[petsc-users] coordinate degrees of freedom for 2nd-order gmsh mesh
Jed Brown
jed at jedbrown.org
Thu Jan 12 17:33:04 CST 2023
It's confusing, but this line makes high order simplices always read as discontinuous coordinate spaces. I would love if someone would revisit that, perhaps also using DMPlexSetIsoperiodicFaceSF(), which should simplify the code and avoid the confusing cell coordinates pattern. Sadly, I don't have time to dive in.
https://gitlab.com/petsc/petsc/-/commit/066ea43f7f75752f012be6cd06b6107ebe84cc6d#3616cad8148970af5b97293c49492ff893e25b59_1552_1724
"Daniel R. Shapero" <shapero at uw.edu> writes:
> Sorry either your mail system or mine prevented me from attaching the file,
> so I put it on pastebin:
> https://pastebin.com/awFpc1Js
> On Wed, Jan 11, 2023 at 4:54 PM Matthew Knepley <knepley at gmail.com> wrote:
>> Can you send the .msh file? I still have not installed Gmsh :)
>> Thanks,
>> Matt
>> On Wed, Jan 11, 2023 at 2:43 PM Daniel R. Shapero <shapero at uw.edu> wrote:
>>> Hi all -- I'm trying to read in 2nd-order / piecewise quadratic meshes
>>> that are generated by gmsh and I don't understand how the coordinates are
>>> stored in the plex. I've been discussing this with Matt Knepley here
>>> <https://urldefense.com/v3/__https://github.com/firedrakeproject/firedrake/issues/982__;!!K-Hz7m0Vt54!hL9WLR51ieyHFZx8N9AjhDwJCRpvmQto9CL1XOTkkAxFfUbtsabHuBDOATnWyP6lQszhA2gOStva7A$>
>>> as it pertains to Firedrake but I think this is more an issue at the PETSc
>>> level.
>>> This code
>>> <https://urldefense.com/v3/__https://gist.github.com/danshapero/a140daaf951ba58c48285ec29f5973cc__;!!K-Hz7m0Vt54!hL9WLR51ieyHFZx8N9AjhDwJCRpvmQto9CL1XOTkkAxFfUbtsabHuBDOATnWyP6lQszhA2hho2eD1g$>
>>> uses gmsh to generate a 2nd-order mesh of the unit disk, read it into a
>>> DMPlex, print out the number of cells in each depth stratum, and finally
>>> print a view of the coordinate DM's section. The resulting mesh has 64
>>> triangles, 104 edges, and 41 vertices. For 2nd-order meshes, I'd expected
>>> there to be 2 degrees of freedom at each node and 2 at each edge. The
>>> output is:
>>> Depth strata: [(64, 105), (105, 209), (0, 64)]
>>> PetscSection Object: 1 MPI process
>>> type not yet set
>>> 1 fields
>>> field 0 with 2 components
>>> Process 0:
>>> ( 0) dim 12 offset 0
>>> ( 1) dim 12 offset 12
>>> ( 2) dim 12 offset 24
>>> ( 62) dim 12 offset 744
>>> ( 63) dim 12 offset 756
>>> ( 64) dim 0 offset 768
>>> ( 65) dim 0 offset 768
>>> ( 207) dim 0 offset 768
>>> ( 208) dim 0 offset 768
>>> PetscSectionSym Object: 1 MPI process
>>> type: label
>>> Label 'depth'
>>> Symmetry for stratum value 0 (0 dofs per point): no symmetries
>>> Symmetry for stratum value 1 (0 dofs per point): no symmetries
>>> Symmetry for stratum value 2 (12 dofs per point):
>>> Orientation range: [-3, 3)
>>> Symmetry for stratum value -1 (0 dofs per point): no symmetries
>>> The output suggests that there are 12 degrees of freedom in each
>>> triangle. That would mean the coordinate field is discontinuous across cell
>>> boundaries. Can someone explain what's going on? I tried reading the .msh
>>> file but it's totally inscrutable to me. I'm happy to RTFSC if someone
>>> points me in the right direction. Matt tells me that the coordinate field
>>> should only be discontinuous if the mesh is periodic, but this mesh
>>> shouldn't be periodic.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!K-Hz7m0Vt54!hL9WLR51ieyHFZx8N9AjhDwJCRpvmQto9CL1XOTkkAxFfUbtsabHuBDOATnWyP6lQszhA2go23tjRg$>
