[petsc-users] PetscSF Fortran interface
Junchao Zhang junchao.zhang at gmail.com
Thu Jan 12 22:55:43 CST 2023
On Thu, Jan 12, 2023 at 1:28 PM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Junchao
> Going back to this merge request. I'm not sure I follow exactly the usage
> described in the commit history. I have a c prototype of what I am trying
> to do which is
>     PetscSectionCreate(PETSC_COMM_WORLD, &leafSection);
>     PetscSFDistributeSection(redistributionSF, filteredSection_local, &remoteOffsets,
> leafSection);
>     PetscSFCreateSectionSF(redistributionSF, filteredSection_local,
> remoteOffsets, leafSection, &redistributionSF_dof);
> But something seems unclear with the usage in fortran around the
> remoteoffsets. Do I have to insert the CreateRemoteOffsetsF90 like so? Any
> clarification would be greatly appreciated.
> call PetscSFDistributeSectionF90(distributionSF, section_filt_l,
> remoteoffsets, leafSection, ierr)
> call PetscSFCreateRemoteOffsetsf90(distributionSF, section_filt_l,
> leafSection, remoteoffsets, ierr )
> call PetscSFCreateSectionSFF90(distributionSF, section_filt_l,
> remoteoffsets, leafSection, distributionSF_dof, ierr)
> Hi, Nicholas,
  Reading through comments at
https://gitlab.com/petsc/petsc/-/merge_requests/5386#note_1022942470, I
feel it should look like
PetscInt, pointer :: remoteOffsets(:)
remoteoffsets, leafSection, ierr)  // allocate remoteoffsets
call PetscIntArray1dDestroyF90(remoteOffsets,ierr) // free remoteoffsets
when not needed
Could you try it?
Sincerely
> Nicholas
> On Tue, Jan 10, 2023 at 4:42 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> Hi, Nicholas,
>>    It seems we have implemented it, but with another name,
>> PetscSFCreateSectionSFF90, see
>>    Try it to see if it works!
>> --Junchao Zhang
>> On Tue, Jan 10, 2023 at 11:45 AM Nicholas Arnold-Medabalimi <
>>> Er to be honest I still can't get my stub to compile properly, and I
>>> don't know how to go about making a merge request. But here is what I am
>>> attempting right now. Let me know how best to proceed
>>> Its not exactly clear to me how to setup up the remote offset properly.
>>> in src/vec/is/sf/interface/ftn-custom/zsf.c
>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection
>>> *rootSection, F90Array1d *aremoteOffsets, PetscSection *leafSection,
>>> PetscSF *sectionSF, int * ierr PETSC_F90_2PTR_PROTO(remoteoffsetsd))
>>>   int * remoteOffsets;
>>>   *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**)
>>> &remoteOffsets PETSC_F90_2PTR_PARAM(remoteoffsetsd));if (*ierr) return;
>>>   *ierr = PetscSFCreateSectionSF(*sf,*rootSection,
>>> &remoteOffsets,*leafSection,*sectionSF);if (*ierr) return;
>>> This is the sticking point.
>>> Sincerely
>>> Nicholas
>>> On Tue, Jan 10, 2023 at 12:38 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Hi, Nicholas,
>>>>   Could you make a merge request to PETSc and then our Fortran experts
>>>> can comment on your MR?
>>>>   Thanks.
>>>> --Junchao Zhang
>>>> On Tue, Jan 10, 2023 at 11:10 AM Nicholas Arnold-Medabalimi <
>>>>> Hi Junchao
>>>>> I think I'm almost there, but I could use some insight into how to use
>>>>> the PETSC_F90_2PTR_PROTO and F90Array1dAccess for the remoteOffset
>>>>> parameter input so if another function comes up, I can add it myself
>>>>> without wasting your time.
>>>>> I am very grateful for your help and time.
>>>>> Sincerely
>>>>> Nicholas
>>>>> On Tue, Jan 10, 2023 at 10:55 AM Junchao Zhang <
>>>>> junchao.zhang at gmail.com> wrote:
>>>>>> Hi, Nicholas,
>>>>>>    I am not a fortran guy, but I will try to add
>>>>>> petscsfcreatesectionsf.
