[petsc-users] How to use DM_BOUNDARY_GHOSTED for Dirichlet boundary conditions
Barry Smith bsmith at petsc.dev
Tue Feb 28 22:38:29 CST 2023
   Ok, here is the situation. The command line options as given do not result in multigrid quality convergence in any of the runs; the error contraction factor is around .94 (meaning that for the modes that the multigrid algorithm does the worst on it only removes about 6 percent of them per iteration).
   But this is hidden by the initial right hand side for the linear system as written in ex45.c which has O(h) values on the boundary nodes and O(h^3) values on the interior nodes. The first iterations are largely working on the boundary residual and making great progress attacking that so that it looks like the one has a good error contraction factor. One then sees the error contraction factor start to get worse and worse for the later iterations. With the 0 on the boundary the iterations quickly get to the bad regime where the error contraction factor is near one. One can see this by using a -ksp_rtol 1.e-12 and having the MG code print the residual decrease for each iteration. Thought it appears the 0 boundary condition one converges much slower (since it requires many more iterations) if you factor out the huge advantage of the nonzero boundary condition case at the beginning (in terms of decreasing the residual) you see they both have an asymptotic error contraction factor of around .94 (which is horrible for multigrid).
   I now add -mg_levels_ksp_richardson_scale .9 -mg_coarse_ksp_richardson_scale .9 and rerun the two cases (nonzero and zero boundary right hand side) they take 35 and 41 iterations (much better)
initial residual norm 14.6993
next residual norm 0.84167 0.0572591
next residual norm 0.0665392 0.00452668
next residual norm 0.0307273 0.00209039
next residual norm 0.0158949 0.00108134
next residual norm 0.00825189 0.000561378
next residual norm 0.00428474 0.000291492
next residual norm 0.00222482 0.000151355
next residual norm 0.00115522 7.85898e-05
next residual norm 0.000599836 4.0807e-05
next residual norm 0.000311459 2.11887e-05
next residual norm 0.000161722 1.1002e-05
next residual norm 8.39727e-05 5.71269e-06
next residual norm 4.3602e-05 2.96626e-06
next residual norm 2.26399e-05 1.5402e-06
next residual norm 1.17556e-05 7.99735e-07
next residual norm 6.10397e-06 4.15255e-07
next residual norm 3.16943e-06 2.15617e-07
next residual norm 1.64569e-06 1.11957e-07
next residual norm 8.54511e-07 5.81326e-08
next residual norm 4.43697e-07 3.01848e-08
next residual norm 2.30385e-07 1.56732e-08
next residual norm 1.19625e-07 8.13815e-09
next residual norm 6.21143e-08 4.22566e-09
next residual norm 3.22523e-08 2.19413e-09
next residual norm 1.67467e-08 1.13928e-09
next residual norm 8.69555e-09 5.91561e-10
next residual norm 4.51508e-09 3.07162e-10
next residual norm 2.34441e-09 1.59491e-10
next residual norm 1.21731e-09 8.28143e-11
next residual norm 6.32079e-10 4.30005e-11
next residual norm 3.28201e-10 2.23276e-11
next residual norm 1.70415e-10 1.15934e-11
next residual norm 8.84865e-11 6.01976e-12
next residual norm 4.59457e-11 3.1257e-12
next residual norm 2.38569e-11 1.62299e-12
next residual norm 1.23875e-11 8.42724e-13
Linear solve converged due to CONVERGED_RTOL iterations 35
Residual norm 1.23875e-11
initial residual norm 172.601
next residual norm 154.803 0.896887
next residual norm 66.9409 0.387837
next residual norm 34.4572 0.199636
next residual norm 17.8836 0.103612
next residual norm 9.28582 0.0537995
next residual norm 4.82161 0.027935
