[petsc-users] Eliminating rows and columns which are zeros
Matthew Knepley
knepley at gmail.com
Mon Feb 13 05:40:58 CST 2023
On Mon, Feb 13, 2023 at 6:24 AM Karthikeyan Chockalingam - STFC UKRI via
petsc-users <petsc-users at mcs.anl.gov> wrote:
> Thank you. I have it working now.
> (Q1) When both d_nz and d_nnz are specified – would petsc would pick up
> d_nnz over d_nz? Likewise for o_nz and o_nnz?
> ierr = MatMPIAIJSetPreallocation(A,d_nz, d_nnz, o_nz, o_nnz);
Yes, it will pick d_nnz.
> (Q2) Finally I would like to assign appropriate memory for ‘active rows’
> as well. I know the max non-zero elements in a row is 9? Is there a
> rule-of-thumb what d_nz and o_nz be for active rows - when run parallelly?
No, it would depend on your partitioning.
Matt
> Best,
> Karthik.
> *From: *Barry Smith <bsmith at petsc.dev>
> *Date: *Saturday, 11 February 2023 at 00:45
> *To: *Chockalingam, Karthikeyan (STFC,DL,HC) <
> karthikeyan.chockalingam at stfc.ac.uk>
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Eliminating rows and columns which are zeros
> On Feb 10, 2023, at 5:32 PM, Karthikeyan Chockalingam - STFC UKRI <
> karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Yes, but d_nnz_vec and o_nnz_vec are not of size MPI rank but of size N.
> They are each of size local_size not size N. So your old code was fine
> with some changes, like
> for (int i = 0; i < local_size; i++) {
> d_nnz[i] = 10 if active row else 1;
> o_nnz[i] = 10 if active row else 0;
> That is all you need to define these two arrays.
> but you don't need the
> Below is an alternative approach, making both d_nnz_vec and o_nnz_vec
> PETSc mpi vecs instead of C++ containers.
> Is this okay?
> MatSetType(A, MATAIJ);
> MatSetSizes(A, PETSC_DECIDE,PETSC_DECIDE,N,N);
> PetscInt rstart, rend;
> MatGetOwnershipRange(A,&rstart,&rend);
> PetscInt local_size = rend – rstart;
> VecCreateMPI(PETSC_COMM_WORLD, local_size, N, &d_nnz_vec)
> VecDuplicate(d_nnz_vec, o_nnz_vec)
> // populate d_nnz_vec and o_nnz_vec but not shown here!
> PetscMalloc(local_size * sizeof(PetscInt), &d_nnz);
> PetscMalloc(local_size * sizeof(PetscInt), &o_nnz);
> PetscMalloc(local_size * sizeof(PetscInt), &indices);
> indices[i]=i+rstart;
> VecGetValues(d_nnz_vec, local_size, indices, d_nzz);
> VecGetValues(o_nnz_vec, local_size, indices, o_nzz);
> MatMPIAIJSetPreallocation(A, max_d_nz, d_nnz, max_o_nz, o_nnz);
> PetscFree(d_nnz);
> PetscFree(o_nnz);
> Kind regards,
> Karthik.
> *Date: *Friday, 10 February 2023 at 20:53
> On Feb 10, 2023, at 3:34 PM, Karthikeyan Chockalingam - STFC UKRI <
> Thank you for your response.
> “But the original big matrix with lots of extra reserved space still
> exists (your A).” - I would like to save memory on rows that are
> ‘inactive’ by making use of d_nnz and o_nnz.
> (Q1) When is a row considered “inactive” and dropped by -pc_type
> redistribute during the solve? Is it when the entire row is zero?
> When there is only a diagonal entry or no entries.
> (Q2) If the answer to (Q1) is ‘yes’. Am I right in thinking it would be
> beneficial to make have 0.0 on the diagonal of the ‘inactive’ rows instead
> of ‘1.0’?
> Doesn't matter, you can have any value on the diagonal.
> Currently, I am setting 0.0 to the diagonal element of the ‘inactive’ rows.