>>>>>>    Thanks.
>>>>>> --Junchao Zhang
>>>>>> On Tue, Jan 10, 2023 at 12:50 AM Nicholas Arnold-Medabalimi <
>>>>>>> I think it should be something like this, but I'm not very fluent in
>>>>>>> Fortran C interop syntax. Any advice would be appreciated. Thanks
>>>>>>> PETSC_EXTERN void petscsfcreatesectionsf(PetscSF *sf, PetscSection *
>>>>>>>   *ierr = F90Array1dAccess(aremoteOffsets, PETSC_INT, (void**) &
>>>>>>> return;
>>>>>>>   *ierr = PetscSFCreateSectionSF(*sf,*rootSection, &remoteOffsets,*
>>>>>>> On Mon, Jan 9, 2023 at 11:41 PM Nicholas Arnold-Medabalimi <
>>>>>>>> Hi Junchao
>>>>>>>> Thanks again for your help in November. I've been using the your
>>>>>>>> merge request branch quite heavily. Would it be possible to add a
>>>>>>>> petscsfcreatesectionsf interface as well?
>>>>>>>> I'm trying to write it myself using your commits as a guide but I
>>>>>>>> have been struggling with handling the section parameter properly.
>>>>>>>> Sincerely
>>>>>>>> Nicholas
>>>>>>>> On Sat, Nov 19, 2022 at 9:44 PM Junchao Zhang <
>>>>>>>>> On Sat, Nov 19, 2022 at 8:05 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>> Hi
>>>>>>>>>> Thanks, this is awesome. Thanks for the very prompt fix. Just one
>>>>>>>>>> question: will the array outputs on the fortran side copies (and need to be
>>>>>>>>>> deallocated) or direct access to the dmplex?
>>>>>>>>> Direct access to internal data;  no need to deallocate
>>>>>>>>>> Sincerely
>>>>>>>>>> Nicholas
>>>>>>>>>> On Sat, Nov 19, 2022 at 8:21 PM Junchao Zhang <
>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>>   See this MR,
>>>>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/5860
>>>>>>>>>>>   It is in testing, but you can try branch
>>>>>>>>>>> jczhang/add-petscsf-fortran to see if it works for you.
>>>>>>>>>>>   Thanks.
>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>> On Sat, Nov 19, 2022 at 4:16 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>> Hi Junchao
>>>>>>>>>>>> Thanks. I was wondering if there is any update on this. I may
>>>>>>>>>>>> write a small interface for those two routines myself in the interim but
>>>>>>>>>>>> I'd appreciate any insight you have.
>>>>>>>>>>>> Sincerely
>>>>>>>>>>>> Nicholas
>>>>>>>>>>>> On Wed, Nov 16, 2022 at 10:39 PM Junchao Zhang <
>>>>>>>>>>>>> Hi, Nicholas,
>>>>>>>>>>>>>   I will have a look and get back to you.
>>>>>>>>>>>>>   Thanks.
>>>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>>>> On Wed, Nov 16, 2022 at 9:27 PM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>>>> Hi Petsc Users
>>>>>>>>>>>>>> I'm in the process of adding some Petsc for mesh management
>>>>>>>>>>>>>> into an existing Fortran Solver. It has been relatively straightforward so
>>>>>>>>>>>>>> far but I am running into an issue with using PetscSF routines. Some like
>>>>>>>>>>>>>> the PetscSFGetGraph work no problem but a few of my routines require the
>>>>>>>>>>>>>> use of PetscSFGetLeafRanks and PetscSFGetRootRanks and those don't seem to
>>>>>>>>>>>>>> be in the fortran interface and I just get a linking error. I also don't
>>>>>>>>>>>>>> seem to see a PetscSF file in the finclude. Any clarification or assistance
>>>>>>>>>>>>>> Sincerely
>>>>>>>>>>>>>> Nicholas
>>>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>>>>> University of Michigan
>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>> Ph.D. Candidate
>>>>>>>> Ph.D. Candidate
>>>>>>> Ph.D. Candidate
>>>>> Ph.D. Candidate
>>> Ph.D. Candidate
> Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230112/c0fd3134/attachment-0001.html>
