[petsc-users] error when trying to compile with HPDDM
Alfredo Jaramillo ajaramillopalma at gmail.com
Thu Jan 5 14:06:36 CST 2023
Hi Pierre, no, I don't really need that flag. I removed it and the
installation process went well. I just noticed a "minor" detail when
building SLEPc:
"gmake[3]: warning: jobserver unavailable: using -j1.  Add '+' to parent
make rule"
so the compilation of that library went slow.
Alfredo
On Thu, Jan 5, 2023 at 12:39 PM Pierre Jolivet <pierre at joliv.et> wrote:
> On 5 Jan 2023, at 7:06 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jan 5, 2023 at 11:36 AM Alfredo Jaramillo <
> ajaramillopalma at gmail.com> wrote:
>> Dear developers,
>> I'm trying to compile petsc together with the HPDDM library. A series on
>> errors appeared:
>> /home/ajaramillo/petsc/x64-openmpi-aldaas2021/include/HPDDM_specifications.hpp:
>> In static member function ‘static constexpr __float128
>> std::numeric_limits<__float128>::min()’:
>> /home/ajaramillo/petsc/x64-openmpi-aldaas2021/include/HPDDM_specifications.hpp:54:57:
>> error: unable to find numeric literal operator ‘operator""Q’
>>    54 |     static constexpr __float128 min() noexcept { return
>> FLT128_MIN; }
>> I'm attaching the log files to this email.
> Pierre,
> It looks like we may need to test for FLT_MIN and FLT_MAX in configure
> since it looks like Alfredo's headers do not have them.
> Is this correct?
> We could do that, but I bet this is a side effect of the fact that Alfredo
> is using --with-cxx-dialect=C++11.
> Alfredo, did you got that flag from someone else’s configure, or do you
> know what that flag is doing?
> - If yes, do you really need to stick to -std=c++11?
> - If no, please look at
> https://gitlab.com/petsc/petsc/-/issues/1284#note_1173803107 and consider
> removing that flag, or at least changing the option to
> --with-cxx-dialect=11. If compilation still fails, please send the
> up-to-date configure.log/make.log
> Thanks,
> Pierre
>   Thanks,
>      Matt
>> Could you please help me with this?
>> bests regards
>> Alfredo
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230105/1982524b/attachment-0001.html>
