[petsc-users] PetscViewer with 64bit
Mike Michell
mi.mike1021 at gmail.com
Thu Feb 16 22:36:20 CST 2023
Jed,
It does not work for me even with the reproducer case with the small 2D
square mesh. Can you run the case that I sent and open the created
"sol.vtu" file with paraview?
> Thanks, Dave.
> Mike, can you test that this branch works with your large problems? I
> tested that .vtu works in parallel for small problems, where works = loads
> correctly in Paraview and VisIt.
> https://gitlab.com/petsc/petsc/-/merge_requests/6081
> Dave May <dave.mayhem23 at gmail.com> writes:
> >> > On Tue 14. Feb 2023 at 17:17, Jed Brown <jed at jedbrown.org> wrote:
> >> >> Can you share a reproducer? I think I recall the format requiring
> >> certain
> >> >> things to be Int32.
> >> > By default, the byte offset used with the appended data format is
> >> UInt32. I
> >> > believe that’s where the sizeof(int) is coming from. This default is
> >> > annoying as it limits the total size of your appended data to be < 3
> GB.
> >> > That said, in the opening of the paraview file you can add this
> attribute
> >> > header_type="UInt64"
> >> You mean in the header of the .vtu?
> > Yeah, within the open VTKFile tag.
> > Like this
> > < VTKFile type=“xxx”, byte_order="LittleEndian" header_type="UInt64" >
> > Do you happen to have an example or pointers to docs describing this
> >> feature?
> > Example yes - will send it to you tomorrow. Docs… not really. Only stuff
> > like this
> https://kitware.github.io/paraview-docs/latest/python/paraview.simple.XMLPStructuredGridWriter.html
> https://kitware.github.io/paraview-docs/v5.8.0/python/paraview.simple.XMLMultiBlockDataWriter.html
> > All the writers seem to support it.
> > Can we always do this?
> > Yep!
> > It isn't mentioned in these:
> >> https://vtk.org/wp-content/uploads/2015/04/file-formats.pdf (PDF was
> >> created in 2003)
> https://kitware.github.io/vtk-examples/site/VTKFileFormats/#xml-file-formats
> > Yes I know. I’ve tied myself in knots for years because the of the
> > assumption that the offset had to be an int.
> > Credit for the discovery goes to Carsten Uphoff. He showed me this.
> > Cheers,
> > Dave
> >> > then the size of the offset is now UInt64 and now large files can be
> >> > finally written.
> >> > Cheers,
> >> > Dave
> >> >> Mike Michell <mi.mike1021 at gmail.com> writes:
> >> >> > Thanks for the note.
> >> >> > I understood that PETSc calculates the offsets for me through
> >> "boffset"
> >> >> > variable in plexvtu.c file. Please correct me if it is wrong.
> >> >> > If plexvtu.c has a bug, it could be around "write file header"
> part in
> >> >> > which the boffset is also computed. Is this correct? I am not using
> >> >> complex
> >> >> > number.
> >> >> > There are several mixed parts among "Int32, UInt8, PetscInt_FMT,
> >> >> > PetscInt64_FMT" in writing the header.
> >> >> > Which combination of those flags is correct for 64bit indices? I am
> >> gonna
> >> >> > modify plexvtu.c file with "#if defined(PETSC_USE_64BIT_INDICES)"
> >> >> > statement, but I do not know what is the correct form of the header
> >> flag
> >> >> > for 64bit indices.
> >> >> > It is also confusing to me:
> >> >> > boffset += gpiece[r].ncells * sizeof(PetscInt) + sizeof(int);
> >> >> > How is sizeof(PetscInt) different from sizeof(int)?
> >> >> > Thanks,
> >> >> > Mike
> >> >> >> On Tue, Feb 14, 2023 at 11:45 AM Mike Michell <
> >> >> >> wrote:
> >> >> >>> I was trying to modify the header flags from "Int32" to "Int64",
> but
> >> >> the
> >> >> >>> problem was not resolved. Could I get any additional comments?
> >> >> >> The calculated offsets are not correct I think.
> >> >> >> Matt
> >> >> >>> Thanks,
> >> >> >>> Mike
> >> >> >>>> Thanks for the comments.
