[petsc-users] PetscViewer with 64bit
    Mike Michell
    mi.mike1021 at gmail.com
    Tue Feb 14 10:44:54 CST 2023
I was trying to modify the header flags from "Int32" to "Int64", but the
problem was not resolved. Could I get any additional comments?
Mike
> Thanks for the comments.
> To be precise on the question, the entire part of the header of the .vtu
> file is attached:
> <?xml version="1.0"?>
> <VTKFile type="UnstructuredGrid" version="0.1" byte_order="LittleEndian">
>   <UnstructuredGrid>
>     <Piece NumberOfPoints="4872" NumberOfCells="4000">
>       <Points>
>         <DataArray type="Float64" Name="Position" NumberOfComponents="3"
> format="appended" offset="0" />
>       </Points>
>       <Cells>
>         <DataArray type="Int32" Name="connectivity" NumberOfComponents="1"
> format="appended" offset="116932" />
>         <DataArray type="Int32" Name="offsets"      NumberOfComponents="1"
> format="appended" offset="372936" />
>         <DataArray type="UInt8" Name="types"        NumberOfComponents="1"
> format="appended" offset="404940" />
>       </Cells>
>       <CellData>
>         <DataArray type="Int32" Name="Rank" NumberOfComponents="1"
> format="appended" offset="408944" />
>       </CellData>
>       <PointData>
>         <DataArray type="Float64" Name="Vec_0x37c89c0_4Field_0.0"
> NumberOfComponents="1" format="appended" offset="424948" />
>       </PointData>
>     </Piece>
>       <Points>
> format="appended" offset="463928" />
>       </Points>
>       <Cells>
> format="appended" offset="580860" />
> format="appended" offset="836864" />
> format="appended" offset="868868" />
>       </Cells>
>       <CellData>
> format="appended" offset="872872" />
>       </CellData>
>       <PointData>
> NumberOfComponents="1" format="appended" offset="888876" />
>       </PointData>
>     </Piece>
>   </UnstructuredGrid>
>   <AppendedData encoding="raw">
> Thanks,
> Mike
>> On Sun, Feb 12, 2023 at 6:15 PM Mike Michell <mi.mike1021 at gmail.com>
>> wrote:
>>> Dear PETSc team,
>>> I am a user of PETSc with Fortran. My code uses DMPlex to handle dm
>>> object. To print out output variable and mesh connectivity, I use VecView()
>>> by defining PetscSection on that dm and borrow a vector. The type of the
>>> viewer is set to PETSCVIEWERVTK.
>>> With 32bit indices, the above work flow has no issue. However, if PETSc
>>> is configured with 64bit indices, my output .vtu file has an error if I
>>> open the file with visualization tools, such as Paraview or Tecplot, saying
>>> that:
>>> "Cannot read cell connectivity from Cells in piece 0 because the
>>> "offsets" array is not monotonically increasing or starts with a value
>>> other than 0."
>>> If I open the .vtu file from terminal, I can see such a line:
>>> I expected "DataArray type="Int64", since the PETSc has 64bit indices.
>>> Could I get recommendations that I need to check to resolve the issue?
>> This is probably a bug. We will look at it.
>> Jed, I saw that Int32 is hardcoded in plexvtu.c, but sizeof(PetscInt) is
>> used to calculate the offset, which looks inconsistent. Can you take a look?
>>   Thanks,
>>      Matt
>>> Thanks,
>>> Mike
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230214/c0f4d4db/attachment.html>
