[petsc-users] MG on GPU: Benchmarking and avoiding vector host->device copy
Mark Adams
mfadams at lbl.gov
Wed Feb 22 12:46:19 CST 2023
OK, Nsight Systems is a good way to see what is going on.
So all three of your solvers are not traversing the MG hierching with the
correct logic.
I don't know about hypre but PCMG and AMGx are pretty simple and AMGx dives
into the AMGx library directly from out interface.
Some things to try:
* Use -options_left to make sure your options are being used (eg, spelling
mistakes)
* Use -ksp_view to see a human readable list of your solver parameters.
* Use -log_trace to see if the correct methods are called.
- PCMG calls PCMGMCycle_Private for each of the cycle in code like:
for (i = 0; i < mg->cyclesperpcapply; i++)
PetscCall(PCMGMCycle_Private(pc, mglevels + levels - 1, transpose, matapp,
NULL));
- AMGx is called PCApply_AMGX and then it dives into the library. See where
these three calls to AMGx are called from.
On Wed, Feb 22, 2023 at 1:10 PM Paul Grosse-Bley <
paul.grosse-bley at ziti.uni-heidelberg.de> wrote:
> Hi Mark,
> I use Nvidia Nsight Systems with --trace
> cuda,nvtx,osrt,cublas-verbose,cusparse-verbose together with the NVTX
> markers that come with -log_view. I.e. I get a nice view of all cuBLAS and
> cuSPARSE calls (in addition to the actual kernels which are not always easy
> to attribute). For PCMG and PCGAMG I also use -pc_mg_log for even more
> detailed NVTX markers.
> The "signature" of a V-cycle in PCMG, PCGAMG and PCAMGX is pretty clear
> because kernel runtimes on coarser levels are much shorter. At the coarsest
> level, there normally isn't even enough work for the GPU (Nvidia A100) to
> be fully occupied which is also visible in Nsight Systems.
> I run only a single MPI rank with a single GPU, so profiling is
> straighforward.
> Best,
> Paul Große-Bley
> On Wednesday, February 22, 2023 18:24 CET, Mark Adams <mfadams at lbl.gov>
> wrote:
> On Wed, Feb 22, 2023 at 11:15 AM Paul Grosse-Bley <
>> Hi Barry,
>> after using VecCUDAGetArray to initialize the RHS, that kernel still gets
>> called as part of KSPSolve instead of KSPSetup, but its runtime is way less
>> significant than the cudaMemcpy before, so I guess I will leave it like
>> this. Other than that I kept the code like in my first message in this
>> thread (as you wrote, benchmark_ksp.c is not well suited for PCMG).
>> The profiling results for PCMG and PCAMG look as I would expect them to
>> look, i.e. one can nicely see the GPU load/kernel runtimes going down and
>> up again for each V-cycle.
>> I was wondering about -pc_mg_multiplicative_cycles as it does not seem to
>> make any difference. I would have expected to be able to increase the
>> number of V-cycles per KSP iteration, but I keep seeing just a single
>> V-cycle when changing the option (using PCMG).
> How are you seeing this?
> You might try -log_trace to see if you get two V cycles.
>> When using BoomerAMG from PCHYPRE, calling KSPSetComputeInitialGuess
>> between bench iterations to reset the solution vector does not seem to work
>> as the residual keeps shrinking. Is this a bug? Any advice for working
>> around this?
> Looking at the doc
> https://petsc.org/release/docs/manualpages/KSP/KSPSetComputeInitialGuess/
> you use this with KSPSetComputeRHS.
> In src/snes/tests/ex13.c I just zero out the solution vector.
>> The profile for BoomerAMG also doesn't really show the V-cycle behavior
>> of the other implementations. Most of the runtime seems to go into calls to
>> cusparseDcsrsv which might happen at the different levels, but the runtime
>> of these kernels doesn't show the V-cycle pattern. According to the output
>> with -pc_hypre_boomeramg_print_statistics it is doing the right thing
>> though, so I guess it is alright (and if not, this is probably the wrong
>> place to discuss it).
>> When using PCAMGX, I see two PCApply (each showing a nice V-cycle
>> behavior) calls in KSPSolve (three for the very first KSPSolve) while
>> expecting just one. Each KSPSolve should do a single preconditioned
>> Richardson iteration. Why is the preconditioner applied multiple times here?
> Again, not sure what "see" is, but PCAMGX is pretty new and has not been
> used much.
> Note some KSP methods apply to the PC before the iteration.
> Mark
>> Thank you,
>> Paul Große-Bley
>> On Monday, February 06, 2023 20:05 CET, Barry Smith <bsmith at petsc.dev>
>> wrote:
>> It should not crash, take a look at the test cases at the bottom of the
>> file. You are likely correct if the code, unfortunately, does use
>> DMCreateMatrix() it will not work out of the box for geometric multigrid.
>> So it might be the wrong example for you.
