[petsc-users] Vec Ownership ranges with Global Section Offsets
Nicholas Arnold-Medabalimi narnoldm at umich.edu
Fri Jan 6 08:36:42 CST 2023
Hi Matt
I made a typo on the line statVecV(offset) = <set to something> in my
example, I agree. (I wrote that offhand since the actual assignment is much
larger) I should be statVecV(offset+1) = <assignment> so I'm confident it's
not a 1 0 indexing thing.
My question is more related to what is happening in the offsets. c0 and c1
are pulled using DMplexgetheight stratum, so they are zero-indexed (which
is why I loop from c0 to (c1-1)).
For the size inquiries. on processor 0
 Petsc VecGetSize(stateVec)        5390
 size(stateVecV)           2640
on processor 1
Petsc VecGetSize 5390
size(stateVecV)    2750
It's quite weird to me that processor one can have a positive offset that
is less than its starting ownership index (in the initial email output).
Thanks for the assistance
Nicholas
On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Petsc Users,
>> I'm working with a dmplex system with a subsampled mesh distributed with
>> an overlap of 1.
>> I'm encountering unusual situations when using VecGetOwnershipRange to
>> adjust the offset received from a global section. The logic of the
>> following code is first to get the offset needed to index a global vector
>> while still being able to check if it is an overlapped cell and skip if
>> needed while counting the owned cells.
>> call DMGetGlobalSection(dmplex,section,ierr)
>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>> do i = c0, (c1-1)
>>     call PetscSectionGetOffset(section,i,offset,ierr)
>>     write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
>>     if(offset<0) then
>>         cycle
>>     endif
>> offset=offset-oStart
>> plexcells=plexcells+1
>> stateVecV(offset)= <set to something> enddo
>> I'm noticing some very weird results that I've appended below. The
>> GetOffset documentation notes that a negative offset indicates an unowned
>> point (which I use to cycle). However, the offset subtraction with oStart
>> will yield an illegal index for the Vector access. I see that on the
>> documentation for GetOwnershipRange, it notes that this may be
>> "ill-defined"  but I wanted to see if this is type of ill-defined I can
>> expect or there is just something terribly wrong with my PetscSection.(both
>> the Vec and Section were produced from DMPlexDistributeField so should by
>> definition have synchronized section information) I was wondering if there
>> is a possible output and/or the best way to index the vector. I'm thinking
>> of subtracting the offset of cell 0 perhaps?
> Can you show your vector sizes? Are you sure it is not the fact that F90
> arrays use 1-based indices, but these are 0-based offsets?
>   Thanks,
>      Matt
>> on rank 0
>>  cell           0 offset           0 oStart           0           0
>>  cell           1 offset          55 oStart           0          55
>>  cell           2 offset         110 oStart           0         110
>>  cell           3 offset         165 oStart           0         165
>>  cell           4 offset         220 oStart           0         220
>>  cell           5 offset         275 oStart           0         275
>>  cell           6 offset         330 oStart           0         330
>>  cell           7 offset         385 oStart           0         385
>>  cell           8 offset         440 oStart           0         440
>>  cell           9 offset         495 oStart           0         495
>>  cell          10 offset         550 oStart           0         550
>>  cell          11 offset         605 oStart           0         605
>>  cell          12 offset         660 oStart           0         660
>>  cell          13 offset         715 oStart           0         715
>> and on rank one
>> cell           0 offset        2475 oStart        2640        -165
>>  cell           1 offset        2530 oStart        2640        -110
>>  cell           2 offset        2585 oStart        2640         -55
>>  cell           3 offset        2640 oStart        2640           0
>>  cell           4 offset        2695 oStart        2640          55
>>  cell           5 offset        2750 oStart        2640         110
>>  cell           6 offset        2805 oStart        2640         165
>>  cell           7 offset        2860 oStart        2640         220
>>  cell           8 offset        2915 oStart        2640         275
>>  cell           9 offset        2970 oStart        2640         330
>>  cell          10 offset        3025 oStart        2640         385
>>  cell          11 offset        3080 oStart        2640         440
>>  cell          12 offset        3135 oStart        2640         495
>>  cell          13 offset        3190 oStart        2640         550
>>  cell          14 offset        3245 oStart        2640         605
>>  cell          15 offset        -771 oStart        2640       -3411
>> Sincerely
>> Nicholas
>> Ph.D. Candidate
>> Computational Aeroscience Lab
>> University of Michigan
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/460d01c9/attachment-0001.html>
