[petsc-users] Inquiry regarding DMAdaptLabel function
Zongze Yang
yangzongze at gmail.com
Mon Feb 27 08:53:29 CST 2023
Hi, Matt,
I tested coarsening a mesh by using ParMMg without firedrake, and found
some issues:
see the code and results here:
https://gitlab.com/petsc/petsc/-/issues/1331
Could you have a look and give some comments or suggestions?
Best wishes,
Zongze
On Mon, 27 Feb 2023 at 20:19, Matthew Knepley <knepley at gmail.com> wrote:
> On Sat, Feb 18, 2023 at 6:41 AM Zongze Yang <yangzongze at gmail.com> wrote:
>> Another question on mesh coarsening is about `DMCoarsen` which will fail
>> when running in parallel.
>> I generate a mesh in Firedrake, and then create function space and
>> functions, after that, I get the dmplex and coarsen it.
>> When running in serials, I get the mesh coarsened correctly. But it
>> failed with errors in ParMMG when running parallel.
>> However, If I did not create function space and functions on the original
>> mesh, everything works fine too.
>> The code and the error logs are attached.
> I believe the problem is that Firedrake and PETSc currently have
> incompatible coordinate spaces. We are working
> to fix this, and I expect it to work by this summer.
> Thanks,
> Matt
>> Thank you for your time and attention。
>> Best wishes,
>> Zongze
>> On Sat, 18 Feb 2023 at 15:24, Zongze Yang <yangzongze at gmail.com> wrote:
>>> Dear PETSc Group,
>>> I am writing to inquire about the function DMAdaptLabel in PETSc.
>>> I am trying to use it coarse a mesh, but the resulting mesh is refined.
>>> In the following code, all of the `adpat` label values were set to 2
>>> (DM_ADAPT_COARSEN).
>>> There must be something wrong. Could you give some suggestions?
>>> ```python
>>> from firedrake import *
>>> from firedrake.petsc import PETSc
>>> def mark_all_cells(mesh):
>>> plex = mesh.topology_dm
>>> with PETSc.Log.Event("ADD_ADAPT_LABEL"):
>>> plex.createLabel('adapt')
>>> cs, ce = plex.getHeightStratum(0)
>>> for i in range(cs, ce):
>>> plex.setLabelValue('adapt', i, 2)
>>> return plex
>>> mesh = RectangleMesh(10, 10, 1, 1)
>>> x = SpatialCoordinate(mesh)
>>> V = FunctionSpace(mesh, 'CG', 1)
>>> f = Function(V).interpolate(10 + 10*sin(x[0]))
>>> triplot(mesh)
>>> plex = mark_all_cells(mesh)
>>> new_plex = plex.adaptLabel('adapt')
>>> mesh = Mesh(new_plex)
>>> triplot(mesh)
>>> Thank you very much for your time.
>>> Best wishes,
>>> Zongze
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230227/fe0d068b/attachment-0001.html>