> I am propose the following, please let me know if I am heading in the
> right direction.
> (Q3) ) I am planning to create two C++ vectors: d_nnz_vec and o_nnz_vec of
> N.
> Is d_nnz_vec[inactive_row_index] = 0 and o_nnz_vec[inactive_row_index] = 0
> or
> d_nnz_vec[inactive_row_index] = 1 and Is o_nnz_vec[inactive_row_index] = 0?
> d_nnz_vec[active_row_index] = 10 and o_nnz_vec[active_row_index] = 10
> Yes, this seems like the correct scheme, it will not allocate unneeded
> extra space for inactive rows, exactly the one you want.
> (Q4) Is the below correct?
> PetscInt * d_nnz = NULL;
> PetscInt * o_nnz = NULL;
> PetscInt max_d_nz = 10;
> PetscInt max_o_nz = 10;
> d_nnz[i] = d_nnz_vec[i + rstart];
> o_nnz[i] = o_nnz_vec[i + rstart];
> Yes, but I think the + rstart is wrong. It is not needed because the
> d_nnz and o_nnz are just the size on that MPI rank.
> MatMPIAIJSetPreallocation(A,max_d_nz,d_nnz,max_o_nz, o_nnz);
> PetscFree(d_nnz);
> PetscFree(o_nnz);
> Kind regards,
> Karthik.
> *Date: *Wednesday, 8 February 2023 at 21:10
> On Feb 8, 2023, at 11:19 AM, Karthikeyan Chockalingam - STFC UKRI <
> No, I am not calling MatMPIAIJSetPreallocation(... N,NULL);
> Here is what I do:
> PetscInt d_nz = 10;
> PetscInt o_nz = 10;
> ierr = MatCreate(PETSC_COMM_WORLD, &A); CHKERRQ(ierr);
> ierr = MatSetType(A, MATMPIAIJ); CHKERRQ(ierr);
> ierr = MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, N, N); CHKERRQ
> (ierr);
> ierr = MatMPIAIJSetPreallocation(A, d_nz, *NULL*, o_nz, *NULL*);
> CHKERRQ(ierr);
> (Q1)
> As I am setting the size of A to be N x N via
> (ierr);
> d_nz and o_nz determine the memory reserved for A. So if you use for
> example 10 that means 10 entries are reserved for every row, even inactive
> ones.
> and pre-allocation is done for ALL rows I would like to understand if the
> ‘inactive rows’ are NOT contributing to memory (while using ‘redistribute’)?
> Redistribute will drop all the inactive rows from the computation of the
> solve, it generates a smaller matrix missing all those rows and columns.
> But the original big matrix with lots of extra reserved space still exists
> (your A).
> (Q2)
> I tried solving using hypre within redistribute and system converges to a
> solution. Is below correct way to use hypre within redistribute?
> ierr = PetscOptionsSetValue(*NULL*,"-ksp_type", "preonly");
> ierr = PetscOptionsSetValue(*NULL*,"-pc_type", "redistribute");
> ierr = PetscOptionsSetValue(*NULL*,"-redistribute_ksp_type", "cg");
> ierr = PetscOptionsSetValue(*NULL*,"-redistribute_pc_type", "hypre");
> ierr = PetscOptionsSetValue(*NULL*,"-redistribute_pc_hypre_type",
> "boomeramg");
> Correct. You can run with -ksp_view and it will provide all the
> information about how the solves are layered.
> Many thanks,
> Karthik.
> *Date: *Tuesday, 7 February 2023 at 19:52
> On Feb 7, 2023, at 1:20 PM, Karthikeyan Chockalingam - STFC UKRI <
> Thank you Barry for your detailed response.
> I would like to shed some light into what I try to accomplish using PETSc
> and AMReX. Please see the *attachment adaptive mesh image* (and ignore
> the mesh-order legend for now).
> The number of elements on each level is a geometric progression.
