[petsc-users] Question - about the 'Hint for performance tuning'
김성익 ksi2443 at gmail.com
Tue Jan 3 06:22:42 CST 2023
2023년 1월 3일 (화) 오후 8:55, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Tue, Jan 3, 2023 at 12:48 AM 김성익 <ksi2443 at gmail.com> wrote:
>> I got more questions so I resend this email with more questions.
>> 1.After reconfigure by
>> ./arch-main-debug/lib/petsc/conf/reconfigure-arch-main-debug.py
>> --with-debugging=0 --PETSC_ARCH=arch-main-opt ,
>> I tried to build my code.
>> But I got an error as below
>> [image: image.png]
>> How can I fix this?
> You reconfigured with PETSC_ARCH=arch-main-opt, but your build is using
> "arch-linux-c-opt". Why are you changing it?
At first Matthew told me use
'./arch-main-debug/lib/petsc/conf/reconfigure-arch-main-debug.py
--with-debugging=0 --PETSC_ARCH=arch-main-opt' for build optimized.
However, I got an error the error is as below.
[image: image.png]
So Barry told me : "The previous value of PETSC_ARCH was not
arch-main-debug do ls $PETSC_DIR and locate the directory whose name begins
with arch- that will tell you the previous value used for PETSC_ARCH."
So I used
"./arch-linux-c-debug/lib/petsc/conf/reconfigure-arch-linux-c-debug.py
--with-debugging=0 --PETSC_ARCH=arch-linux-c-opt"
That command worked. However I got an error when I build my code and the
error is as below.
[image: image.png]
>> 2.
>> CFLAGS       = -O3
>> FFLAGS       =
>> CPPFLAGS         =
>> FPPFLAGS         =
>> COPTFLAGS        = -march=native
>> app : a1.o a2.o a3.o a4.o
>>    $(LINK.C) -o $@ $^ $(LDLIBS)
>> include ${PETSC_DIR}/lib/petsc/conf/rules
>> include ${PETSC_DIR}/lib/petsc/conf/test
>> Upper makefile is just for build my own code not for src of petsc.
>> In this case, also has problem as your comments?
> I do not understand your question.
My questions is :
When building my own code without reconfigure of PETSc, I wonder if there
will be performance improvement by building with the high optimization
level of compiler even if the makefile is configured as above.
>> 3.  I have no such processors. Where can I find benchmark information
>> about STREAMS?
>>  I mean I don't have such various processors. So I just wondering the
>> results of STREAMS each processors (already existing results of various
>> processors).
>> Can anyone have results of benchmark of various desktop systems?
> There are catalogues of STREAMS results online.
Sorry, I can't find proper catalogues. What's the keyword for googling or
could you please give a link of catalogues?
Hyung Kim
>   Thanks,
>      Matt
>> Thanks,
>> Hyung Kim
>> 2023년 1월 3일 (화) 오후 2:19, 김성익 <ksi2443 at gmail.com>님이 작성:
>>> [image: image.png]
>>> How can I fix this?
>>> 2023년 1월 3일 (화) 오전 4:05, Barry Smith <bsmith at petsc.dev>님이 작성:
>>>> On Jan 2, 2023, at 9:27 AM, 김성익 <ksi2443 at gmail.com> wrote:
>>>> There are more questions.
>>>> 1. Following your comments, but there is an error as below.
>>>> <image.png>
>>>> How can I fix this?
>>>>    The previous value of PETSC_ARCH was not arch-main-debug do ls
>>>> $PETSC_DIR and locate the directory whose name begins with arch- that will
>>>> 2. After changing the optimized build, then how can I set the debug
>>>> mode again?
>>>>    export PETSC_ARCH=arch- whatever the previous value was and then
>>>> recompile your code (note you do not need to recompile PETSc just your
>>>> executable).
>>>> 3.Following your comments, the new makefile is as below. Is it right?
>>>> CFLAGS       = -O3
>>>> FFLAGS       =
>>>> CPPFLAGS         =
>>>> FPPFLAGS         =
>>>> Best not to set these values in the makefile at all because they will
>>>> affect all compilers. Just set them with ./configure CCOPTFLAGS="-O3
>>>> -march=native"
>>>> 4. I have no such processors. Where can I find benchmark information
>>>> about STREAMS?
>>>>   do make mpistreams in PETSC_DIR
>>>> Thanks,
>>>> Hyung Kim
>>>> 2023년 1월 2일 (월) 오후 11:03, Matthew Knepley <knepley at gmail.com>님이 작성:
>>>>> On Mon, Jan 2, 2023 at 4:16 AM 김성익 <ksi2443 at gmail.com> wrote:
>>>>>> Hello,
>>>>>> Happy new year!!
>>>>>> I have some questions about “Hint for performance tuning” in user
>>>>>> guide of petsc.
>>>>>> 1.     In the “Performance Pitfalls and Advice” section, there are 2
>>>>>> modes “debug” and “optimized builds. My current setup is debug mode. So I
>>>>>> want to change for test the performance the optimized build mode. However,
>>>>>> if I configure again, does the existing debug mode disappear? Is there any
>>>>>> way to coexist the 2 modes and use them in the run the application?
>>>>> Suppose your current arch is named "arch-main-debug". Then you can
>>>>> make an optimized version using
>>>>>   cd $PETSC_DIR
>>>>>> 2.     In the guide, there are some paragraphs about optimization
>>>>>> level of compiler. To control the optimization level of compiler, I put the
>>>>>> ‘-O3’ as below. Is this right??
>>>>>> CFLAGS       = -O3
>>>>>> FFLAGS       =
>>>>>> CPPFLAGS         =
>>>>>> FPPFLAGS         =
>>>>> You could dp this, but that only changes it for that directory. It is
>>>>> best to do it by reconfiguring.
>>>>>> 3.     In the guide, user should put ‘-march=native’ for using AVX2
>>>>>> or AVX-512. Where should I put the ‘-march=native’ for using AVX?
>>>>> You can add --COPTFLAGS="<user flags>" with any flags you want to the
>>>>> configure.
>>>>> 4.     After read the “Hint for performance tuning” I understood that
>>>>>> for good performance and scalability user should use the multiple node and
>>>>>> multiple socket . However, before composing cluster system, many users just
>>>>>> can use desktop system.
>>>>>> In that case, between intel 13th i9 and amd ryzen 7950x, can the
>>>>>> 7950x, which has an arichitecture similar to the server processor, be more
>>>>>> suitable for petsc? (Because the architecture of intel desktop cpu is
>>>>>> big.little.)
>>>>> A good guide is to run the STREAMS benchmark on the processor. PETSc
>>>>> performance closely tracks that.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Hyung Kim
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230103/2e9b6357/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230103/2e9b6357/attachment-0003.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230103/2e9b6357/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230103/2e9b6357/attachment-0005.png>
