[petsc-users] TS failed due to diverged_step_rejected
Tu, Jiannan Jiannan_Tu at uml.edu
Fri Feb 17 18:06:12 CST 2023
It’s possible. I’m checking the rhs and stiff equations.
Thank you,
Jiannan
Sent: Friday, February 17, 2023 3:39 PM
To: Tu, Jiannan<mailto:Jiannan_Tu at uml.edu>
Cc: Barry Smith<mailto:bsmith at petsc.dev>; petsc-users<mailto:petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] TS failed due to diverged_step_rejected
CAUTION: This email was sent from outside the UMass Lowell network.
On Fri, Feb 17, 2023 at 3:32 PM Tu, Jiannan <Jiannan_Tu at uml.edu<mailto:Jiannan_Tu at uml.edu>> wrote:
The ts_type arkimex is used. There is right hand-side function RHSFunction set by TSSetRHSFunction() and also stiff function set by TSSetIFunction().
With adaptivity shut off, TS can finish its first time step after the 3rd “Nonlinear solve converged due to …”. The solution gives negative electron and neutral temperatures at the bottom boundary. I need to fix the negative temperatures and see how the code works.
BTW, what is this ts_adapt? Is it by default on?
It is a controller for adaptive timestepping. It is on by default, but I suspect that you step into an unphysical regime, which makes
its estimates unreliable.
     Matt
Thank you,
Jiannan
Sent: Friday, February 17, 2023 3:15 PM
I am not sure what TS you are using, but the estimate of the local truncation error is 91.4, and does not seem
to change when you make the step smaller, so something is off. You can shut off the adaptivity using
 -ts_adapt_type none
      Matt
On Fri, Feb 17, 2023 at 3:01 PM Tu, Jiannan <Jiannan_Tu at uml.edu<mailto:Jiannan_Tu at uml.edu>> wrote:
These are what I got with the options you suggested.
Thank you,
Jiannan
    0 SNES Function norm 2.274473072186e+03
    1 SNES Function norm 1.673091274668e-03
  Nonlinear solve converged due to CONVERGED_FNORM_RELATIVE iterations 1
    0 SNES Function norm 8.715428433630e-02
    1 SNES Function norm 4.995727626692e-04
    2 SNES Function norm 5.498018152230e-08
  Nonlinear solve converged due to CONVERGED_FNORM_ABS iterations 2
    0 SNES Function norm 3.237461568254e-01
    1 SNES Function norm 7.988531005091e-04
    2 SNES Function norm 1.280948196292e-07
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 2.189e-02 dt=4.374e-03  wlte= 91.4  wltea=   -1 wlter=   -1
    1 SNES Function norm 4.881903203545e-04
   0 SNES Function norm 7.562592690785e-02
    1 SNES Function norm 1.143078818923e-04
    2 SNES Function norm 9.834547907735e-09
    0 SNES Function norm 2.683968949758e-01
    1 SNES Function norm 1.838028436639e-04
    2 SNES Function norm 9.470813523140e-09
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-03 dt=4.374e-04  wlte= 91.4  wltea=   -1 wlter=   -1
    1 SNES Function norm 1.821562431175e-04
    0 SNES Function norm 1.005443458812e-01
    1 SNES Function norm 3.633336946661e-05
  Nonlinear solve converged due to CONVERGED_FNORM_ABS iterations 1
    0 SNES Function norm 1.515368382715e-01
    1 SNES Function norm 3.389298316830e-05
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-04 dt=4.374e-05  wlte= 91.4  wltea=   -1 wlter=   -1
    1 SNES Function norm 4.541003359206e-05
    0 SNES Function norm 1.713800906043e-01
    1 SNES Function norm 1.179958172167e-05
    0 SNES Function norm 2.020265094117e-01
    1 SNES Function norm 1.513971290464e-05
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-05 dt=4.374e-06  wlte= 91.4  wltea=   -1 wlter=   -1
    1 SNES Function norm 6.090269704320e-06
    0 SNES Function norm 2.136603895703e-01
    1 SNES Function norm 1.877474016012e-06
    0 SNES Function norm 3.127812462507e-01
    1 SNES Function norm 2.713146825704e-06
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-06 dt=4.374e-07  wlte= 91.4  wltea=   -1 wlter=   -1
    1 SNES Function norm 2.793512213059e-06
    0 SNES Function norm 2.205196267430e-01
    1 SNES Function norm 2.572653773308e-06
    0 SNES Function norm 3.260057361977e-01
    1 SNES Function norm 2.705816087598e-06
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-07 dt=4.374e-08  wlte= 91.4  wltea=   -1 wlter=   -1
    1 SNES Function norm 2.764855860446e-05
    0 SNES Function norm 2.212505522844e-01
    1 SNES Function norm 2.958996472386e-05
    0 SNES Function norm 3.273222034162e-01
    1 SNES Function norm 2.994512887620e-05