>> I don't know what you mean about clever. If you simply set the solution
>> to zero at the beginning of the loop then it will just do the same solve
>> multiple times. The setup should not do much of anything after the first
>> solver. Thought usually solves are big enough that one need not run solves
>> multiple times to get a good understanding of their performance.
>> On Feb 6, 2023, at 12:44 PM, Paul Grosse-Bley <
>> Hi Barry,
>> src/ksp/ksp/tutorials/bench_kspsolve.c is certainly the better starting
>> point, thank you! Sadly I get a segfault when executing that example with
>> PCMG and more than one level, i.e. with the minimal args:
>> $ mpiexec -c 1 ./bench_kspsolve -split_ksp -pc_type mg -pc_mg_levels 2
>> Test: KSP performance - Poisson
>> Input matrix: 27-pt finite difference stencil
>> -n 100
>> DoFs = 1000000
>> Number of nonzeros = 26463592
>> Step1 - creating Vecs and Mat...
>> Step2a - running PCSetUp()...
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and
>> [0]PETSC ERROR: or try
>> https://docs.nvidia.com/cuda/cuda-memcheck/index.html on NVIDIA CUDA
>> systems to find memory corruption errors
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link,
>> and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is
>> causing the crash.
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 59.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> As the matrix is not created using DMDACreate3d I expected it to fail due
>> to the missing geometric information, but I expected it to fail more
>> gracefully than with a segfault.
>> I will try to combine bench_kspsolve.c with ex45.c to get easy MG
>> preconditioning, especially since I am interested in the 7pt stencil for
>> now.
>> Concerning my benchmarking loop from before: Is it generally discouraged
>> to do this for KSPSolve due to PETSc cleverly/lazily skipping some of the
>> work when doing the same solve multiple times or are the solves not
>> iterated in bench_kspsolve.c (while the MatMuls are with -matmult) just to
>> keep the runtime short?
>> Thanks,
>> Paul
>> On Monday, February 06, 2023 17:04 CET, Barry Smith <bsmith at petsc.dev>
>> wrote:
>> Paul,
>> I think src/ksp/ksp/tutorials/benchmark_ksp.c is the code intended to
>> be used for simple benchmarking.
>> You can use VecCudaGetArray() to access the GPU memory of the vector
>> and then call a CUDA kernel to compute the right hand side vector directly
>> on the GPU.
>> Barry
>> On Feb 6, 2023, at 10:57 AM, Paul Grosse-Bley <
>> Hi,
>> I want to compare different implementations of multigrid solvers for
>> Nvidia GPUs using the poisson problem (starting from ksp tutorial example
>> ex45.c).
>> Therefore I am trying to get runtime results comparable to hpgmg-cuda
>> <https://bitbucket.org/nsakharnykh/hpgmg-cuda/src/master/>
>> (finite-volume), i.e. using multiple warmup and measurement solves and
>> avoiding measuring setup time.
>> For now I am using -log_view with added stages:
>> PetscLogStageRegister("Solve Bench", &solve_bench_stage);
>> for (int i = 0; i < BENCH_SOLVES; i++) {
>> PetscCall(KSPSetComputeInitialGuess(ksp, ComputeInitialGuess, NULL));
>> // reset x
>> PetscCall(KSPSetUp(ksp)); // try to avoid setup overhead during solve
>> PetscCall(PetscDeviceContextSynchronize(dctx)); // make sure that
>> everything is done
>> PetscLogStagePush(solve_bench_stage);
>> PetscCall(KSPSolve(ksp, NULL, NULL));
>> PetscLogStagePop();
>> This snippet is preceded by a similar loop for warmup.
>> When profiling this using Nsight Systems, I see that the very first solve
>> is much slower which mostly correspods to H2D (host to device) copies and
>> e.g. cuBLAS setup (maybe also paging overheads as mentioned in the docs
>> <https://petsc.org/release/docs/manual/profiling/#accurate-profiling-and-paging-overheads>,
>> but probably insignificant in this case). The following solves have some
>> overhead at the start from a H2D copy of a vector (the RHS I guess, as the
>> copy is preceeded by a matrix-vector product) in the first MatResidual call
>> (callchain:
>> KSPSolve->MatResidual->VecAYPX->VecCUDACopyTo->cudaMemcpyAsync). My
>> interpretation of the profiling results (i.e. cuBLAS calls) is that that
>> vector is overwritten with the residual in Daxpy and therefore has to be
>> copied again for the next iteration.
>> Is there an elegant way of avoiding that H2D copy? I have seen some
>> examples on constructing matrices directly on the GPU, but nothing about
>> vectors. Any further tips for benchmarking (vs profiling) PETSc solvers? At
>> the moment I am using jacobi as smoother, but I would like to have a CUDA
>> implementation of SOR instead. Is there a good way of achieving that, e.g.
>> using PCHYPREs boomeramg with a single level and "SOR/Jacobi"-smoother as
>> smoother in PCMG? Or is the overhead from constantly switching between
>> PETSc and hypre too big?
>> Thanks,
>> Paul
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230222/970cfa19/attachment-0001.html>