> N - Number elements on each level indexed by ‘n’
> n - Adaptive mesh level index (starting from 1)
> a - Number of elements on the base mesh = 16
> r = 4 (each element is divided into four on the next higher level of
> refinement)
> N = a r^(n-1)
> The final solution u, is the super imposition of solutions from all levels
> (here we have a total of 7 levels).
> u = u^(1) + u^(2) + … + u^(7)
> Hence I have seven system matrix and solution vector pairs, one for each
> level.
> On each level the element index vary from 1 to N. But on each level NOT
> all elements are ‘active’.
> As you can see from the attached image not all elements are active (*a
> lot of white hollow spaces*). So the ‘active’ indexes can be scatted
> anywhere between 1 to N = 65536 for n = 7.
> (Q1) In my case, I can’t at the moment insert 1 on the diagonal because
> during assembly I am using ADD_VALUES as a node can be common to many
> elements. So I added 0.0 to ALL diagonals. After global assembly, I find
> that the linear solver converges.
> (Q2) After adding 0.0 to all diagonal. I able to solve using either
> ierr = PetscOptionsSetValue(NULL,"-redistribute_pc_type", "jacobi");
> CHKERRQ(ierr);
> or
> ierr = PetscOptionsSetValue(NULL," pc_type", "jacobi"); CHKERRQ(ierr);
> I was able to solve using hypre as well.
> Do I need to use -pc_type redistribute or not? Because I am able to solve
> without it as well.
> No you do not need redistribute, but for large problems with many empty
> rows using a solver inside redistribute will be faster than just using that
> solver directly on the much larger (mostly empty) system.
> (Q3) I am sorry, if I sound like a broken record player. On each level I
> request allocation for A[N][N]
> Not sure what you mean by this? Call MatMPIAIJSetPreallocation(...
> N,NULL); where N is the number of columns in the matrix?
> If so, yes this causes a huge malloc() by PETSc when it allocates the
> matrix. It is not scalable. Do you have a small upper bound on the number
> of nonzeros in a row, say 9 or 27? Then use that instead of N, not perfect
> but much better than N.
> Barry
> as the indexes can be scatted anywhere between 1 to N but most are
> ‘inactive rows’. Is -pc_type *redistribute* the way to go for me to save
> on memory? Though I request A[N][N] allocation, and not all rows are active
> - I wonder if I am wasting a huge amount of memory?
> Kind regards,
> Karthik.
> *Date: *Monday, 6 February 2023 at 22:42
> Sorry was not clear MatZero*. I just meant MatZeroRows() or
> MatZeroRowsColumns()
> On Feb 6, 2023, at 4:45 PM, Karthikeyan Chockalingam - STFC UKRI <
> No problem. I don’t completely follow.
> (Q1) I have used MATMPIAJI but not sure what is MatZero* (star) and what
> it does? And its relevance to my problem.
> (Q2) Since I am creating a MATMPIAJI system– what would be the best way to
> insert 0.0 in to ALL diagonals (both active and inactive rows) to begin
> with?
> Yes, just have each MPI process loop over its rows and put zero on the
> diagonal (actually, you could put a 1 if you want). Then have your code use
> AMReX to
> put all its values in, I am assuming the code uses INSERT_VALUES so it
> will always overwrite the value you put in initially (hence putting in 1
> initially will be fine; the advantage of 1 is if you do not
> use PCREDISTIBUTE the matrix is fully defined and so any solver will work.
> If you know the inactive rows you can just put the diagonal on those since
> AMReX will fill up the rest of the rows, but it is harmless to put values
> on all diagonal entries. Do NOT call MatAssemblyBegin/End between filling
> the diagonal entries and having AMReX put in its values.
> (Q3) If I have to insert 0.0 only into diagonals of “inactive” rows after
> I have put values into the matrix would be an effort. Unless there is a
> straight forward to do it in PETSc.
> (Q4) For my problem do I need to use PCREDISTIBUTE or any linear solve
> would eliminate those rows?
> Well no solver will really make sense if you have "inactive" rows, that
> is rows with nothing in them except PCREDISTIBUTE.
