[petsc-users] Retreiving a PetscObject
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Fri Jan 13 09:58:45 CST 2023
ok, here is what I want to do:
I am writing a brand new PC which needs some other PETSc objects like a
Vec (for unit partition).
We have a text based user file format in which the user can create
arbitrary Petsc's Vec or Mat.
Then, I would like the user to give the prefix of these Vec or Mat as a
parameter for the new PC that we would like to configure completely via
the "petsc options database".
So in our PCApply_XXX we would like to retrieve some specific options
which will simply give the Vec prefix to retreive.
Eric
On 2023-01-13 15:39, Matthew Knepley wrote:
> On Fri, Jan 13, 2023 at 4:24 AM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca> wrote:
>     Hi,
>     Is it possible with PETSc's API to query an objet by it's name?
>     Is there a "global" database with all PETScObject created?
> No, we do not store that information. What would the use case be?
> Maybe there is another way to do it.
>   Thanks,
>     Matt
>     Thanks,
>     Eric
>     Eric Chamberland, ing., M. Ing
>     Professionnel de recherche
>     GIREF/Université Laval
>     (418) 656-2131 poste 41 22 42
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230113/717bc0a8/attachment.html>
