[petsc-users] DMPlex Halo Communication or Graph Partitioner Issue
Matthew Knepley
knepley at gmail.com
Sun Feb 26 10:37:41 CST 2023
On Sun, Feb 26, 2023 at 11:32 AM Mike Michell <mi.mike1021 at gmail.com> wrote:
> This is what I get from petsc main which is not correct:
> Overall volume computed from median-dual ...
> 6.37050098781844
> Overall volume computed from PETSc ...
> 3.15470053800000
> This is what I get from petsc 3.18.4 which is correct:
> 3.15470053800000
> 3.15470053800000
> If there is a problem in the code, it is also strange for me that petsc
> 3.18.4 gives the correct answer
As I said, this can happen due to different layouts in memory. If you run
it under valgrind, or address sanitizer, you will see
that there is a problem.
Matt
> Thanks,
> Mike
>> On Sun, Feb 26, 2023 at 11:19 AM Mike Michell <mi.mike1021 at gmail.com>
>> wrote:
>>> Which version of petsc you tested? With petsc 3.18.4, median duan volume
>>> gives the same value with petsc from DMPlexComputeCellGeometryFVM().
>> This is only an accident of the data layout. The code you sent writes
>> over memory in the local Fortran arrays.
>> Thanks,
>> Matt
>>>> On Sat, Feb 25, 2023 at 3:11 PM Mike Michell <mi.mike1021 at gmail.com>
>>>> wrote:
>>>>> My apologies for the late follow-up. There was a time conflict.
>>>>> A simple example code related to the issue I mentioned is attached
>>>>> here. The sample code does: (1) load grid on dm, (2) compute vertex-wise
>>>>> control volume for each node in a median-dual way, (3) halo exchange among
>>>>> procs to have complete control volume values, and (4) print out its field
>>>>> as a .vtu file. To make sure, the computed control volume is also compared
>>>>> with PETSc-computed control volume via DMPlexComputeCellGeometryFVM() (see
>>>>> lines 771-793).
>>>>> Back to the original problem, I can get a proper control volume field
>>>>> with PETSc 3.18.4, which is the latest stable release. However, if I use
>>>>> PETSc from the main repo, it gives a strange control volume field.
>>>>> Something is certainly strange around the parallel boundaries, thus I think
>>>>> something went wrong with halo communication. To help understand, a
>>>>> comparing snapshot is also attached. I guess a certain part of my code is
>>>>> no longer compatible with PETSc unless there is a bug in the library. Could
>>>>> I get comments on it?
>>>> I can run your example. The numbers I get for "median-dual volume" do
>>>> not match the "PETSc volume", and the PETSc volume is correct. Moreover,
>>>> the median-dual numbers change, which suggests a memory fault. I compiled
>>>> it using address sanitizer, and it found an error:
>>>> Number of physical boundary edge ... 4 0
>>>> Number of physical and parallel boundary edge ... 4
>>>> 0
>>>> Number of parallel boundary edge ... 0 0
>>>> Number of physical boundary edge ... 4 1
>>>> 1
>>>> Number of parallel boundary edge ... 0 1
>>>> ==36587==ERROR: AddressSanitizer: heap-buffer-overflow on address
>>>> 0x603000022d40 at pc 0x0001068e12a8 bp 0x7ffee932cfd0 sp 0x7ffee932cfc8
>>>> READ of size 8 at 0x603000022d40 thread T0
>>>> ==36588==ERROR: AddressSanitizer: heap-buffer-overflow on address
>>>> 0x60300000f0f0 at pc 0x00010cf702a8 bp 0x7ffee2c9dfd0 sp 0x7ffee2c9dfc8
>>>> READ of size 8 at 0x60300000f0f0 thread T0
>>>> #0 0x10cf702a7 in MAIN__ test.F90:657
>>>> #1 0x10cf768ee in main test.F90:43
>>>> #0 0x1068e12a7 in MAIN__ test.F90:657
>>>> #1 0x1068e78ee in main test.F90:43
>>>> #2 0x7fff6b80acc8 in start (libdyld.dylib:x86_64+0x1acc8)
>>>> 0x60300000f0f0 is located 0 bytes to the right of 32-byte region
>>>> [0x60300000f0d0,0x60300000f0f0)
>>>> allocated by thread T0 here:
>>>> 0x603000022d40 is located 0 bytes to the right of 32-byte region
>>>> [0x603000022d20,0x603000022d40)
>>>> #0 0x114a7457f in wrap_malloc (libasan.5.dylib:x86_64+0x7b57f)
>>>> #1 0x1068dba71 in MAIN__ test.F90:499
>>>> #2 0x1068e78ee in main test.F90:43
>>>> #3 0x7fff6b80acc8 in start (libdyld.dylib:x86_64+0x1acc8)
>>>> SUMMARY: AddressSanitizer: heap-buffer-overflow test.F90:657 in MAIN__
>>>> Shadow bytes around the buggy address:
>>>> which corresponds to
>>>> ! midpoint of median-dual face for inner face
>>>> axrf(ifa,1) = 0.5d0*(yc(nc1)+yfc(ifa)) ! for nc1 cell
>>>> axrf(ifa,2) = 0.5d0*(yc(nc2)+yfc(ifa)) ! for nc2 cell
>>>> and these were allocated here
>>>> allocate(xc(ncell))
>>>> allocate(yc(ncell))
>>>> Hopefully the error is straightforward to see now.