> When PETSc was written we didn't understand having lots of completely
> empty rows was a use case so much of the functionality does not work in
> that case.
> Best,
> Karthik.
> *Date: *Monday, 6 February 2023 at 20:18
> Sorry, I had a mistake in my thinking, PCREDISTRIBUTE supports
> completely empty rows but MatZero* does not.
> When you put values into the matrix you will need to insert a 0.0 on the
> diagonal of each "inactive" row; all of this will be eliminated during the
> linear solve process. It would be a major project to change the MatZero*
> functions to handle empty rows.
> Barry
> On Feb 4, 2023, at 12:06 PM, Karthikeyan Chockalingam - STFC UKRI <
> Thank you very much for offering to debug.
> I built PETSc along with AMReX, so I tried to extract the PETSc code alone
> which would reproduce the same error on the smallest sized problem possible.
> I have attached three files:
> petsc_amrex_error_redistribute.txt – The error message from amrex/petsc
> interface, but THE linear system solves and converges to a solution.
> problem.c – A simple stand-alone petsc code, which produces almost the
> same error message.
> petsc_ error_redistribute.txt – The error message from problem.c but
> strangely it does NOT solve – I am not sure why?
> Please use problem.c to debug the issue.
> Kind regards,
> Karthik.
> *Date: *Saturday, 4 February 2023 at 00:22
> If you can help me reproduce the problem with a simple code I can debug
> the problem and fix it.
> Barry
> On Feb 3, 2023, at 6:42 PM, Karthikeyan Chockalingam - STFC UKRI <
> I updated the main branch to the below commit but the same problem
> persists.
> *[0]PETSC ERROR: Petsc Development GIT revision:
> v3.18.4-529-g995ec06f92 GIT Date: 2023-02-03 18:41:48 +0000*
> *Date: *Friday, 3 February 2023 at 18:51
> If you switch to use the main branch of petsc
> https://petsc.org/release/install/download/#advanced-obtain-petsc-development-version-with-git you
> will not have the problem below (previously we required that a row exist
> before we zeroed it but now we allow the row to initially have no entries
> and still be zeroed.
> Barry
> On Feb 3, 2023, at 1:04 PM, Karthikeyan Chockalingam - STFC UKRI <
> Thank you. The entire error output was an attachment in my previous email.
> I am pasting here for your reference.
> [1;31m[0]PETSC ERROR: --------------------- Error Message
> [0;39m[0;49m[0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR: Matrix is missing diagonal entry in row 0 (65792)
> [0]PETSC ERROR: WARNING! There are option(s) set that were not used! Could
> be the program crashed before they were used or a spelling mistake, etc!
> [0]PETSC ERROR: Option left: name:-options_left (no value)
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.18.1-127-ga207d08eda
> GIT Date: 2022-10-30 11:03:25 -0500
> [0]PETSC ERROR:
> /Users/karthikeyan.chockalingam/AMReX/amrFEM/build/Debug/amrFEM on a named
> HC20210312 by karthikeyan.chockalingam Fri Feb 3 11:10:01 2023
> [0]PETSC ERROR: Configure options --with-debugging=0
> --prefix=/Users/karthikeyan.chockalingam/AMReX/petsc
> --download-fblaslapack=yes --download-scalapack=yes --download-mumps=yes
> --with-hypre-dir=/Users/karthikeyan.chockalingam/AMReX/hypre/src/hypre
> [0]PETSC ERROR: #1 MatZeroRowsColumns_SeqAIJ() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/impls/aij/seq/aij.c:2218
> [0]PETSC ERROR: #2 MatZeroRowsColumns() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/interface/matrix.c:6085
> [0]PETSC ERROR: #3 MatZeroRowsColumns_MPIAIJ() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/impls/aij/mpi/mpiaij.c:879
> [0]PETSC ERROR: #4 MatZeroRowsColumns() at
> [0]PETSC ERROR: #5 MatZeroRowsColumnsIS() at
> /Users/karthikeyan.chockalingam/AMReX/SRC_PKG/petsc/src/mat/interface/matrix.c:6124
> [0]PETSC ERROR: #6 localAssembly() at
> /Users/karthikeyan.chockalingam/AMReX/amrFEM/src/FENodalPoisson.cpp:435
> Residual norms for redistribute_ solve.
