[petsc-users] DMPlex Halo Communication or Graph Partitioner Issue
Matthew Knepley
knepley at gmail.com
Sun Feb 26 08:01:41 CST 2023
On Sat, Feb 25, 2023 at 3:11 PM Mike Michell <mi.mike1021 at gmail.com> wrote:
> My apologies for the late follow-up. There was a time conflict.
> A simple example code related to the issue I mentioned is attached here.
> The sample code does: (1) load grid on dm, (2) compute vertex-wise control
> volume for each node in a median-dual way, (3) halo exchange among procs to
> have complete control volume values, and (4) print out its field as a .vtu
> file. To make sure, the computed control volume is also compared with
> PETSc-computed control volume via DMPlexComputeCellGeometryFVM() (see lines
> 771-793).
> Back to the original problem, I can get a proper control volume field with
> PETSc 3.18.4, which is the latest stable release. However, if I use PETSc
> from the main repo, it gives a strange control volume field. Something is
> certainly strange around the parallel boundaries, thus I think something
> went wrong with halo communication. To help understand, a comparing
> snapshot is also attached. I guess a certain part of my code is no longer
> compatible with PETSc unless there is a bug in the library. Could I get
> comments on it?
I can run your example. The numbers I get for "median-dual volume" do not
match the "PETSc volume", and the PETSc volume is correct. Moreover, the
median-dual numbers change, which suggests a memory fault. I compiled it
using address sanitizer, and it found an error:
Number of physical boundary edge ... 4 0
Number of physical and parallel boundary edge ... 4 0
Number of parallel boundary edge ... 0 0
Number of physical boundary edge ... 4 1
Number of physical and parallel boundary edge ... 4 1
Number of parallel boundary edge ... 0 1
==36587==ERROR: AddressSanitizer: heap-buffer-overflow on address
0x603000022d40 at pc 0x0001068e12a8 bp 0x7ffee932cfd0 sp 0x7ffee932cfc8
READ of size 8 at 0x603000022d40 thread T0
==36588==ERROR: AddressSanitizer: heap-buffer-overflow on address
0x60300000f0f0 at pc 0x00010cf702a8 bp 0x7ffee2c9dfd0 sp 0x7ffee2c9dfc8
READ of size 8 at 0x60300000f0f0 thread T0
#0 0x10cf702a7 in MAIN__ test.F90:657
#1 0x10cf768ee in main test.F90:43
#0 0x1068e12a7 in MAIN__ test.F90:657
#1 0x1068e78ee in main test.F90:43
#2 0x7fff6b80acc8 in start (libdyld.dylib:x86_64+0x1acc8)
0x60300000f0f0 is located 0 bytes to the right of 32-byte region
[0x60300000f0d0,0x60300000f0f0)
allocated by thread T0 here:
0x603000022d40 is located 0 bytes to the right of 32-byte region
[0x603000022d20,0x603000022d40)
#0 0x114a7457f in wrap_malloc (libasan.5.dylib:x86_64+0x7b57f)
#1 0x1068dba71 in MAIN__ test.F90:499
#2 0x1068e78ee in main test.F90:43
#3 0x7fff6b80acc8 in start (libdyld.dylib:x86_64+0x1acc8)
SUMMARY: AddressSanitizer: heap-buffer-overflow test.F90:657 in MAIN__
Shadow bytes around the buggy address:
which corresponds to
! midpoint of median-dual face for inner face
axrf(ifa,1) = 0.5d0*(yc(nc1)+yfc(ifa)) ! for nc1 cell
axrf(ifa,2) = 0.5d0*(yc(nc2)+yfc(ifa)) ! for nc2 cell
and these were allocated here
allocate(xc(ncell))
allocate(yc(ncell))
Hopefully the error is straightforward to see now.
Matt
> Thanks,
> Mike
>> On Mon, Feb 20, 2023 at 12:05 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Sat, Feb 18, 2023 at 12:00 PM Mike Michell <mi.mike1021 at gmail.com>
>>> wrote:
>>>> As a follow-up, I tested:
>>>> (1) Download tar for v3.18.4 from petsc gitlab (
>>>> https://gitlab.com/petsc/petsc/-/tree/v3.18.4) has no issue on DMPlex
>>>> halo exchange. This version works as I expect.
>>>> (2) Clone main branch (git clone https://gitlab.com/petsc/petsc.git)
>>>> has issues with DMPlex halo exchange. Something is suspicious about this
>>>> main branch, related to DMPlex halo. The solution field I got is not
>>>> correct. But it works okay with 1-proc.
>>>> Does anyone have any comments on this issue? I am curious if other
>>>> DMPlex users have no problem regarding halo exchange. FYI, I do not
>>>> declare ghost layers for halo exchange.
>>> There should not have been any changes there and there are definitely
>>> tests for this.
>>> It would be great if you could send something that failed. I could fix
>>> it and add it as a test.
>> Just to follow up, we have tests of the low-level communication (Plex
>> tests ex1, ex12, ex18, ex29, ex31), and then we have
>> tests that use halo exchange for PDE calculations, for example SNES
>> tutorial ex12, ex13, ex62. THe convergence rates
>> should be off if the halo exchange were wrong. Is there any example
>> similar to your code that is failing on your installation?
>> Or is there a way to run your code?
>> Thanks,
>> Matt
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Mike
>>>>> Dear PETSc team,
>>>>> I am using PETSc for Fortran with DMPlex. I have been using this
>>>>> version of PETSc:
>>>>> >>git rev-parse origin
>>>>> >>995ec06f924a86c4d28df68d1fdd6572768b0de1
>>>>> >>git rev-parse FETCH_HEAD
>>>>> >>9a04a86bf40bf893fb82f466a1bc8943d9bc2a6b
>>>>> There has been no issue, before the one with VTK viewer, which Jed
>>>>> fixed today (
>>>>> https://gitlab.com/petsc/petsc/-/merge_requests/6081/diffs?commit_id=27ba695b8b62ee2bef0e5776c33883276a2a1735
>>>>> Since that MR has been merged into the main repo, I pulled the latest
>>>>> version of PETSc (basically I cloned it from scratch). But if I use the
>>>>> same configure option with before, and run my code, then there is an issue
>>>>> with halo exchange. The code runs without error message, but it gives wrong
>>>>> solution field. I guess the issue I have is related to graph partitioner or
>>>>> halo exchange part. This is because if I run the code with 1-proc, the
>>>>> solution is correct. I only updated the version of PETSc and there was no
>>>>> change in my own code. Could I get any comments on the issue? I was
>>>>> wondering if there have been many changes in halo exchange or graph
>>>>> partitioning & distributing part related to DMPlex.
>>>>> Thanks,
>>>>> Mike
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230226/6e84e760/attachment-0001.html>
