[petsc-users] [EXTERNAL] GPU implementation of serial smoothers
Mark Lohry
mlohry at gmail.com
Tue Jan 10 15:58:36 CST 2023
Thanks Stefano and Chonglin!
DILU in openfoam is our block Jacobi ilu subdomain solvers
are you saying that -pc_type gang -mg_levels_pc_type -mg_levels_ksp_type
richardson gives you something exactly equivalent to DILU?
On Tue, Jan 10, 2023 at 4:04 PM Zhang, Chonglin <zhangc20 at rpi.edu> wrote:
> I am using the following in my Poisson solver running on GPU, which were
> suggested by Barry and Mark (Dr. Mark Adams).
> -ksp_type cg
> -pc_type gamg
> -mg_levels_ksp_type chebyshev
> -mg_levels_pc_type jacobi
> On Jan 10, 2023, at 3:31 PM, Mark Lohry <mlohry at gmail.com> wrote:
> So what are people using for GAMG configs on GPU? I was hoping petsc today
> would be performance competitive with AMGx but it sounds like that's not
> the case?
> On Tue, Jan 10, 2023 at 3:03 PM Jed Brown <jed at jedbrown.org> wrote:
>> Mark Lohry <mlohry at gmail.com> writes:
>> > I definitely need multigrid. I was under the impression that GAMG was
>> > relatively cuda-complete, is that not the case? What functionality works
>> > fully on GPU and what doesn't, without any host transfers (aside from
>> > what's needed for MPI)?
>> > If I use -ksp-pc_type gamg -mg_levels_pc_type pbjacobi
>> -mg_levels_ksp_type
>> > richardson is that fully on device, but -mg_levels_pc_type ilu or
>> > -mg_levels_pc_type sor require transfers?
>> You can do `-mg_levels_pc_type ilu`, but it'll be extremely slow (like
>> 20x slower than an operator apply). One can use Krylov smoothers, though
>> that's more synchronization. Automatic construction of operator-dependent
>> multistage smoothers for linear multigrid (because Chebyshev only works for
>> problems that have eigenvalues near the real axis) is something I've wanted
>> to develop for at least a decade, but time is always short. I might put
>> some effort into p-MG with such smoothers this year as we add DDES to our
>> scale-resolving compressible solver.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230110/aa92d7a1/attachment.html>