next residual norm 2.50358 0.014505
next residual norm 1.29996 0.0075316
next residual norm 0.674992 0.00391071
next residual norm 0.350483 0.0020306
next residual norm 0.181985 0.00105437
next residual norm 0.094494 0.000547472
next residual norm 0.0490651 0.000284269
next residual norm 0.0254766 0.000147604
next residual norm 0.0132285 7.6642e-05
next residual norm 0.00686876 3.97956e-05
next residual norm 0.00356654 2.06635e-05
next residual norm 0.00185189 1.07293e-05
next residual norm 0.000961576 5.5711e-06
next residual norm 0.000499289 2.89274e-06
next residual norm 0.000259251 1.50203e-06
next residual norm 0.000134614 7.79914e-07
next residual norm 6.98969e-05 4.04963e-07
next residual norm 3.62933e-05 2.10273e-07
next residual norm 1.88449e-05 1.09182e-07
next residual norm 9.78505e-06 5.66919e-08
next residual norm 5.0808e-06 2.94367e-08
next residual norm 2.63815e-06 1.52847e-08
next residual norm 1.36984e-06 7.93645e-09
next residual norm 7.11275e-07 4.12093e-09
next residual norm 3.69322e-07 2.13975e-09
next residual norm 1.91767e-07 1.11105e-09
next residual norm 9.95733e-08 5.769e-10
next residual norm 5.17024e-08 2.99549e-10
next residual norm 2.6846e-08 1.55538e-10
next residual norm 1.39395e-08 8.07615e-11
next residual norm 7.23798e-09 4.19348e-11
next residual norm 3.75824e-09 2.17742e-11
next residual norm 1.95138e-09 1.13058e-11
next residual norm 1.01327e-09 5.87059e-12
next residual norm 5.26184e-10 3.04856e-12
next residual norm 2.73182e-10 1.58274e-12
next residual norm 1.41806e-10 8.21586e-13
Linear solve converged due to CONVERGED_RTOL iterations 42
Residual norm 1.41806e-10
Notice in the first run the residual norm still dives much more quickly for the first 2 iterations than the second run. This is because the first run has "lucky error" that gets wiped out easily from the big boundary term. After that you can see that the convergence for both is very similar with both having a reasonable error contraction factor of .51
I' ve attached the modified src/ksp/pc/impls/mg/mg.c that prints the residuals along the way.
One can also play games with the scaling factor used for the boundary nodes; I did a quick parameter sweep and found using 8 (instead of 2) in front of the diagonal matrix entry and the right hand side for the boundary nodes resulting in even better convergence; about half the number of iterations than the 35 and 41 above.
So I do stand corrected; it is possible that using non-zero Dirichlet boundary conditions  (compared to zero) can affect the "convergence" of the multigrid method (especially without a Krylov accelerator) in the NON-asymptotic regime when comparing the residual norms and using relative residual norm decrease as the convergence criteria.
If you wish to compare, for example, ex45.c with a code that does not incorporate the Dirichlet boundary nodes in the linear system you can just use 0 boundary conditions for both codes.
Barry
> On Feb 28, 2023, at 2:05 PM, Große-Bley, Paul <rz230 at uni-heidelberg.de> wrote:
> Sorry, I should have made myself more clear. I changed the three 7 passed to DMDACreate3d to 33 to make the example a bit more realistic, as I also use "U-cycles", i.e. my coarsest level is still big enough to make use of some GPU parallelism. I should have just put that into the given command line argument string with -da_grid_x 33 -da_grid_y 33 -da_grid_z 33
> On 2/28/23 18:43, Barry Smith wrote:
>>    I am sorry, I cannot reproduce what you describe. I am using src/ksp/ksp/tutorials/ex45.c in the main branch (should be same as release for this purpose).
