[petsc-users] Inquiry regarding DMAdaptLabel function
Pierre Jolivet
pierre at joliv.et
Mon Feb 27 09:13:37 CST 2023
> On 27 Feb 2023, at 3:59 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Feb 27, 2023 at 9:53 AM Zongze Yang <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> wrote:
>> Hi, Matt,
>> I tested coarsening a mesh by using ParMMg without firedrake, and found some issues:
>> see the code and results here: https://gitlab.com/petsc/petsc/-/issues/1331
>> Could you have a look and give some comments or suggestions?
> I replied on the issue. More generally, the adaptive refinement software has not seen wide use
Matt probably meant “the _DMPlex interface_ to adaptive refinement software has not seen wide use”, Mmg has been rather widely used for 10+ years (here is a 13-year old presentation https://www.ljll.math.upmc.fr/hecht/ftp/ff++days/2010/exposes/Morice-MeshMetric.pdf).
Pierre
> , and I expect
> more of these kinds of bugs until more people use it.
> Thanks,
> Matt
>> Best wishes,
>> Zongze
>> On Mon, 27 Feb 2023 at 20:19, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> On Sat, Feb 18, 2023 at 6:41 AM Zongze Yang <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> wrote:
>>>> Another question on mesh coarsening is about `DMCoarsen` which will fail when running in parallel.
>>>> I generate a mesh in Firedrake, and then create function space and functions, after that, I get the dmplex and coarsen it.
>>>> When running in serials, I get the mesh coarsened correctly. But it failed with errors in ParMMG when running parallel.
>>>> However, If I did not create function space and functions on the original mesh, everything works fine too.
>>>> The code and the error logs are attached.
>>> I believe the problem is that Firedrake and PETSc currently have incompatible coordinate spaces. We are working
>>> to fix this, and I expect it to work by this summer.
>>> Thanks,
>>> Matt
>>>> Thank you for your time and attention。
>>>> Best wishes,
>>>> Zongze
>>>> On Sat, 18 Feb 2023 at 15:24, Zongze Yang <yangzongze at gmail.com <mailto:yangzongze at gmail.com>> wrote:
>>>>> Dear PETSc Group,
>>>>> I am writing to inquire about the function DMAdaptLabel in PETSc.
>>>>> I am trying to use it coarse a mesh, but the resulting mesh is refined.
>>>>> In the following code, all of the `adpat` label values were set to 2 (DM_ADAPT_COARSEN).
>>>>> There must be something wrong. Could you give some suggestions?
>>>>> ```python
>>>>> from firedrake import *
>>>>> from firedrake.petsc import PETSc
>>>>> def mark_all_cells(mesh):
>>>>> plex = mesh.topology_dm
>>>>> with PETSc.Log.Event("ADD_ADAPT_LABEL"):
>>>>> plex.createLabel('adapt')
>>>>> cs, ce = plex.getHeightStratum(0)
>>>>> for i in range(cs, ce):
>>>>> plex.setLabelValue('adapt', i, 2)
>>>>> return plex
>>>>> mesh = RectangleMesh(10, 10, 1, 1)
>>>>> x = SpatialCoordinate(mesh)
>>>>> V = FunctionSpace(mesh, 'CG', 1)
>>>>> f = Function(V).interpolate(10 + 10*sin(x[0]))
>>>>> triplot(mesh)
>>>>> plex = mark_all_cells(mesh)
>>>>> new_plex = plex.adaptLabel('adapt')
>>>>> mesh = Mesh(new_plex)
>>>>> triplot(mesh)
>>>>> Thank you very much for your time.
>>>>> Best wishes,
>>>>> Zongze
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230227/a81e1ad6/attachment-0001.html>
