[petsc-users] PETSC install
Sijie Zhang zhan2355 at purdue.edu
Wed Jan 11 22:52:27 CST 2023
Yes, I followed the exact instructions. I’m using bash. I put the environmental variable in the .bashrc file. This only happens to my intel i129700 workstation. Is it because of the hardware?
Thanks.
Sijie
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows
Sent: Wednesday, January 11, 2023 7:40 PM
To: Barry Smith<mailto:bsmith at petsc.dev>
Cc: Sijie Zhang<mailto:zhan2355 at purdue.edu>; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] PETSC install
---- External Email: Use caution with attachments, links, or sharing data ----
On Wed, Jan 11, 2023 at 2:33 PM Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>> wrote:
  Did you do exactly:
export HWLOC_HIDE_ERRORS=2
make check
Also, what shell are you using? The command above is for bash, but if you use csh it is different.
     Matt
On Jan 11, 2023, at 6:51 PM, Sijie Zhang <zhan2355 at purdue.edu<mailto:zhan2355 at purdue.edu>> wrote:
I tried that but it's showing the same error.  Can you help me to take a look at that?
Thanks.
Sijie
Running check examples to verify correct installation
Using PETSC_DIR=/home/zhangsijie1995/Documents/Package/petsc-3.18.3 and PETSC_ARCH=arch-linux-c-debug
Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
See https://petsc.org/release/faq/
hwloc/linux: Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don't enable unless really needed).
lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
Number of SNES iterations = 2
Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
*******************Error detected during compile or link!*******************
/home/zhangsijie1995/Documents/Package/petsc-3.18.3/src/snes/tutorials ex5f
/opt/intel/oneapi/mpi/2021.8.0/bin/mpif90 -fPIC -Wall -ffree-line-length-none -ffree-line-length-0 -Wno-lto-type-mismatch -Wno-unused-dummy-argument -g -O0   -I/home/zhangsijie1995/Documents/Package/petsc-3.18.3/include -I/home/zhangsijie1995/Documents/Package/petsc-3.18.3/arch-linux-c-debug/include -I/opt/intel/oneapi/mkl/2023.0.0/include -I/opt/intel/oneapi/mpi/2021.8.0/include     ex5f.F90  -Wl,-rpath,/home/zhangsijie1995/Documents/Package/petsc-3.18.3/arch-linux-c-debug/lib -L/home/zhangsijie1995/Documents/Package/petsc-3.18.3/arch-linux-c-debug/lib -Wl,-rpath,/opt/intel/oneapi/mkl/2023.0.0/lib/intel64 -L/opt/intel/oneapi/mkl/2023.0.0/lib/intel64 -Wl,-rpath,/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib/release -L/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib/release -Wl,-rpath,/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib -L/home/zhangsijie1995/Documents/Package/petsc-3.18.3/I_MPI_SUBSTITUTE_INSTALLDIR/lib -Wl,-rpath,/usr/lib/gcc/x86_64-linux-gnu/11 -L/usr/lib/gcc/x86_64-linux-gnu/11 -lpetsc -lmkl_intel_lp64 -lmkl_core -lmkl_sequential -lpthread -lm -lstdc++ -ldl -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -ldl -o ex5f
f951: Warning: Nonexistent include directory ‘I_MPI_SUBSTITUTE_INSTALLDIR/include/gfortran/11.1.0’ [-Wmissing-include-dirs]
f951: Warning: Nonexistent include directory ‘I_MPI_SUBSTITUTE_INSTALLDIR/include’ [-Wmissing-include-dirs]
Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
Number of SNES iterations =     3
Completed test examples
Error while running make check
gmake[1]: *** [makefile:149: check] Error 1
make: *** [GNUmakefile:17: check] Error 2
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Sent: Wednesday, January 11, 2023 8:22 AM
To: Sijie Zhang
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
https://petsc.org/release/faq/#what-does-the-message-hwloc-linux-ignoring-pci-device-with-non-16bit-domain-mean
On Jan 11, 2023, at 5:03 AM, Sijie Zhang <zhan2355 at purdue.edu<mailto:zhan2355 at purdue.edu>> wrote:
When I try to install petsc on my workstation, I got the following error. Can you help me with that?
Thank you and best regards.
Sijie
make: *** [GNUmakefile:17: check] Error 2<configure.log><make.log>
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230112/3a8e95fc/attachment-0001.html>