>>    No change to the code I get
>> $ ./ex45 -ksp_converged_reason -ksp_type richardson -ksp_rtol 1e-09 -pc_type mg -pc_mg_levels 3 -mg_levels_ksp_type richardson -mg_levels_ksp_max_it 6 -mg_levels_ksp_converged_maxits -mg_levels_pc_type jacobi -mg_coarse_ksp_type richardson -mg_coarse_ksp_max_it 6 -mg_coarse_ksp_converged_maxits -mg_coarse_pc_type jacobi -ksp_monitor_true_residual -ksp_view
>>   0 KSP preconditioned resid norm 1.851257578045e+01 true resid norm 1.476491378857e+01 ||r(i)||/||b|| 1.000000000000e+00
>>   1 KSP preconditioned resid norm 3.720545622095e-01 true resid norm 5.171053311198e-02 ||r(i)||/||b|| 3.502257707188e-03
>>   2 KSP preconditioned resid norm 1.339047557616e-02 true resid norm 1.866765310863e-03 ||r(i)||/||b|| 1.264325235890e-04
>>   3 KSP preconditioned resid norm 4.833887599029e-04 true resid norm 6.867629264754e-05 ||r(i)||/||b|| 4.651316873974e-06
>>   4 KSP preconditioned resid norm 1.748167886388e-05 true resid norm 3.398334857479e-06 ||r(i)||/||b|| 2.301628648933e-07
>>   5 KSP preconditioned resid norm 6.570567424652e-07 true resid norm 4.304483984231e-07 ||r(i)||/||b|| 2.915346507180e-08
>>   6 KSP preconditioned resid norm 4.013427896557e-08 true resid norm 7.502068698790e-08 ||r(i)||/||b|| 5.081010838410e-09
>>   7 KSP preconditioned resid norm 5.934811016347e-09 true resid norm 1.333884145638e-08 ||r(i)||/||b|| 9.034147877457e-10
>> Linear solve converged due to CONVERGED_RTOL iterations 7
>> KSP Object: 1 MPI process
>>   type: richardson
>>     damping factor=1.
>>   maximum iterations=10000, nonzero initial guess
>>   tolerances:  relative=1e-09, absolute=1e-50, divergence=10000.
>>   left preconditioning
>>   using PRECONDITIONED norm type for convergence test
>> PC Object: 1 MPI process
>>   type: mg
>>     type is MULTIPLICATIVE, levels=3 cycles=v
>>       Cycles per PCApply=1
>>       Not using Galerkin computed coarse grid matrices
>>   Coarse grid solver -- level 0 -------------------------------
>>     KSP Object: (mg_coarse_) 1 MPI process
>>       type: richardson
>>         damping factor=1.
>>       maximum iterations=6, nonzero initial guess
>>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>>     PC Object: (mg_coarse_) 1 MPI process
>>       type: jacobi
>>         type DIAGONAL
>>       linear system matrix = precond matrix:
>>       Mat Object: 1 MPI process
>>         type: seqaij
>>         rows=8, cols=8
>>         total: nonzeros=32, allocated nonzeros=32
>>         total number of mallocs used during MatSetValues calls=0
>>           not using I-node routines
>>   Down solver (pre-smoother) on level 1 -------------------------------
>>     KSP Object: (mg_levels_1_) 1 MPI process
>>       type: richardson
>>         damping factor=1.
>>       using NONE norm type for convergence test
>>     PC Object: (mg_levels_1_) 1 MPI process
>>       type: jacobi
>>         type DIAGONAL
>>         type: seqaij
>>         rows=64, cols=64
>>         total: nonzeros=352, allocated nonzeros=352
>>   Up solver (post-smoother) same as down solver (pre-smoother)
>>   Down solver (pre-smoother) on level 2 -------------------------------
>>     KSP Object: (mg_levels_2_) 1 MPI process
>>       type: richardson
>>         damping factor=1.
