[petsc-users] petsc compiled without MPI
Matthew Knepley
knepley at gmail.com
Mon Feb 27 07:46:03 CST 2023
On Mon, Feb 27, 2023 at 8:41 AM Long, Jianbo <jl7037 at mun.ca> wrote:
> Thanks for the explanations ! It turns out the issue of running
> sequentially compiled petsc is PetscFinalize() function. Since my
> subroutine involving petsc functions needs to be called multiple times in
> the program, I have to comment out PetscFinalize() at the end of the
> subroutine, otherwise at the next call of this subroutine, petsc would stop
> and throw out an error about MPI_Comm_set_errhandler !
Yes, you are supposed to call PetscInitialize() _once_ at the beginning of
the program, and PetscFinalize() _once_ at the end of the program.
Matt
> Jianbo
> On Sun, Feb 26, 2023 at 4:39 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> On Sun, 26 Feb 2023, Pierre Jolivet wrote:
>> > > On 25 Feb 2023, at 11:44 PM, Long, Jianbo <jl7037 at mun.ca> wrote:
>> > > Hello,
>> > > For some of my applications, I need to use petsc without mpi, or use
>> it sequentially. I wonder where I can find examples/tutorials for this ?
>> > You can run sequentially with just a single MPI process (-n 1).
>> even if you build with mpich/openmpi - you can run sequentially without
>> mpiexec - i.e:
>> ./binary
>> One reason to do this [instead of building PETSc with --with-mpi=0] - is
>> if you are mixing in multiple pkgs that have MPI dependencies [in which
>> case - its best to build all these pkgs with the same mpich or openmpi -
>> but still run sequentially].
>> Satish
>> > If you need to run without MPI whatsoever, you’ll need to have a
>> separate PETSc installation which was configured --with-mpi=0
>> > In both cases, the same user-code will run, i.e., all PETSc examples
>> available with the sources will work (though some are designed purely for
>> parallel experiments and may error out early on purpose).
>> > Thanks,
>> > Pierre
>> > > Thanks very much,
>> > > Jianbo Long
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230227/82e9b274/attachment.html>