> 0 KSP preconditioned resid norm 5.182603110407e+00 true resid norm
> 1.382027496109e+01 ||r(i)||/||b|| 1.000000000000e+00
> 1 KSP preconditioned resid norm 1.862430383976e+00 true resid norm
> 4.966481023937e+00 ||r(i)||/||b|| 3.593619546588e-01
> 2 KSP preconditioned resid norm 2.132803507689e-01 true resid norm
> 5.687476020503e-01 ||r(i)||/||b|| 4.115313216645e-02
> 3 KSP preconditioned resid norm 5.499797533437e-02 true resid norm
> 1.466612675583e-01 ||r(i)||/||b|| 1.061203687852e-02
> 4 KSP preconditioned resid norm 2.829814271435e-02 true resid norm
> 7.546171390493e-02 ||r(i)||/||b|| 5.460217985345e-03
> 5 KSP preconditioned resid norm 7.431048995318e-03 true resid norm
> 1.981613065418e-02 ||r(i)||/||b|| 1.433844891652e-03
> 6 KSP preconditioned resid norm 3.182040728972e-03 true resid norm
> 8.485441943932e-03 ||r(i)||/||b|| 6.139850305312e-04
> 7 KSP preconditioned resid norm 1.030867020459e-03 true resid norm
> 2.748978721225e-03 ||r(i)||/||b|| 1.989091193167e-04
> 8 KSP preconditioned resid norm 4.469429300003e-04 true resid norm
> 1.191847813335e-03 ||r(i)||/||b|| 8.623908111021e-05
> 9 KSP preconditioned resid norm 1.237303313796e-04 true resid norm
> 3.299475503456e-04 ||r(i)||/||b|| 2.387416685085e-05
> 10 KSP preconditioned resid norm 5.822094326756e-05 true resid norm
> 1.552558487134e-04 ||r(i)||/||b|| 1.123391894522e-05
> 11 KSP preconditioned resid norm 1.735776150969e-05 true resid norm
> 4.628736402585e-05 ||r(i)||/||b|| 3.349236115503e-06
> Linear redistribute_ solve converged due to CONVERGED_RTOL iterations 11
> KSP Object: (redistribute_) 1 MPI process
> type: cg
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> PC Object: (redistribute_) 1 MPI process
> type: jacobi
> type DIAGONAL
> linear system matrix = precond matrix:
> Mat Object: 1 MPI process
> type: mpiaij
> rows=48896, cols=48896
> total: nonzeros=307976, allocated nonzeros=307976
> total number of mallocs used during MatSetValues calls=0
> not using I-node (on process 0) routines
> End of program
> solve time 0.564714744 seconds
> Starting max value is: 0
> Min value of level 0 is: 0
> Interpolated min value is: 741.978761
> Unused ParmParse Variables:
> [TOP]::model.type(nvals = 1) :: [3]
> [TOP]::ref_ratio(nvals = 1) :: [2]
> AMReX (22.10-20-g3082028e4287) finalized
> #PETSc Option Table entries:
> -ksp_type preonly
> -options_left
> -redistribute_ksp_converged_reason
> -redistribute_ksp_monitor_true_residual
> -redistribute_ksp_type cg
> -redistribute_ksp_view
> -redistribute_pc_type jacobi
> #End of PETSc Option Table entries
> There are no unused options.
> Program ended with exit code: 0
> Best,
> Karthik.
> *Date: *Friday, 3 February 2023 at 17:41
> We need all the error output for the errors you got below to understand
> why the errors are happening.
> On Feb 3, 2023, at 11:41 AM, Karthikeyan Chockalingam - STFC UKRI <
> Hello Barry,
> I would like to better understand pc_type redistribute usage.