>>     PC Object: (mg_levels_2_) 1 MPI process
>>       type: jacobi
>>         type DIAGONAL
>>         type: seqaij
>>         rows=343, cols=343
>>         total: nonzeros=2107, allocated nonzeros=2107
>>     type: seqaij
>>     rows=343, cols=343
>> Residual norm 1.33388e-08
>> ~/Src/petsc/src/ksp/ksp/tutorials (main=) arch-main
>>    Now change code with
>>         if (i == 0 || j == 0 || k == 0 || i == mx - 1 || j == my - 1 || k == mz - 1) {
>>           barray[k][j][i] = 0; //2.0 * (HxHydHz + HxHzdHy + HyHzdHx);
>>         } else {
>>           barray[k][j][i] = 1; //Hx * Hy * Hz;
>>   I do not understand where I am suppose to change the dimension to 33 so I ignore that statement. Same command line with change above gives
>>   0 KSP preconditioned resid norm 7.292257119299e+01 true resid norm 1.118033988750e+01 ||r(i)||/||b|| 1.000000000000e+00
>>   1 KSP preconditioned resid norm 2.534913491362e+00 true resid norm 3.528425353826e-01 ||r(i)||/||b|| 3.155919577875e-02
>>   2 KSP preconditioned resid norm 9.145057509152e-02 true resid norm 1.279725352471e-02 ||r(i)||/||b|| 1.144621152262e-03
>>   3 KSP preconditioned resid norm 3.302446009474e-03 true resid norm 5.122622088691e-04 ||r(i)||/||b|| 4.581812485342e-05
>>   4 KSP preconditioned resid norm 1.204504429329e-04 true resid norm 4.370692051248e-05 ||r(i)||/||b|| 3.909265814124e-06
>>   5 KSP preconditioned resid norm 5.339971695523e-06 true resid norm 7.229991776815e-06 ||r(i)||/||b|| 6.466701235889e-07
>>   6 KSP preconditioned resid norm 5.856425044706e-07 true resid norm 1.282860114273e-06 ||r(i)||/||b|| 1.147424968455e-07
>>   7 KSP preconditioned resid norm 1.007137752126e-07 true resid norm 2.283009757390e-07 ||r(i)||/||b|| 2.041986004328e-08
>>   8 KSP preconditioned resid norm 1.790021892548e-08 true resid norm 4.063263596129e-08 ||r(i)||/||b|| 3.634293444578e-09
>> Linear solve converged due to CONVERGED_RTOL iterations 8
>>   type: richardson
>>     damping factor=1.
>>   type: mg
>>       type: richardson
>>         damping factor=1.
>>       type: jacobi
>>         type DIAGONAL
>>         type: seqaij
>>         rows=8, cols=8
>>       type: richardson
>>         damping factor=1.
>>       type: jacobi
>>         type DIAGONAL
>>         type: seqaij
>>         rows=64, cols=64
>>       type: richardson
>>         damping factor=1.
>>       type: jacobi
>>         type DIAGONAL
>>         type: seqaij
>>         rows=343, cols=343
>>     type: seqaij
>>     rows=343, cols=343
>> Residual norm 4.06326e-08
>> ~/Src/petsc/src/ksp/ksp/tutorials (main *=) arch-main
>> In neither case is it taking 25 iterations. What am I doing wrong?
>> Normally one expects only trivial changes in the convergence of multigrid methods when one changes values in the right hand side as with the run above.
>> Barry
>>> On Feb 27, 2023, at 7:16 PM, Paul Grosse-Bley <paul.grosse-bley at ziti.uni-heidelberg.de> <mailto:paul.grosse-bley at ziti.uni-heidelberg.de> wrote:
>>> The scaling might be the problem, especially since I don't know what you mean by scaling it according to FE.
>>> For reproducing the issue with a smaller problem:
>>> Change the ComputeRHS function in ex45.c
>>>   barray[k][j][i] = 0.0;
>>> } else {
>>>   barray[k][j][i] = 1.0;
>>> Change the dimensions to e.g. 33 (I scaled it down, so it goes quick without a GPU) instead of 7 and then run with
>>> You will find that it takes 145 iterations instead of 25 for the original ex45 RHS. My hpgmg-cuda implementation (using 32^3) takes 41 iterations.
>>> To what do I have to change the diagonal entries of the matrix for the boundary according to FE? Right now the diagonal is completely constant.
>>> Paul
>>> On Tuesday, February 28, 2023 00:23 CET, Barry Smith <bsmith at petsc.dev> <mailto:bsmith at petsc.dev> wrote:
>>>> I have not seen explicitly including, or excluding, the Dirichlet boundary values in the system having a significant affect on the convergence so long as you SCALE the diagonal rows (of those Dirichlet points) by a value similar to the other entries along the diagonal. If they are scaled completely differently, that can screw up the convergence. For src/ksp/ksp/ex45.c I see that the appropriate scaling is used (note the scaling should come from a finite element view of the discretization even if the discretization is finite differences as is done in ex45.c)
>>>> Are you willing to share the two codes so we can take a look with experienced eyes to try to figure out the difference?
