[petsc-users] MatMatMul inefficient
Pierre Jolivet
pierre at joliv.et
Mon Feb 13 08:51:41 CST 2023
Could you please share a reproducer?
What you are seeing is not typical of the performance of such a kernel, both from a theoretical or a practical (see fig. 2 of https://joliv.et/article.pdf) point of view.
Pierre
> On 13 Feb 2023, at 3:38 PM, Guido Margherita via petsc-users <petsc-users at mcs.anl.gov> wrote:
> A is a sparse MATSEQAIJ, Q is dense.
> Thanks,
> Margherita
>> Il giorno 13 feb 2023, alle ore 3:27 PM, knepley at gmail.com ha scritto:
>> On Mon, Feb 13, 2023 at 9:21 AM Guido Margherita via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hi all,
>> I realised that performing a matrix-matrix multiplication using the function MatMatMult it is not at all computationally efficient with respect to performing N times a matrix-vector multiplication with MatMul, being N the number of columns of the second matrix in the product.
>> When I multiply I matrix A 46816 x 46816 to a matrix Q 46816 x 6, the MatMatMul function is indeed 6 times more expensive than 6 times a call to MatMul, when performed sequentially (0.04056 s vs 0.0062 s ). When the same code is run in parallel the gap grows even more, being10 times more expensive.
>> Is there an explanation for it?
>> So we can reproduce this, what kind of matrix is A? I am assuming that Q is dense.
>> Thanks,
>> Matt
>> t1 = MPI_Wtime()
>> call MatMatMult(A,Q,MAT_INITIAL_MATRIX, PETSC_DEFAULT_REAL, AQ, ierr )
>> t2 = MPI_Wtime()
>> t_MatMatMul = t2-t1
>> t_MatMul=0.0
>> do j = 0, m-1
>> call MatGetColumnVector(Q, q_vec, j,ierr)
>> t1 = MPI_Wtime()
>> call MatMult(A, q_vec, aq_vec, ierr)
>> t2 = MPI_Wtime()
>> t_MatMul = t_MatMul + t2-t1
>> end do
>> Thank you,
>> Margherita Guido
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230213/630b29bc/attachment-0001.html>