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-08 dt=4.374e-09  wlte= 91.4  wltea=   -1 wlter=   -1
    1 SNES Function norm 3.317240589134e-04
    0 SNES Function norm 2.213246532918e-01
    1 SNES Function norm 2.799468604767e-04
  Nonlinear solve converged due to CONVERGED_SNORM_RELATIVE iterations 1
    0 SNES Function norm 3.274570888397e-01
    1 SNES Function norm 3.066048050994e-04
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-09 dt=4.374e-10  wlte= 91.4  wltea=   -1 wlter=   -1
    0 SNES Function norm 2.274473072189e+03
    1 SNES Function norm 2.653507278572e-03
    0 SNES Function norm 2.213869585841e-01
    1 SNES Function norm 2.177156902895e-03
    0 SNES Function norm 3.275136370365e-01
    1 SNES Function norm 1.962849131557e-03
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-10 dt=4.374e-11  wlte= 91.4  wltea=   -1 wlter=   -1
    0 SNES Function norm 2.274473072218e+03
    1 SNES Function norm 5.664907315679e-03
    0 SNES Function norm 2.223208399368e-01
    1 SNES Function norm 5.688863091415e-03
    0 SNES Function norm 3.287121218919e-01
    1 SNES Function norm 4.085338521320e-03
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-11 dt=4.374e-12  wlte= 91.4  wltea=   -1 wlter=   -1
    0 SNES Function norm 2.274473071968e+03
    1 SNES Function norm 4.694691905235e-04
    0 SNES Function norm 2.211786508657e-01
    1 SNES Function norm 1.503497433939e-04
    0 SNES Function norm 3.272667798977e-01
    1 SNES Function norm 2.176132327279e-04
      TSAdapt basic arkimex 0:3 step   0 rejected t=42960      + 4.374e-12 dt=4.374e-13  wlte= 91.4  wltea=   -1 wlter=   -1
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR:
[0]PETSC ERROR: TSStep has failed due to DIVERGED_STEP_REJECTED
[0]PETSC ERROR: See https://petsc.org/release/faq/<https://nam10.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpetsc.org%2Frelease%2Ffaq%2F&data=05%7C01%7CJiannan_Tu%40uml.edu%7C01ad28026b614c9c427a08db11270481%7C4c25b8a617f746f983f054734ab81fb1%7C0%7C0%7C638122631541429844%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=QUFvFMlmq8xNOLR4T%2Fz5K1bbZ45%2FY0%2Fic2dSJm%2BihpU%3D&reserved=0> for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.16.6, Mar 30, 2022
[0]PETSC ERROR: ./iditm3d on a  named office by jtu Fri Feb 17 14:54:22 2023
[0]PETSC ERROR: Configure options --prefix=/usr/local --with-mpi-dir=/usr/local --with-fc=0 --with-openmp --with-hdf5-dir=/usr/local --download-f2cblaslapack=1
[0]PETSC ERROR: #1 TSStep() at /home/jtu/Downloads/petsc-3.16.6/src/ts/interface/ts.c:3583
Sent: Friday, February 17, 2023 12:58 PM
Cc: petsc-users<mailto:petsc-users at mcs.anl.gov>
  Can you please run with also the options -ts_monitor -ts_adapt_monitor ?
  The output is confusing because it prints that the Nonlinear solve has converged but then TSStep has failed due to DIVERGED_STEP_REJECTED which seems contradictory
On Feb 17, 2023, at 12:09 PM, Tu, Jiannan <Jiannan_Tu at uml.edu<mailto:Jiannan_Tu at uml.edu>> wrote:
My code uses TS to solve a set of multi-fluid MHD equations. The jacobian is provided with function F(t, u, u'). Both linear and nonlinear solvers converge but snes repeats itself until gets "TSStep has failed due to diverged_step_rejected."
Is it because I used TSStep rather than TSSolve? I have checked the condition number. The condition number with pc_type asm is about 1 (without precondition it is about 4x10^4). The maximum ratio of off-diagonal jacobian element over diagonal element is about 21.
Could you help me to identify what is going wrong?
Thank you very much!
Jiannan
Run command with options
mpiexec -n $1 ./iditm3d -ts_type arkimex -snes_tyep ngmres -ksp_type gmres -pc_type asm \
-ts_rtol 1.0e-4 -ts_atol 1.0e-4 -snes_monitor -snes_rtol 1.0e-4 -snes_atol 1.0e-4 \
-snes_converged_reason
The output message is
Start time advancing ...
[0]PETSC ERROR:
[0]PETSC ERROR: ./iditm3d on a  named office by jtu Fri Feb 17 11:59:43 2023
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<https://nam10.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=05%7C01%7CJiannan_Tu%40uml.edu%7C01ad28026b614c9c427a08db11270481%7C4c25b8a617f746f983f054734ab81fb1%7C0%7C0%7C638122631541429844%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=I89Ouhn3jiKbz%2FuQzFSq6pKN47sba2rXpJN4JrBc1iQ%3D&reserved=0>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230218/36b86490/attachment-0001.html>
