[petsc-users] MatCreateSeqAIJWithArrays for GPU / cusparse
Junchao Zhang junchao.zhang at gmail.com
Wed Jan 4 17:02:20 CST 2023
No, we don't have a counterpart of MatCreateSeqAIJWithArrays() for GPUs.
Maybe we could add a MatCreateSeqAIJCUSPARSEWithArrays(), but then we would
need another for MATMPIAIJCUSPARSE, and then for HIPSPARSE on AMD GPUs, ...
The real problem I think is to deal with multiple MPI ranks. Providing the
split arrays for petsc MATMPIAIJ is not easy and thus is discouraged for
users to do so.
A workaround is to let petsc build the matrix and allocate the memory, then
you call MatSeqAIJCUSPARSEGetArray() to get the array and fill it up.
We recently added routines to support matrix assembly on GPUs, see if
MatSetValuesCOO
<https://petsc.org/release/docs/manualpages/Mat/MatSetValuesCOO/> helps
--Junchao Zhang
On Wed, Jan 4, 2023 at 2:22 PM Mark Lohry <mlohry at gmail.com> wrote:
> I have a sparse matrix constructed in non-petsc code using a standard CSR
> representation where I compute the Jacobian to be used in an implicit TS
> context. In the CPU world I call
> MatCreateSeqAIJWithArrays(PETSC_COMM_WORLD, nrows, ncols, rowidxptr,
> colidxptr, valptr, Jac);
> which as I understand it -- (1) never copies/allocates that information,
> and the matrix Jac is just a non-owning view into the already allocated
> CSR, (2) I can write directly into the original data structures and the Mat
> just "knows" about it, although it still needs a call to
> MatAssemblyBegin/MatAssemblyEnd after modifying the values. So far this
> works great with GAMG.
> I have the same CSR representation filled in GPU data allocated with
> cudaMalloc and filled on-device. Is there an equivalent Mat constructor for
> GPU arrays, or some other way to avoid unnecessary copies?
> Thanks,
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230104/7d5f7189/attachment-0001.html>
