[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Mark Lohry
mlohry at gmail.com
Fri Jan 6 19:35:33 CST 2023
Well, I think it's a moderately crazy idea unless it's less painful to
implement than I'm thinking. Is there a use case for a mixed device system
where one petsc executable might be addressing both a HIP and CUDA device
beyond some frankenstein test system somebody cooked up? In all my code I
implicitly assume I have either have one host with one device or one host
with zero devices. I guess you can support these weird scenarios, but why?
Life is hard enough supporting one device compiler with one host compiler.
Many thanks Junchao -- with combinations of SetPreallocation I was able to
grab allocated pointers out of petsc. Now I have all the jacobian
construction on device with no copies.
On Fri, Jan 6, 2023 at 12:27 AM Barry Smith <bsmith at petsc.dev> wrote:
> So Jed's "everyone" now consists of "no one" and Jed can stop
> complaining that "everyone" thinks it is a bad idea.
> On Jan 5, 2023, at 11:50 PM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> On Thu, Jan 5, 2023 at 10:32 PM Barry Smith <bsmith at petsc.dev> wrote:
>> > On Jan 5, 2023, at 3:42 PM, Jed Brown <jed at jedbrown.org> wrote:
>> > Mark Adams <mfadams at lbl.gov> writes:
>> >> Support of HIP and CUDA hardware together would be crazy,
>> > I don't think it's remotely crazy. libCEED supports both together and
>> it's very convenient when testing on a development machine that has one of
>> each brand GPU and simplifies binary distribution for us and every package
>> that uses us. Every day I wish PETSc could build with both simultaneously,
>> but everyone tells me it's silly.
>> Not everyone at all; just a subset of everyone. Junchao is really the
>> hold-out :-)
> I am not, instead I think we should try (I fully agree it can ease binary
> distribution). But satish needs to install such a machine first :)
> There are issues out of our control if we want to mix GPUs in execution.
> For example, how to do VexAXPY on a cuda vector and a hip vector? Shall we
> do it on the host? Also, there are no gpu-aware MPI implementations
> supporting messages between cuda memory and hip memory.
>> I just don't care about "binary packages" :-); I think they are an
>> archaic and bad way of thinking about code distribution (but yes the
>> alternatives need lots of work to make them flawless, but I think that is
>> where the work should go in the packaging world.)
>> I go further and think one should be able to automatically use a CUDA
>> vector on a HIP device as well, it is not hard in theory but requires
>> thinking about how we handle classes and subclasses a little to make it
>> straightforward; or perhaps Jacob has fixed that also?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/89b20762/attachment-0001.html>