> >> >> >>>> To be precise on the question, the entire part of the header of
> the
> >> >> .vtu
> >> >> >>>> file is attached:
> >> >> >>>> <?xml version="1.0"?>
> >> >> >>>> <VTKFile type="UnstructuredGrid" version="0.1"
> >> >> byte_order="LittleEndian">
> >> >> >>>> <UnstructuredGrid>
> >> >> >>>> <Piece NumberOfPoints="4872" NumberOfCells="4000">
> >> >> >>>> <Points>
> >> >> >>>> <DataArray type="Float64" Name="Position"
> >> >> NumberOfComponents="3"
> >> >> >>>> format="appended" offset="0" />
> >> >> >>>> </Points>
> >> >> >>>> <Cells>
> >> >> >>>> <DataArray type="Int32" Name="connectivity"
> >> >> >>>> NumberOfComponents="1" format="appended" offset="116932" />
> >> >> >>>> <DataArray type="Int32" Name="offsets"
> >> >> >>>> NumberOfComponents="1" format="appended" offset="372936" />
> >> >> >>>> <DataArray type="UInt8" Name="types"
> >> >> >>>> NumberOfComponents="1" format="appended" offset="404940" />
> >> >> >>>> </Cells>
> >> >> >>>> <CellData>
> >> >> >>>> <DataArray type="Int32" Name="Rank"
> >> >> >>>> format="appended" offset="408944" />
> >> >> >>>> </CellData>
> >> >> >>>> <PointData>
> Name="Vec_0x37c89c0_4Field_0.0"
> >> >> >>>> NumberOfComponents="1" format="appended" offset="424948" />
> >> >> >>>> </PointData>
> >> >> >>>> </Piece>
> >> >> >>>> <Points>
> >> >> >>>> format="appended" offset="463928" />
> >> >> >>>> </Points>
> >> >> >>>> <Cells>
> >> >> >>>> NumberOfComponents="1" format="appended" offset="580860" />
> >> >> >>>> NumberOfComponents="1" format="appended" offset="836864" />
> >> >> >>>> NumberOfComponents="1" format="appended" offset="868868" />
> >> >> >>>> </Cells>
> >> >> >>>> <CellData>
> >> >> >>>> format="appended" offset="872872" />
> >> >> >>>> </CellData>
> >> >> >>>> <PointData>
> >> >> >>>> NumberOfComponents="1" format="appended" offset="888876" />
> >> >> >>>> </PointData>
> >> >> >>>> </Piece>
> >> >> >>>> </UnstructuredGrid>
> >> >> >>>> <AppendedData encoding="raw">
> >> >> >>>> Thanks,
> >> >> >>>> Mike
> >> >> >>>>> On Sun, Feb 12, 2023 at 6:15 PM Mike Michell <
> >> >> >>>>> wrote:
> >> >> >>>>>> Dear PETSc team,
> >> >> >>>>>> I am a user of PETSc with Fortran. My code uses DMPlex to
> handle
> >> dm
> >> >> >>>>>> object. To print out output variable and mesh connectivity, I
> use
> >> >> VecView()
> >> >> >>>>>> by defining PetscSection on that dm and borrow a vector. The
> type
> >> >> of the
> >> >> >>>>>> viewer is set to PETSCVIEWERVTK.
> >> >> >>>>>> With 32bit indices, the above work flow has no issue.
> However, if
> >> >> >>>>>> PETSc is configured with 64bit indices, my output .vtu file
> has
> >> an
> >> >> error if
> >> >> >>>>>> I open the file with visualization tools, such as Paraview or
> >> >> Tecplot,
> >> >> >>>>>> saying that:
> >> >> >>>>>> "Cannot read cell connectivity from Cells in piece 0 because
> the
> >> >> >>>>>> "offsets" array is not monotonically increasing or starts
> with a
> >> >> value
> >> >> >>>>>> other than 0."
> >> >> >>>>>> If I open the .vtu file from terminal, I can see such a line:
> >> >> >>>>>> I expected "DataArray type="Int64", since the PETSc has 64bit
> >> >> indices.
> >> >> >>>>>> Could I get recommendations that I need to check to resolve
> the
> >> >> issue?
> >> >> >>>>> This is probably a bug. We will look at it.
> >> >> >>>>> Jed, I saw that Int32 is hardcoded in plexvtu.c, but
> >> sizeof(PetscInt)
> >> >> >>>>> is used to calculate the offset, which looks inconsistent. Can
> you
> >> >> take a
> >> >> >>>>> look?
> >> >> >>>>> Thanks,
> >> >> >>>>> Matt
> >> >> >>>>>> Thanks,
> >> >> >>>>>> Mike
> >> >> >>>>> What most experimenters take for granted before they begin
> their
> >> >> >>>>> experiments is infinitely more interesting than any results to
> >> which
> >> >> their
> >> >> >>>>> experiments lead.
> >> >> >>>>> -- Norbert Wiener
> >> >> >>>>> https://www.cse.buffalo.edu/~knepley/
> >> >> >>>>> <http://www.cse.buffalo.edu/~knepley/>
> >> >> >> What most experimenters take for granted before they begin their
> which
> >> >> their
> >> >> >> experiments lead.
> >> >> >> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230216/f0294043/attachment-0001.html>