> I am plan to use pc_type *redistribute* in the context of adaptive mesh
> refinement on a structured grid in 2D. My base mesh (level 0) is indexed
> from 0 to N-1 elements and refined mesh (level 1) is indexed from 0 to
> 4(N-1) elements. When I construct system matrix A on (level 1); I probably
> only use 20% of 4(N-1) elements, however the indexes are scattered in the
> range of 0 to 4(N-1). That leaves 80% of the rows and columns of the system
> matrix A on (level 1) to be zero. From your earlier response, I believe
> this would be a use case for petsc_type redistribute.
> Indeed the linear solve will be more efficient if you use the
> redistribute solver.
> But I don't understand your plan. With adaptive refinement I would just
> create the two matrices, one for the initial grid on which you solve the
> system, this will be a smaller matrix and then create a new larger matrix
> for the refined grid (and discard the previous matrix).
> Question (1)
> If N is really large, I would have to allocate memory of size 4(N-1) for
> the system matrix A on (level 1). How does pc_type redistribute help?
> Because, I did end up allocating memory for a large system, where most of
> the rows and columns are zeros. Is most of the allotted memory not wasted?
> *Is this the correct usage?*
> See above
> Question (2)
> I tried using pc_type redistribute for a two level system.
> I have *attached* the output only for (level 1)
> The solution converges to right solution but still petsc outputs some
> error messages.
> But the there were no unused options
> -ksp_type preonly
> -options_left
> *There are no unused options.*
> I cannot explain this
> Question (2)
> What does this error message imply? Given I only use 20% of 4(N-1)
> indexes, I can imagine most of the diagonal entrees are zero. *Is my
> understanding correct?*
> Question (3)
> I am using MatZeroRowsColumnsIS to set the homogenous Dirichelet boundary.
> I don’t follow why I get this error message as the linear system converges
> to the right solution.
> Thank you for your help.
> Kind regards,
> Karthik.
> *Date: *Tuesday, 10 January 2023 at 18:50
> Yes, after the solve the x will contain correct values for ALL the
> locations including the (zeroed out rows). You use case is exactly what
> redistribute it for.
> Barry
> On Jan 10, 2023, at 11:25 AM, Karthikeyan Chockalingam - STFC UKRI <
> Thank you Barry. This is great!
> I plan to solve using ‘-pc_type redistribute’ after applying the Dirichlet
> bc using
> MatZeroRowsColumnsIS(A, isout, 1, x, b);
> While I retrieve the solution data from x (after the solve) – can I index
> them using the original ordering (if I may say that)?
> Kind regards,
> Karthik.
> *Date: *Tuesday, 10 January 2023 at 16:04
> https://petsc.org/release/docs/manualpages/PC/PCREDISTRIBUTE/#pcredistribute
> It does everything for you. Note that if the right hand side for any of
> the "zero" rows is nonzero then the system is inconsistent and the system
> does not have a solution.
> Barry
> On Jan 10, 2023, at 10:30 AM, Karthikeyan Chockalingam - STFC UKRI via
> Hello,
> I am assembling a MATIJ of size N, where a very large number of rows (and
> corresponding columns), are zeros. I would like to potentially eliminate
> them before the solve.
> For instance say N=7
> 0 0 0 0 0 0 0
> 0 1 -1 0 0 0 0
> 0 -1 2 0 0 0 -1
> 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0
> 0 0 0 0 0 0 0
> 0 0 -1 0 0 0 1
> I would like to reduce it to a 3x3
> 1 -1 0
> -1 2 -1
> 0 -1 1
> I do know the size N.
> Q1) How do I do it?
> Q2) Is it better to eliminate them as it would save a lot of memory?
> Q3) At the moment, I don’t know which rows (and columns) have the zero
> entries but with some effort I probably can find them. Should I know which
> rows (and columns) I am eliminating?
> Thank you.
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
> <petsc_redistribute.txt>
> <petsc_error_redistribute.txt><petsc_amrex_error_redistribute.txt><problem.c>
> <adaptive_mesh_level.png>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230213/445bcc79/attachment-0001.html>
