[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Mark Lohry mlohry at gmail.com
Thu Jan 5 10:23:56 CST 2023
I am thinking something like MatSeqAIJGetArrayAndMemType
Isn't the "MemType" of the matrix an invariant on creation? e.g. a user
shouldn't care what memtype a pointer is for, just that if a device matrix
was created it returns device pointers, if a host matrix was created it
returns host pointers.
Now that I'm looking at those docs I see MatSeqAIJGetCSRAndMemType
<https://petsc.org/release/docs/manualpages/Mat/MatSeqAIJGetCSRAndMemType/>,
isn't this what I'm looking for? If I call MatCreateSeqAIJCUSPARSE it will
cudaMalloc the csr arrays, and then MatSeqAIJGetCSRAndMemType will return
me those raw device pointers?
On Thu, Jan 5, 2023 at 11:06 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> On Thu, Jan 5, 2023 at 9:39 AM Mark Lohry <mlohry at gmail.com> wrote:
>>> A workaround is to let petsc build the matrix and allocate the memory,
>>> then you call MatSeqAIJCUSPARSEGetArray() to get the array and fill it up.
>> Junchao, looking at the code for this it seems to only return a pointer
>> to the value array, but not pointers to the column and row index arrays, is
>> that right?
> Yes, that is correct.
> I am thinking something like MatSeqAIJGetArrayAndMemType(Mat A, const
> PetscInt **i, const PetscInt **j, PetscScalar **a, PetscMemType *mtype),
> which returns (a, i, j) on device and mtype = PETSC_MEMTYPE_{CUDA, HIP} if
> A is a device matrix, otherwise (a,i, j) on host and mtype =
> PETSC_MEMTYPE_HOST.
> We currently have similar things like
> VecGetArrayAndMemType(Vec,PetscScalar**,PetscMemType*), and I am adding
> MatDenseGetArrayAndMemType(Mat,PetscScalar**,PetscMemType*).
> It looks like you need (a, i, j) for assembly, but the above function only
> works for an assembled matrix.
>> On Thu, Jan 5, 2023 at 5:47 AM Jacob Faibussowitsch <jacob.fai at gmail.com>
>> wrote:
>>> We define either PETSC_HAVE_CUDA or PETSC_HAVE_HIP or NONE, but not both
>>> CUPM works with both enabled simultaneously, I don’t think there are any
>>> direct restrictions for it. Vec at least was fully usable with both cuda
>>> and hip (though untested) last time I checked.
>>> Best regards,
>>> (Jacob Fai - booss - oh - vitch)
>>> On Jan 5, 2023, at 00:09, Junchao Zhang <junchao.zhang at gmail.com> wrote:
>>> On Wed, Jan 4, 2023 at 6:02 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Jan 4, 2023 at 6:49 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> On Wed, Jan 4, 2023 at 5:40 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>> Oh, is the device backend not known at compile time?
>>>>> Currently it is known at compile time.
>>>> Are you sure? I don't think it is known at compile time.
>>>>   Thanks,
>>>>      Matt
>>>>> Or multiple backends can be alive at once?
>>>>> Some petsc developers (Jed and Barry) want to support this, but we are
>>>>> incapable now.
>>>>>> On Wed, Jan 4, 2023, 6:27 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>>>> wrote:
>>>>>>> On Wed, Jan 4, 2023 at 5:19 PM Mark Lohry <mlohry at gmail.com> wrote:
>>>>>>>> Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then
>>>>>>>>> we would need another for MATMPIAIJCUSPARSE, and then for HIPSPARSE on AMD
>>>>>>>>> GPUs, ...
>>>>>>>> Wouldn't one function suffice? Assuming these are contiguous arrays
>>>>>>>> in CSR format, they're just raw device pointers in all cases.
>>>>>>> But we need to know what device it is (to dispatch to either
>>>>>>> petsc-CUDA or petsc-HIP backend)
>>>>>>>> On Wed, Jan 4, 2023 at 6:02 PM Junchao Zhang <
>>>>>>>>> No, we don't have a counterpart of MatCreateSeqAIJWithArrays() for
>>>>>>>>> GPUs. Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we
>>>>>>>>> GPUs, ...
>>>>>>>>> The real problem I think is to deal with multiple MPI ranks.
>>>>>>>>> Providing the split arrays for petsc MATMPIAIJ is not easy and thus is
>>>>>>>>> discouraged for users to do so.
>>>>>>>>> memory, then you call MatSeqAIJCUSPARSEGetArray() to get the array and fill
>>>>>>>>> it up.
>>>>>>>>> We recently added routines to support matrix assembly on GPUs, see
>>>>>>>>> if MatSetValuesCOO
>>>>>>>>> <https://petsc.org/release/docs/manualpages/Mat/MatSetValuesCOO/>
>>>>>>>>>  helps
>>>>>>>>> --Junchao Zhang
>>>>>>>>> On Wed, Jan 4, 2023 at 2:22 PM Mark Lohry <mlohry at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> I have a sparse matrix constructed in non-petsc code using a
>>>>>>>>>> standard CSR representation where I compute the Jacobian to be used in an
>>>>>>>>>> implicit TS context. In the CPU world I call
>>>>>>>>>> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrows, ncols,
>>>>>>>>>> rowidxptr, colidxptr, valptr, Jac);
>>>>>>>>>> which as I understand it -- (1) never copies/allocates that
>>>>>>>>>> information, and the matrix Jac is just a non-owning view into the already
>>>>>>>>>> allocated CSR, (2) I can write directly into the original data structures
>>>>>>>>>> and the Mat just "knows" about it, although it still needs a call to
>>>>>>>>>> MatAssemblyBegin/MatAssemblyEnd after modifying the values. So far this
>>>>>>>>>> works great with GAMG.
>>>>>>>>>> I have the same CSR representation filled in GPU data allocated
>>>>>>>>>> with cudaMalloc and filled on-device. Is there an equivalent Mat
>>>>>>>>>> constructor for GPU arrays, or some other way to avoid unnecessary copies?
>>>>>>>>>> Thanks,
>>>>>>>>>> Mark
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230105/b0977918/attachment.html>
