/src/tao/interface/taosolver.c:177
[2]PETSC ERROR: Nonconforming object sizes
[2]PETSC ERROR: Preconditioner number of local rows 1229 does not equal input vector size 1254
[2]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[2]PETSC ERROR: Petsc Development GIT revision: v3.18.3-342-gdab44c92d91  GIT Date: 2023-01-04 13:37:04 +0000
[2]PETSC ERROR: /home/marboeua/Developpement/mef90/arch-darwin-c/bin/vDefTAO on a arch-darwin-c named bb01 by marboeua Thu Jan 12 16:55:18 2023
[2]PETSC ERROR: Configure options --FFLAGS=-ffree-line-length-none --COPTFLAGS="-O3 -march=znver3 -g" --CXXOPTFLAGS="-O3 -march=znver3 -g" --FOPTFLAGS="-O3 -march=znver3 -g" --download-fblaslapack=1 --download-mumps=1 --download-chaco=1 --download-exodusii=1 --download-hypre=1 --download-ml=1 --download-triangle --download-scalapack=1 --download-superlu=1 --download-sowing=1 --download-sowing-cc=/opt/rh/devtoolset-9/root/usr/bin/gcc --download-sowing-cxx=/opt/rh/devtoolset-9/root/usr/bin/g++ --download-sowing-cpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-sowing-cxxcpp=/opt/rh/devtoolset-9/root/usr/bin/cpp --download-yaml=1 --download-bison=1 --download-hdf5=1 --download-metis=1 --download-parmetis=1 --download-netcdf=1 --download-pnetcdf=1 --download-zlib=1 --with-cmake=1 --with-debugging=0 --with-mpi-dir=/opt/HPC/mvapich2/2.3.7-gcc11.2.1 --with-ranlib=ranlib --with-shared-libraries=1 --with-sieve=1 --download-p4est=1 --with-pic --with-mpiexec=srun --with-x11=0 PETSC_ARCH=arch-darwin-c
[2]PETSC ERROR: #1 PCApply() at /1/home/marboeua/Developpement/petsc/src/ksp/pc/interface/precon.c:434
[2]PETSC ERROR: #2 KSP_PCApply() at /home/marboeua/Developpement/petsc/include/petsc/private/kspimpl.h:380
[2]PETSC ERROR: #3 KSPCGSolve_STCG() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/impls/cg/stcg/stcg.c:76
[2]PETSC ERROR: #4 KSPSolve_Private() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:898
[2]PETSC ERROR: #5 KSPSolve() at /1/home/marboeua/Developpement/petsc/src/ksp/ksp/interface/itfunc.c:1070
[2]PETSC ERROR: #6 TaoBNKComputeStep() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bnk.c:459
[2]PETSC ERROR: #7 TaoSolve_BNTR() at /1/home/marboeua/Developpement/petsc/src/tao/bound/impls/bnk/bntr.c:138
[2]PETSC ERROR: #8 TaoSolve() at /1/home/marboeua/Developpement/petsc/src/tao/interface/taosolver.c:177
[3]PETSC ERROR: #9 /home/marboeua/Developpement/mef90/vDef/vDefTAO.F90:370
application called MPI_Abort(MPI_COMM_SELF, 60) - process 0
[2]PETSC ERROR: #9 /home/marboeua/Developpement/mef90/vDef/vDefTAO.F90:370
slurmstepd: error: *** STEP 5034.0 ON bb01 CANCELLED AT 2023-01-12T17:21:07 ***
srun: Job step aborted: Waiting up to 32 seconds for job step to finish.
srun: error: bb01: tasks 0-1: Killed
srun: error: bb01: tasks 2-3: Exited with exit code 1
The error is raised in the middle of the computation after many successful calls of TAOSolve and TAO iterations. My guess is that TAO computes the preconditioner during its first iteration with all variables in the active set. But the preconditioner is never updated when some variables are moved to the inactive set during the next TAO iterations. Am I right? Can you help me with that?
Thanks a lot for your help and your time.
Alexis
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230113/0fdfb2da/attachment-0001.html>