>>>> Thanks,
>>>> Matt
>>>>> Thanks,
>>>>> Mike
>>>>>> On Mon, Feb 20, 2023 at 12:05 PM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Sat, Feb 18, 2023 at 12:00 PM Mike Michell <mi.mike1021 at gmail.com>
>>>>>>> wrote:
>>>>>>>> As a follow-up, I tested:
>>>>>>>> (1) Download tar for v3.18.4 from petsc gitlab (
>>>>>>>> https://gitlab.com/petsc/petsc/-/tree/v3.18.4) has no issue on
>>>>>>>> DMPlex halo exchange. This version works as I expect.
>>>>>>>> (2) Clone main branch (git clone https://gitlab.com/petsc/petsc.git)
>>>>>>>> has issues with DMPlex halo exchange. Something is suspicious about this
>>>>>>>> main branch, related to DMPlex halo. The solution field I got is not
>>>>>>>> correct. But it works okay with 1-proc.
>>>>>>>> Does anyone have any comments on this issue? I am curious if other
>>>>>>>> DMPlex users have no problem regarding halo exchange. FYI, I do not
>>>>>>>> declare ghost layers for halo exchange.
>>>>>>> There should not have been any changes there and there are
>>>>>>> definitely tests for this.
>>>>>>> It would be great if you could send something that failed. I could
>>>>>>> fix it and add it as a test.
>>>>>> Just to follow up, we have tests of the low-level communication (Plex
>>>>>> tests ex1, ex12, ex18, ex29, ex31), and then we have
>>>>>> tests that use halo exchange for PDE calculations, for example SNES
>>>>>> tutorial ex12, ex13, ex62. THe convergence rates
>>>>>> should be off if the halo exchange were wrong. Is there any example
>>>>>> similar to your code that is failing on your installation?
>>>>>> Or is there a way to run your code?
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Mike
>>>>>>>>> Dear PETSc team,
>>>>>>>>> I am using PETSc for Fortran with DMPlex. I have been using this
>>>>>>>>> version of PETSc:
>>>>>>>>> >>git rev-parse origin
>>>>>>>>> >>995ec06f924a86c4d28df68d1fdd6572768b0de1
>>>>>>>>> >>git rev-parse FETCH_HEAD
>>>>>>>>> >>9a04a86bf40bf893fb82f466a1bc8943d9bc2a6b
>>>>>>>>> There has been no issue, before the one with VTK viewer, which Jed
>>>>>>>>> fixed today (
>>>>>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/6081/diffs?commit_id=27ba695b8b62ee2bef0e5776c33883276a2a1735
>>>>>>>>> Since that MR has been merged into the main repo, I pulled the
>>>>>>>>> latest version of PETSc (basically I cloned it from scratch). But if I use
>>>>>>>>> the same configure option with before, and run my code, then there is an
>>>>>>>>> issue with halo exchange. The code runs without error message, but it gives
>>>>>>>>> wrong solution field. I guess the issue I have is related to graph
>>>>>>>>> partitioner or halo exchange part. This is because if I run the code with
>>>>>>>>> 1-proc, the solution is correct. I only updated the version of PETSc and
>>>>>>>>> there was no change in my own code. Could I get any comments on the issue?
>>>>>>>>> I was wondering if there have been many changes in halo exchange or graph
>>>>>>>>> partitioning & distributing part related to DMPlex.
>>>>>>>>> Thanks,
>>>>>>>>> Mike
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230226/7daff173/attachment.html>
