[petsc-users] KSP_Solve crashes in debug mode
Barry Smith
bsmith at petsc.dev
Wed Feb 15 14:01:11 CST 2023
https://gitlab.com/petsc/petsc/-/merge_requests/6075 should fix the possible recursive error condition Matt pointed out
> On Feb 9, 2023, at 6:24 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Feb 9, 2023 at 6:05 PM Sajid Ali Syed via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>> I added “-malloc_debug” in a .petscrc file and ran it again. The backtrace from lldb is in the attached file. The crash now seems to be at:
>> Process 32660 stopped* thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=2, address=0x16f603fb8)
>> frame #0: 0x0000000112ecc8f8 libpetsc.3.018.dylib`PetscFPrintf(comm=0, fd=0x0000000000000000, format=0x0000000000000000) at mprint.c:601
>> 598 `PetscViewerASCIISynchronizedPrintf()`, `PetscSynchronizedFlush()`
>> 599 @*/
>> 600 PetscErrorCode PetscFPrintf(MPI_Comm comm, FILE *fd, const char format[], ...)
>> -> 601 {
>> 602 PetscMPIInt rank;
>> 603
>> 604 PetscFunctionBegin;
>> (lldb) frame info
>> (lldb)
>> The trace seems to indicate some sort of infinite loop causing an overflow.
> Yes, I have also seen this. What happens is that we have a memory error. The error is reported inside PetscMallocValidate()
> using PetscErrorPrintf, which eventually calls PetscCallMPI, which calls PetscMallocValidate again, which fails. We need to
> remove all error checking from the prints inside Validate.
> Thanks,
> Matt
>> PS: I'm using a arm64 mac, so I don't have access to valgrind.
>> Thank You,
>> Sajid Ali (he/him) | Research Associate
>> Scientific Computing Division
>> Fermi National Accelerator Laboratory
>> s-sajid-ali.github.io <http://s-sajid-ali.github.io/>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230215/d9988b12/attachment.html>
