[petsc-users] GPU implementation of serial smoothers
Mark Lohry
mlohry at gmail.com
Tue Jan 10 13:19:42 CST 2023
> Is DILU a point-block method? We have -pc_type pbjacobi (and vpbjacobi if
> the node size is not uniform). The are good choices for scale-resolving CFD
> on GPUs.
I was hoping you'd know :) pbjacobi is underperforming ilu by a pretty
wide margin on some of the systems i'm looking at.
We don't have colored smoothers currently in PETSc.
So what happens under the hood when I run -mg_levels_pc_type sor on GPU?
Are you actually decomposing the matrix into lower and computing updates
with matrix multiplications? Or is it just the standard serial algorithm
with thread safety ignored?
> if the node size is not uniform). The are good choices for scale-resolving
> CFD on GPUs.
> > Mark Lohry <mlohry at gmail.com> writes:
> >> I'm running GAMG with CUDA, and I'm wondering how the nominally serial
> >> smoother algorithms are implemented on GPU? Specifically SOR/GS and
> ILU(0)
> >> -- in e.g. AMGx these are applied by first creating a coloring, and the
> >> smoother passes are done color by color. Is this how it's done in petsc
> AMG?
> >> Tangential, AMGx and OpenFOAM offer something called "DILU", diagonal
> ILU.
> >> Is there an equivalent in petsc?
> >> Thanks,
> >> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230110/583ef4bb/attachment-0001.html>