>>>> Barry
>>>> > On Feb 27, 2023, at 5:48 PM, Paul Grosse-Bley <paul.grosse-bley at ziti.uni-heidelberg.de> <mailto:paul.grosse-bley at ziti.uni-heidelberg.de> wrote:
>>>> > Hi Barry,
>>>> > the reason why I wanted to change to ghost boundaries is that I was worrying about the effect of PCMGs coarsening on these boundary values.
>>>> > As mentioned before, I am trying to reproduce results from the hpgmg-cuda benchmark (a modified version of it, e.g. using 2nd order instead of 4th etc.).
>>>> > I am trying to solve the Poisson equation -\nabla^2 u = 1 with u = 0 on the boundary with rtol=1e-9. While my MG solver implemented in hpgmg solves this in 40 V-cycles (I weakened it a lot by only doing smooths at the coarse level instead of CG). When I run the "same" MG solver built in PETSc on this problem, it starts out reducing the residual norm as fast or even faster for the first 20-30 iterations. But for the last order of magnitude in the residual norm it needs more than 300 V-cycles, i.e. it gets very slow. At this point I am pretty much out of ideas about what is the cause, especially since e.g. adding back cg at the coarsest level doesn't seem to change the number of iterations at all. Therefore I am suspecting the discretization to be the problem. HPGMG uses an even number of points per dimension (e.g. 256), while PCMG wants an odd number (e.g. 257). So I also tried adding another layer of boundary values for the discretization to effectively use only 254 points per dimension. This caused the solver to get even slightly worse.
>>>> > So can the explicit boundary values screw with the coarsening, especially when they are not finite? Because with the problem as stated in ex45 with finite (i.e. non-zero) boundary values, the MG solver takes only 18 V-cycles.
>>>> > Best,
>>>> > Paul
>>>> > On Monday, February 27, 2023 18:17 CET, Barry Smith <bsmith at petsc.dev> <mailto:bsmith at petsc.dev> wrote:
>>>> >> Paul,
>>>> >> DM_BOUNDARY_GHOSTED would result in the extra ghost locations in the local vectors (obtained with DMCreateLocalVector() but they will not appear in the global vectors obtained with DMCreateGlobalVector(); perhaps this is the issue? Since they do not appear in the global vector they will not appear in the linear system so there will be no diagonal entries for you to set since those rows/columns do not exist in the linear system. In other words, using DM_BOUNDARY_GHOSTED is a way to avoid needing to put the Dirichlet values explicitly into the system being solved; DM_BOUNDARY_GHOSTED is generally more helpful for nonlinear systems than linear systems.
>>>> >> Barry
>>>> >> > On Feb 27, 2023, at 12:08 PM, Paul Grosse-Bley <paul.grosse-bley at ziti.uni-heidelberg.de> <mailto:paul.grosse-bley at ziti.uni-heidelberg.de> wrote:
>>>> >> > Hi,
>>>> >> > I would like to modify src/ksp/ksp/tutorials/ex45.c to implement Dirichlet boundary conditions using DM_BOUNDARY_GHOSTED instead of using DM_BOUNDARY_NONE and explicitly implementing the boundary by adding diagnonal-only rows.
>>>> >> > My assumption was that with DM_BOUNDARY_GHOSTED all vectors from that DM have the extra memory for the ghost entries and that I can basically use DMDAGetGhostCorners instead of DMDAGetCorners to access the array gotten via DMDAVecGetArray. But when I access (gxs, gys, gzs) = (-1,-1,-1) I get a segmentation fault. When looking at the implementation of DMDAVecGetArray it looked to me as if accessing (-1, -1, -1) should work as DMDAVecGetArray passes the ghost corners to VecGetArray3d which then adds the right offsets.
>>>> >> > I could not find any example using DM_BOUNDARY_GHOSTED and then actually accessing the ghost/boundary elements. Can I assume that they are set to zero for the solution vector, i.e. the u=0 on \del\Omega and I do not need to access them at all?
>>>> >> > Best,
>>>> >> > Paul Große-Bley
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230228/3fc2c424/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230228/3fc2c424/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230228/3fc2c424/attachment-0003.html>
