[petsc-users] KSP_Solve crashes in debug mode
Wed Feb 22 17:23:23 CST 2023
On Wed, Feb 22, 2023 at 6:18 PM Sajid Ali Syed via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> One thing to note in relation to the trace attached in the previous email
> is that there are no warnings until the 36th call to KSP_Solve. The first
> error (as indicated by ASAN) occurs somewhere before the 40th call to
> KSP_Solve (part of what the application marks as turn 10 of the
> propagator). The crash finally occurs on the 43rd call to KSP_solve.
Looking at the trace, it appears that stack handling is messed up and
eventually it causes the crash. This can happen when
PetscFunctionBegin is not matched up with PetscFunctionReturn. Can you try
running this with
  -checkstack
     Matt
> Thank You,
> Sajid Ali (he/him) | Research Associate
> Data Science, Simulation, and Learning Division
> Fermi National Accelerator Laboratory
> s-sajid-ali.github.io
> *From:* Sajid Ali Syed <sasyed at fnal.gov>
> *Sent:* Wednesday, February 22, 2023 5:11 PM
> *To:* Barry Smith <bsmith at petsc.dev>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] KSP_Solve crashes in debug mode
> Hi Barry,
> Thanks a lot for fixing this issue. I ran the same problem on a linux
> machine and have the following trace for the same crash (with ASAN turned
> on for both PETSc (on the latest commit of the branch) and the application)
> : https://gist.github.com/s-sajid-ali/85bdf689eb8452ef8702c214c4df6940
> The trace seems to indicate a couple of buffer overflows, one of which
> causes the crash. I'm not sure as to what causes them.
> Thank You,
> *From:* Barry Smith <bsmith at petsc.dev>
> *Sent:* Wednesday, February 15, 2023 2:01 PM
> *To:* Sajid Ali Syed <sasyed at fnal.gov>
> https://gitlab.com/petsc/petsc/-/merge_requests/6075
> <https://urldefense.proofpoint.com/v2/url?u=https-3A__gitlab.com_petsc_petsc_-2D_merge-5Frequests_6075&d=DwMFaQ&c=gRgGjJ3BkIsb5y6s49QqsA&r=w-DPglgoOUOz8eiEyHKz0g&m=P7R0CW9R-fGNfm2q3yTL-ehqhM5N9-r8hHBLNgDetm9-7jxVqNsujIZ2hdnhVrVX&s=QwRI_DzGnCHagpaQSC4MPPEUnC4aAkbMwdG1eg_QUII&e=> should
> fix the possible recursive error condition Matt pointed out
> On Feb 9, 2023, at 6:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 9, 2023 at 6:05 PM Sajid Ali Syed via petsc-users <
> I added “-malloc_debug” in a .petscrc file and ran it again. The backtrace
> from lldb is in the attached file. The crash now seems to be at:
> Process 32660 stopped* thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=2, address=0x16f603fb8)
>     frame #0: 0x0000000112ecc8f8 libpetsc.3.018.dylib`PetscFPrintf(comm=0, fd=0x0000000000000000, format=0x0000000000000000) at mprint.c:601
>    598               `PetscViewerASCIISynchronizedPrintf()`, `PetscSynchronizedFlush()`
>    599      @*/
>    600      PetscErrorCode PetscFPrintf(MPI_Comm comm, FILE *fd, const char format[], ...)
> -> 601      {
>    602       PetscMPIInt rank;
>    603
>    604       PetscFunctionBegin;
> (lldb) frame info
> (lldb)
> The trace seems to indicate some sort of infinite loop causing an overflow.
> Yes, I have also seen this. What happens is that we have a memory error.
> The error is reported inside PetscMallocValidate()
> using PetscErrorPrintf, which eventually calls PetscCallMPI, which calls
> PetscMallocValidate again, which fails. We need to
> remove all error checking from the prints inside Validate.
>   Thanks,
>      Matt
> PS: I'm using a arm64 mac, so I don't have access to valgrind.
> Thank You,
> Scientific Computing Division
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__s-2Dsajid-2Dali.github.io_&d=DwMFaQ&c=gRgGjJ3BkIsb5y6s49QqsA&r=w-DPglgoOUOz8eiEyHKz0g&m=P7R0CW9R-fGNfm2q3yTL-ehqhM5N9-r8hHBLNgDetm9-7jxVqNsujIZ2hdnhVrVX&s=JA1u9AHcO8HqY5oCgbEy-ghtKRjURlRDwdmxP-9YJac&e=>
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.cse.buffalo.edu_-7Eknepley_&d=DwMFaQ&c=gRgGjJ3BkIsb5y6s49QqsA&r=w-DPglgoOUOz8eiEyHKz0g&m=P7R0CW9R-fGNfm2q3yTL-ehqhM5N9-r8hHBLNgDetm9-7jxVqNsujIZ2hdnhVrVX&s=CdEZKWQbBYiD2pzU3Az_EDIGUTBNkNHwSoD2n_2098Y&e=>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230222/064ba58a/attachment.html>
