[petsc-users] MatFDColoringSetUp with Periodic BC
Barry Smith bsmith at petsc.dev
Tue Feb 14 14:35:08 CST 2023
  I have created an MR that documents this and moved the error checking to a more appropriate location https://gitlab.com/petsc/petsc/-/merge_requests/6070
> On Feb 14, 2023, at 4:33 AM, Pierre Bernigaud <pierre.bernigaud at onera.fr> wrote:
> Dear all,
> I hope this email finds you well.
> We are currently working on a solver which is employing DMDA with SNES. The jacobian is computed via FDColoring, ie:
> call DMDACreate1D(PETSC_COMM_WORLD, DM_BOUNDARY_GHOSTED, NY, NC, NGc, PETSC_NULL_INTEGER, dmF, ierr)
> ! ----- Some steps ...
> call DMCreateColoring(dmF, IS_COLORING_GLOBAL, iscoloring, ierr)
> call MatFDColoringCreate(Jac,iscoloring, matfdcoloring, ierr)
> call MatFDColoringSetFunction(matfdcoloring, FormFunction, CTX, ierr)
> call MatFDColoringSetUp(Jac ,iscoloring,matfdcoloring, ierr)
> call SNESSetJacobian(snes, Jac, Jac, SNESComputeJacobianDefaultColor, matfdcoloring, ierr)
> Everything is running smoothly.
> Recently, we modified the boundary conditions such as to use periodic BC:
> call DMDACreate1D(PETSC_COMM_WORLD, DM_BOUNDARY_PERIODIC, NY, NC, NGc, PETSC_NULL_INTEGER, dmF, ierr)
> We then encountered frequent crashes when calling MatFDColoringSetUp, depending on the number of cells NY. After looking for an solution, I found this old thread: https://lists.mcs.anl.gov/pipermail/petsc-users/2013-May/017449.html
> It appears that when using periodic BC, FDColoring can only be used if the number of cells is divisible by 2*NGc+1. Even though this is only a slight annoyance, I was wondering if you were working on this matter / if you had a quick fix at hand? At any rate, I think it would be nice if a warning was displayed in the FDColoring documentation?
> Respectfully,
> Pierre Bernigaud
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230214/f8de4716/attachment.html>
